Go to Post ...remember RAID 0 is a trap. - Sperkowsky [more]
Unread 20-06-2014, 23:25
LFRobotics's Avatar
LFRobotics LFRobotics is offline
FRC #4623
LFRobotics is on a distinguished road
Xbox Controller
I got help earlier but I have tried to program one in and just cant figure it out. I am completely lost and need lots of help so if anyone out there is willing id be forever grateful.
THANKS!
Unread 20-06-2014, 23:58
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
Re: Xbox Controller
Its just like any other controller, except with more axes and buttons. See the following post: http://www.chiefdelphi.com/forums/sh...51&postcount=4. Go to "Run" on your computer and type in "joy.cpl" (without quotes, with the controller plugged in). Then go to properties to see the button numbers.
Unread 21-06-2014, 13:55
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Xbox Controller
https://github.com/team1306/Badgerbo...ontroller.java
Unread 21-06-2014, 16:49
LFRobotics's Avatar
FRC #4623
Re: Xbox Controller
I sorry but I have tried for hours now and just cant seem to figure out how to implement both your ways. Like how do I use buttons - because the regular "button.whenPressed(new exampleCommand());" isn't working. How do I make it work with tankdrive when there are not two joysticks connected but rather one controller. I am sooooo confused and I tried to figure it out on my own but I have gotten nowhere.
THANKS for the help.
Unread 21-06-2014, 20:52
NWChen's Avatar
NWChen NWChen is offline
Alum
NWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to behold
Re: Xbox Controller
Can we see the code you have so far?
Assuming you're using a RobotDrive object to control your drivetrain, and the tankDrive method, your Xbox controller (like ekapalka said) should behave much like a pair of joysticks in tank drive - with each Xbox stick controlling one side of the drivetrain.
drive.tankDrive(gamepad.getLeftStickY(), gamepad.getRightStickY();
2012 - 2015 • Team 2601
Unread 22-06-2014, 14:54
LFRobotics's Avatar
FRC #4623
Re: Xbox Controller
Okay - im still confused about how to implement it in my DriveTele command and how to make buttons work.
Here's is the Chassis subsystem - I think I have this figured out:
package edu.wpi.first.XBoxBot2014.subsystems;
import edu.wpi.first.XBoxBot2014.OI;
import edu.wpi.first.XBoxBot2014.RobotMap;
import edu.wpi.first.XBoxBot2014.commands.DriveTele;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.command.Subsystem;
 * @author FrankyMonezz
public class Chassis extends Subsystem {
    // Put methods for controlling this subsystem
    // here. Call these from Commands.
    RobotDrive drive;
    OI oi = new OI();
    public void initDefaultCommand() {
        // Set the default command for a subsystem here.
        setDefaultCommand(new DriveTele());
    public Chassis(){
        drive = new RobotDrive(RobotMap.leftMotorPort, RobotMap.rightMotorPort);
        drive.setSafetyEnabled(false);
    public void driveTele(Joystick leftStick, Joystick rightStick){
       drive.tankDrive(oi.xcon2.getLeftJoyY(), oi.xcon2.getRightJoyY());
    public void setSpeed(double speed){
        drive.setMaxOutput(speed);
    public void driveAuton(double speed, double turnRate)
	drive.arcadeDrive(speed, turnRate);
Here is the XBoxController class that im using - kindly given to me by cgmv123:
import edu.wpi.first.wpilibj.DriverStation;
 * @author Jon Morton
public class XBoxController {
    private DriverStation _ds;
    private final int _port;
    public XBoxController(int port) {
        _ds = DriverStation.getInstance();
        _port = port;
    public double getRawAxis(final int axis) {
        return _ds.getStickAxis(_port, axis);
    public boolean getRawButton(final int button) {
        return ((0x1 << (button - 1)) & _ds.getStickButtons(_port)) != 0;
     * Warning! getRightTrigger() and getLeftTrigger() both use getRawAxis(3).
     * As getRawAxis(3) goes below zero, getRightTrigger() increases, and as
     * getRawAxis(3) goes above zero, getLeftTrigger() increases. If both
     * triggers are pressed, both of them will be treated as zero. You can only
     * use one trigger at a time.
     * @return
    public double getRightTrigger() {
        return -Math.min(getRawAxis(3), 0);
    public double getLeftTrigger() {
        return Math.max(getRawAxis(3), 0);
    public double getRightJoyX() {
        return getRawAxis(4);
    public double getRightJoyY() {
        return getRawAxis(5);
    public double getLeftJoyX() {
        return getRawAxis(1);
    public double getLeftJoyY() {
        return getRawAxis(2);
    public boolean getButtonA() {
        return getRawButton(1);
    public boolean getButtonB() {
        return getRawButton(2);
    public boolean getButtonX() {
        return getRawButton(3);
    public boolean getButtonY() {
        return getRawButton(4);
    public boolean getButtonBack() {
        return getRawButton(7);
    public boolean getButtonStart() {
        return getRawButton(8);
    public boolean getButtonRB() {
        return getRawButton(6);
    public boolean getButtonLB() {
        return getRawButton(5);
    public boolean getButtonLS() {
        return getRawButton(9);
    public boolean getButtonRS() {
        return getRawButton(10);
I instantiate XBoxController here(conPort is an integer value of 1 stored in RobotMap) - I have the
boolean button = xcon2.getWHATEVER()
figured out - but how do I use that to turn say a motor on - because for example
button.whenPressed or button.when released
does not work with boolean values:
package edu.wpi.first.XBoxBot2014;
import edu.wpi.first.XBoxBot2014.subsystems.XBoxController;
public class OI {
    public XBoxController xcon2 = new XBoxController(RobotMap.conPort);
public OI() {
        boolean button = xcon2.getButtonA();
Unread 23-06-2014, 02:13
NWChen's Avatar
Alum
Re: Xbox Controller
Originally Posted by LFRobotics View Post
whenPressed() and whenReleased() are methods of the Button class, not of booleans. As a result, if you want to perform a command when a button is being pressed or released you need to call the method on a Button object, not a boolean.
The JoystickButton constructor takes a human interface device (Xbox controller object) and a button number as parameters. In your code, you could do the following:
public class OI {
    private Button button = new JoystickButton(xcon2, 1); //Button A = 1
    public OI() {
         button.whenPressed(doThing());
As for driveTele(), you don't need to take a leftStick and a rightStick as parameters if you don't use them in the method. Instead, drive.tankDrive() takes values from the xcon2 object in oi:
I don't have much expertise with command-based programming (sorry), but here's what I'd do to fix that problem with your current setup:
Replace the parameters with doubles, and take advantage of the fact that tankDrive() will also take a leftValue and rightValue as input:
public void driveTele(double leftValue, double rightValue){
    drive.tankDrive(leftValue, rightValue);
Your DriveTele() command will then look something like this.
Hope it works!
Unread 23-06-2014, 11:38
LFRobotics's Avatar
FRC #4623
Re: Xbox Controller
Thanks soooo much. It all worked except for the
Netbeans gets all mad and says
incompatible types: XBoxController cannot be converted to GenericHID
Unread 23-06-2014, 13:14
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Xbox Controller
What I would do in your case is scrap the use of the XBoxController class and use the provided Joystick class with these button/joystick mappings.
So for the A button it would be:
Joystick joystick = new Joystick(1);
private Button button = new JoystickButton(joystick, 0);
And to access the left and right sticks for tank drive it would be:
oi.joystick.getRawAxis(7); //Left stick
oi.joystick.getRawAxis(5); //Rightstick
The best way to do this would be to create a class that extends the Joystick class then:
-create getter methods for each of the buttons and axis
-create static constants that hold the mapped button numbers and axis
If you'd like more information on how to do this I can assist you there too.
Unread 23-06-2014, 14:43
NWChen's Avatar
Alum
Re: Xbox Controller
You can have the XBoxController class extend GenericHID and have NetBeans implement all abstract methods:
public class XBoxController extends GenericHID{
and that should allow you to cast XBoxController to a GenericHID.
notmattlythgoe's suggestion is much better, but for a quick fix right now this should work.
LFRobotics's Avatar
FRC #4623
Re: Xbox Controller
Okay I get it - but why cant I just continue to use
to assign my buttons or even
private Button button = new JoystickButton(joystick, joystick.getRawButton(0));
instead of having to create a whole new class.
And if it is completely necessary to do so I would need some help - I have an idea of what to do but I would still need some guidance.
THANKS!
Unread 23-06-2014, 14:49
Flywheel Police
Re: Xbox Controller
THANKS!
You don't need a whole new class. Writing the new class will just make it easier in the future to write code using the xbox controller, but they literally do the exact same thing.
Just using the JoystickButton along with the Joystick class is a perfectly fine way to do it. So for you I'd suggest you stick with the below for now.
Unread 23-06-2014, 14:54
LFRobotics's Avatar
FRC #4623
Re: Xbox Controller
@NWChen I tried that but it didn't work - THANKS though!
@notmattlythgoe In that case id like to do it - wouldn't it be a lot like the XBoxController class other than the fact that it extends the Joystick class - at least the getters would be the same
Unread 23-06-2014, 15:11
Flywheel Police
Re: Xbox Controller
Yes the getters would be similar.
You'll want to get rid of the getRaw...() methods from the XBoxController class because you get those automatically from extending the Joystick class. Also remove the port and driver station fields since the Joystick class takes care of that communication for you.
Don't forget to include a single parameter constructor that calls the Joystick constructor.
Then what you'll want to do is create a list of static final variables that hold the mapping values for the buttons, this way you don't have to memorize what button maps to what value. I would also suggest using these static fields as the values in the getter methods, this way if you ever have to change the value you only have to change it in one place.
Example:
public static final int A_BUTTON = 0;
public static final int B_BUTTON = 1;
etc...
        return getRawButton(A_BUTTON);
Then you can use it like so:
XBoxController joystick = new XBoxController(1);
private Button button = new JoystickButton(joystick, XBoxController.A_BUTTON);
Unread 23-06-2014, 15:53
LFRobotics's Avatar
FRC #4623
Re: Xbox Controller
Ok AWESOME - now this may seem like a dumb question to you but im a beginner programmer so here it is
How exactly do I extend the Joystick class - I tried it like this:
public class XBox extends Joystick {
but Netbeans doesn't like that
When you say
do you want that in the class and would that just look like
Joystick stick = new Joystick();
THANKS for all your help!
