Go to Post Here, and in general, avoid jumping to conclusions without research. This will serve you well in life. - DonRotolo [more]
Unread 23-06-2014, 12:40
stef stef is offline
stef is an unknown quantity at this point
How to make a 3-D surface graph from a given table data
Hello,
I'd like to insert some data from a 3-D table as shown in the attached picture in Labview software and represent these (x,y,z) data to a 3-D surface graph.
Could somedody please help me with that problem?
Stef.
Unread 24-06-2014, 05:24
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: How to make a 3-D surface graph from a given table data
LabVIEW has 3D graphing controls that are quite easy to use. The 3D Surface Graph control does exactly what you want. You can search for 3D Surface Graph in the front panel controls palette if you can't find it yourself. Follow the instructions here: http://zone.ni.com/reference/en-XX/h...data_3d_graph/. The location of the example VI that is included with LabVIEW changes somewhat depending on your version of LabVIEW. In 2013, it's at labview\examples\Controls and Indicators\Graphs and Charts\Math Plots - 3D\
FRC 766, 2015-, Mentor
Unread 24-06-2014, 09:09
Thanks a lot!!!! I found it
Stef
