Go to Post IRI: Where the Egos Go to Tie. :ahh: - Ian Curtis [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 18-06-2014, 12:18
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: pic: Plywood Butterfly Drive Render
Originally Posted by AllenGregoryIV View Post
The biggest issue with this is it makes it harder to do your reductions.
It's not too hard with the central gearbox design since you can do a second reduction with the belts to the modules. From JVN's calculator, a 12:60 reduction in the gearbox and a 24:42 reduction with the belts gives adjusted speeds of 6.4fps on the Colson wheels and 12.9 fps on the omni wheels.
Originally Posted by Joe G. View Post
Have you considered using pancake cylinders for module actuation to save some space and weight?
I'll look into doing that.
I noticed a few problems with my design that I also need to fix in the next iteration: the belts to the modules run into the bellypan, the bolt that serves as an axle for the gearbox is not adequately supported and the bottom two CIMs in each gearbox can't be installed or removed once the chassis is assembled.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 18-06-2014, 13:10
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
The other reason we prefer to float the traction wheels is that if we lose air, or if we lose a belt in a module we default to the omni wheels which is where we spend around 90% of our time anyway.
Unread 18-06-2014, 13:40
Chris is me's Avatar
AKA: Pinecone
If it simplifies the design, you could consider the option of using shifters for the central gearboxes rather than a pulley reduction between the traction and omni wheel. That way, you can shift from high speed to high torque independently of which wheels are on the ground and pivoting about the traction wheel isn't a big hassle. However, this is added complexity.
Unread 20-06-2014, 00:14
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
It's great to see another team going with this method of construction. Mine has been doing laser cut plywood chassis in the past two years, and we love it.
Unread 20-06-2014, 00:21
Custom User Title
AKA: Cal
Is there anywhere I could find more information on your designs and construction method? What thickness and type of wood did you use? How did it hold up in competition?
It's hard to find high-quality information about wood chassis in FRC since so few teams have used them.
Unread 20-06-2014, 02:27
RKIyer's Avatar
RKIyer RKIyer is offline
Student Hardware Lead
AKA: Rahul Iyer
FRC #0846 (The Funky Monkeys)
RKIyer is an unknown quantity at this point
How are the cut plywood pieces of your frame and wheel assemblies attached together? Are you using a glue? Or are there tiny screws?
Lynbrook Robotics
www.lynbrookrobotics.com
www.becauserobots.org
The Funky Monkeys, FRC Team 846
Vice President, Engineering
2014 Dean's List Finalist - Silicon Valley Regional
Unread 20-06-2014, 08:45
Electronica1's Avatar
Electronica1 Electronica1 is online now
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
You can go on http://frcdesigns.com/ and look at 1771's cad from 2011 and 2012. They had some very good wood robots.
Unread 20-06-2014, 11:13
Custom User Title
AKA: Cal
It's designed to be assembled using wood glue.
Unread 27-06-2014, 07:47
Custom User Title
AKA: Cal
Here's my progress on the next iteration of the drivetrain. The chassis will be sturdier when complete, but the module and powertrain are just about done. Currently, it weighs 30.5 lbs (the same as the original 4-CIM version).
Improvements in this version include:
-Simpler and lighter powertrain due to direct-drive gearbox
-Stiffer module with less wasted space
-Smaller, lighter pancake cylinders for switching between wheels
-Narrower side rails and more open bellypan
The outside plates will be attached with T-nuts (http://goo.gl/XBWxdN) so they are removable for easy maintenance.
Unread 27-06-2014, 17:57
Custom User Title
AKA: Cal
Here's the more-or-less complete version of the drivetrain, except for the finger joints, which are time-consuming and no fun to draw. Sturdier structure, lightening holes and encoder mounts are added. The pneumatic cylinder mounting is improved.
The two aluminum tubes on top are an example of how a hinged superstructure can be mounted, similar to our 2014 robot (http://www.chiefdelphi.com/media/photos/39338).
I'd like to integrate bumper mounts into the wood frame, but am uncertain of how best to do so in a way that is simple, robust and allows for quick swaps. Anyone have ideas?
Unless anyone has ideas for improvement, next steps are probably cutting some test pieces on the laser to learn about best practices for finger joints, large parts and bearing fits before manufacturing a full drivetrain.
