Go to Post Think, Write, Re-Think, Erase or Post - and Deal With it Either Way. - Chris Fultz [more]
Unread 18-06-2014, 11:05
Re: Encoder rate noise
Look at the datasheet for the tolerance specs on symmetry and quadrature delay for this encoder. These also affect the max speed the FPGA can handle.
Using 4X decoding with no sampling is likely to be very noisy, given the above-mentioned tolerances on symmetry and quadrature.
Free play between the encoder shaft and whatever it engages can exacerbate the noise, especially if using 4X decoding with no sampling.
Unread 18-06-2014, 11:41
Originally Posted by compwiztobe View Post
What happens if you switch 4x decoding to 1x? You lose direction sensitivity, but it only counts one edge of one channel, instead of both, so it may be able to keep up better.
Switching to 1x decoding does not lose direction sensitivity. It still uses the B channel for direction, but only 1 transition of the A channel.
1x decoding helps reduce noise beyond just reducing counts to within the limit of the FPGA. It also allows additional digital samples between each count, effectively acting like averaging 4 samples at 4x. It also ignores manufacturing tolerances between the different signals, like Ether mentioned. For the S4 encoder, B lags A by 90 degress +/- 60 degrees (max).
Unread 18-06-2014, 11:43
Originally Posted by notmattlythgoe View Post
I really hope they make this available in C++ and Java without having to modify the source in this next year's version of the API.
Like Aren pointed out, this was added prior to the 2014 season. http://wpilib.screenstepslive.com/s/...d-known-issues
Unread 18-06-2014, 16:00
Aren Siekmeier's Avatar
on walkabout
Ah, thanks for that, good to know. I'm guessing 2x behaves similarly, skipping the falling edge of each channel and using it as a second sample to smooth things out relative to 4x.
Unread 18-06-2014, 16:13
on walkabout
Originally Posted by Bpk9p4 View Post
Thanks for all of the great replies. It is amazing the support you can get on this website.
I am using the sleeve bearing (not sure on part number) so you could be correct and i am exceeding the max speed. however i still get a lot of noise at low speed
I will add the config timer tonight when i get home and try reducing it to x1 to see if that helps. I am currently running it with no load already. i will also post a plot of the encoder values and noise and more information about which encoder i have
edit:
Gear box: VexPro 3 cim ball shifter with 2.16 ratio and we are mounting the encoder to the gear box with an idler sprocket
encoder: us digital s4 with 256 cpr
Are you driving the encoder using the press on plastic gears on the backside of the gearbox (near the shifting cylinder)? The larger of these gears is known to sometimes have a sloppy press fit, you could superglue it in place if this is the case to ensure no slip between the ball shifter output shaft and this gear that drives the encoder gear.
Unread 18-06-2014, 16:15
on walkabout
What if the FPGA cannot keep up with all of the counts it would be averaging at 1x? Does it still properly count every 4th tick, even though the 3 in between go by too quickly? And then adds in the extra samples (and direction sensing) provided 3 intermediate ticks, provided they are slow enough to capture? Sort of nitpicking...
Unread 18-06-2014, 16:26
2x uses the rising and falling pulse of channel A (since those are 180 degrees apart).
Unread 18-06-2014, 16:52
All that matters is the edge that it is looking for at 1x does not exceed the digital clock rate (It will count and handle direction correctly, but will have horrible rate noise). It doesn't matter if the other edges happen too fast, because it will latch the values on the digital clock.
Unread 18-06-2014, 20:49
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant future
thanks you very much for all of your suggestions. I put the config timer in the begin file and it cleaned up a lot of the noise. what number of samples do you normal avareage
Unread 19-06-2014, 11:46
I would still like to know what you refer to as "noise".
Unread 19-06-2014, 11:57
Iaquinto.Joe's Avatar
Iaquinto.Joe Iaquinto.Joe is offline
RPI 2018
AKA: Joe Iaquinto
FRC #0308 (The Monsters)
Iaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the rough
We used a Low Pass filter of 20% to reduce the noise of our drive encoder rates. I've linked to the code below. Key note: The Low Pass filter code I linked needs to be executed as a preallocated clone reentrant because data is stored for more than 1 iteration. Go to vi properties>execution for this setting. You can tune LPFilt to whatever works best.
Context:
http://puu.sh/9ADYL/292687bb80.png
LPFilt.vi:
http://puu.sh/9ADVq/5b0cc41731.png
4 year 2011 - 2014 FRC team 308 member, Lead Programmer - C++ / LabVIEW
3 year 2011, 2013, 2014 OCCRA member, Co-Captain OCCRA team 308
  • OCCRA Engineering Excellence - Waterford Kettering 2013
  • Innovation in Control - 2011
  • Quality award- Northville 2012
  • Engineering Excellence- Howell 2014
  • Innovation in Controls- Livonia 2014
Unread 19-06-2014, 13:11
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
This is not entirely true. The behavior of the quadrature decoder is not guaranteed if both signals change value on the same clock cycle. For the cRIO, that means if A and B channels both change within a single 6.525 us sampling period on the DIO module, that the count will fail. I don't recall what the FPGA does in this case. If it doesn't count at all, it means there is nothing to measure the time of. If you are seeing glitches where the rate is occasionally close to half of subsequent rate measurements (with averaging off of course) then you may identify this.
Fundamentally, the 1x vs 4x decoding only affects the amount of averaging you can do (by essentially being an average of 4 samples). It also affects how much position resolution you have if you care about that (but exposes you to mechanical inaccuracy as described above). Another difference is simply that there are 12 quadrature decoders in the FPGA... 8 counters (capable of 1x and 2x decoding) and 4 dedicated 4x quadrature decoding units. Bottom line, the FPGA still has to "see" all 4 edges in sequence no matter what the decoding scheme.
Of course if you are running anywhere near the digital I/O sampling rate, then the FPGA's built-in rate calculations are so noisy that they are practically useless. In this situation I recommend that you calculate the rate by reading the number of counts that changed in a fixed time period. This will be far more accurate at these high speeds. You can very accurately get the counts in a fixed time period by using the DMA feature of the FPGA to send the encoder count value at exact intervals measured by the FPGA.
Unread 19-06-2014, 13:34
...because you can't tell which edge came first, so you don't know the direction.
Unless you setup the FPGA to do averaging over a large enough sample size?
Are there code examples how to do this in all 3 supported languages?
Unread 19-06-2014, 13:41
AKA: jhersh
Correct. Also for noise rejection. If you get a bounce or even a little electrical noise around a transition, you may count that edge more than once (you could use digital filtering, but that drops the max rate even further).
I suppose it could just assume the direction hasn't changed, and go ahead and use the data. But I can imagine scenarios where that might be fraught with peril.
That would break noise rejection and could also be an invalid assumption. The point is the decoder simply doesn't know.
Perhaps, depending on your requirements. Generally it is the wrong approach for very fast encoder signals.
Not that I'm aware of. I don't even know that DMA was implemented at the API level in WPILib for C++ and Java.
Unread 19-06-2014, 14:13
I did a little math about this about 10 months ago:
http://www.chiefdelphi.com/forums/sh...34&postcount=7
If there's anyone reading this thread whose team has successfully implemented Joe's DMA recommendation, would you please share your code.
