Re: 1500 3D printers will be donated to teams
I have been in the Rapid Prototyping/3D printing business for many years. I worked with one of the first commercial SLAs many moons ago.
3D Systems has never made a secret of their business plan, which is to make money primarily on material, not machines. After all you sell material again and again while machines tend to be around for years. So they sell machines at a break-even price and make it up on the material which only comes in proprietary packages that will only work on their machines. Of course this means paying 3 or so times the going rate per pound for material. |
There is quality variation in off-the-shelf filament, but after going through about a dozen kilos of ABS and PLA in the past two years I've only found one roll that I hold as 'suspect'.
Right now I'm using a roll that I got from www.robotdigg.com and it seems to be working just fine. You'll note that robotdigg also has some great deals on steppers and bearings. Their order process isn't a 'one click' process... you actually have to email back and forth a bit before paying over paypal, but I have been happy with the one order that I have placed with them and plan to order more. A team wanting to save money on filament could always just rip out the original electronics and replace them with a RepRap style control board. I've built a couple RepRap Gen7 boards (for about $30 each, plus another $30 for stepper drivers) and they seem to be working fine in initial testing. After all, FDM 3D printers are basically just four stepper motors and a hot end, plus some limit switches and maybe a heated bed. Or a team could build their own printer for a couple hundred bucks. Depending on how much printing you are going to do, it might be cheaper to build or buy an open-source machine and use commodity filament. Jason |
