Go to Post This isn't a science fair, sometimes it's okay to give away the answer, especially if they learned something on the way there. - Karthik [more]
Unread 14-06-2014, 11:13
idoshamir idoshamir is offline
FRC #5038
idoshamir is an unknown quantity at this point
LabVIEW and FAULHABER MCDC 3006 S RS
Hello,
I need to find out if it is possible to program a FAULHABER MCDC 3006 S RS ( http://www.faulhaber.com/manuals/sit...3006_s_rs.html ) with LabVIEW.
Does it need an additional API or can it be done natively and how?
Thank you,
Ido
Unread 18-06-2014, 13:45
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Re: LabVIEW and FAULHABER MCDC 3006 S RS
What do you mean by program? Are you trying to use RS232, CAN, or PWM?
Unread 18-06-2014, 22:44
pastelpony's Avatar
pastelpony pastelpony is offline
Programmer/Electrical
AKA: Zach M
FRC #3525 (Nuts and Bolts of Fury)
pastelpony will become famous soon enough
I believe instead of treating it as a motor, you can operate it by treating it as an analog output through PWM.
Judging by the technical manual's description, I believe this can work.
Team 3525 Head Programmer (2014- ) - Java (Formerly LabVIEW)
Unread 19-06-2014, 07:00
FRC #5038
Hi,
Thank you for the help but I figured it out, working with VISA for serial COM ports. The tricky part is the reply from the VISA Read is in an unknown length so I have to read one byte at a time until a stop char is given.
Thanks anyway!
Ido
Unread 19-06-2014, 10:42
pastelpony's Avatar
AKA: Zach M
Originally Posted by idoshamir View Post
Hi,
Thanks anyway!
Ido
I forgot you could communicate with motor controllers using VISA. Thanks.
Unread 07-07-2014, 16:12
gpri gpri is offline
gpri is an unknown quantity at this point
Hi,
Thanks anyway!
Ido
What information are you able to get from the motion controller using VISA Read? I'm trying to get the position of my linear actuator as a function of time so I can get it's actual amplitude and frequency, but I've not been having much luck with VISA Read. How exactly do you have that part of your code set up?
