Go to Post The robot uprising is coming for your chairs first, people. - bobbysq [more]
Unread 20-06-2014, 17:39
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: pic: Encoder Noise
Agreed :-) So:
What is the complete part number of the part you're using (including CPR, bearing type, etc)?
Were you reading counts from the FPGA and dividing by elapsed time, or reading the rate from the FPGA? Please post code if you have it.
@jhersh: (if you are following this thread) would there be any advantage, tolerance-wise, to change the sample size to an even multiple of 4 (say 12 or 8) so that the averaging would always take place over an integer number of cycles?
S4-120-250-N-S-B
We were reading the rate from the FPGA. I'l post some code when I get a chance.
Unread 20-06-2014, 18:35
Originally Posted by notmattlythgoe View Post
S4-120-250-N-S-B
Your S4 is less than half the CPR of the OP's and has ball bearings. So the two are not comparable. What works for you won't necessarily work for the OP.
At 7K RPM you are exceeding the speed the FPGA could handle if your S4 were at max tolerance for quadrature phase error:
Welcome to RLaB. New users type `help INTRO'
RLaB version 2.1.05 Copyright (C) 1992-97 Ian Searle
RLaB comes with ABSOLUTELY NO WARRANTY; for details type `help warranty'
This is free software, and you are welcome to redistribute it under
certain conditions; type `help conditions' for details
> format(5);
> CPR = 120 # cycles per rev (single channel)
      120
> EPRS = 2*CPR # edges per rev (single channel)
      240
> EPRQ = 2*EPRS # edges per rev quadrature (both channels)
      480
> RPEQ = 1/EPRQ # angular distance (revs) between cross-channel edges
0.0020833
> per = 261/40e6 # FPGA sampling period, seconds
6.525e-006
> RPS = RPEQ/per # maximum revs per sec
   319.28
> RPM = RPS*60 # maximum RPM (revs per minute)
    19157
> # with "typical" tolerance:
> RPEQ_TYP = (90-10)/90*RPEQ
0.0018519
> RPM_TYP = RPEQ_TYP/per*60
    17029
> # angular distance (revs) between cross-channel edges with "max" tolerance:
> RPEQ_MAX = (90-60)/90*RPEQ
0.00069444
> RPM_MAX = RPEQ_MAX/per*60
   6385.7
> # RPM with no tolerance, typical tolerance, and max tolerance:
> RPM
    19157
> RPM_TYP
    17029
> RPM_MAX
   6385.7
Unread 20-06-2014, 18:40
Flywheel Police
> format(5);
      120
      240
      480
0.0020833
6.525e-006
   319.28
    19157
0.0018519
    17029
0.00069444
   6385.7
> RPM
    19157
> RPM_TYP
    17029
> RPM_MAX
   6385.7
After thinking about it more we weren't at 7k rpm the encoder was reporting a rate of 7k.
Unread 21-06-2014, 17:11
7k what?
Unread 23-06-2014, 08:05
Flywheel Police
7k what?
Pulses per second. Which I believe should put it around 875 RPM.
(7000 pules/s / 480 EPRQ) * 60 s = 875 RPM
