Go to Post Joe is a great sport and this was a good moral booster after a grueling weekend. How many opportunities do you get to play William Tell with a Regional WFA Winner? :) - The Lucas [more]
Unread 23-06-2014, 13:48
blockwall2's Avatar
blockwall2 blockwall2 is offline
AKA: Adam Blocker
FTC #0772 (Caveman w/ Rock)
blockwall2 is an unknown quantity at this point
[FTC]: Alternative to axles? Does hardening work?
As just about everyone that has worked with Tetrix knows, the axles suck. The bend, they twist, etc. They work okay in low-torque situations, but they don't work in high-torque situations AT ALL.
For the upcoming season my team and I are looking into alternatives to the Tetrix axles or potentially hardening them.
Does anyone know of any alternatives to the Tetrix axles that have been used before?
Is it possible to harden the axles without making them too brittle?
Edit: The vast majority of our problems have occurred on non-drive axles, particularly in compound gear ratios that power some sort of arm.
Thanks in advance
FTC Team 772 - Hartsville, SC
Unread 23-06-2014, 14:28
JorgeReyes JorgeReyes is offline
Team Captain
FRC #2002 (Tualatin Robotics)
JorgeReyes is an unknown quantity at this point
Re: [FTC]: Alternative to axles? Does hardening work?
I would take a look at using VEX wheels. There are 4 in wheels and and 3.25 in wheels. Then you could use a 1/2 or 3/8 in axles in either round or hex tubing. If you use components from Vex you will never have to worry about things breaking and to me it doesn't seem to hard to implement.
Unread 23-06-2014, 15:14
blockwall2's Avatar
AKA: Adam Blocker
Thanks for the suggestion, and we'll certainly think about it.
Just to clarify:
Typically we haven't had issues with drive wheels/axles, but primarily with any sort of (compound) gearing we have done.
Unread 23-06-2014, 15:54
aklego aklego is offline
FTC #3595 (Schrödinger's Hat)
aklego is just really niceaklego is just really niceaklego is just really niceaklego is just really nice
In our problem area we used 3/8" d-shaft and bushings from McMaster Carr:
http://www.mcmaster.com/#rotary-shafts/=sjbxtn
http://www.mcmaster.com/#standard-sl...arings/=sjc10h
We drilled and reamed the Tetrix axle hubs and they worked pretty well.
Another trick (that we picked up on this forum) is to use flat point set screws:
http://www.fastenal.com/web/products/details/0171675
These help quite a bit when the axle-hub joint is subjected to reversing loads.
let tau = 2pi
Unread 24-06-2014, 09:08
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Purchasing D-shaft is not legal, since the flat makes it a custom machined profile, and only round, square and rectangular profile metal bar material is legal.
You have to buy hardened round shaft and grind (Dremel) the needed flats, for at least the lengths where the screws grip, if not the full length.
We design to avoid, as much as possible, applying any torque through the TETRIX shafts, and to always have both ends of shafts supported when bending forces are present. Bolt the gears together for compound gearing, so the shaft isn't transferring the torque.
When we do transfer torque through TETRIX axles, we try to always double hub them, on both sides of gears or sprockets, so that one single set screw loosening cannot kill the mechanism.
You can use long, Grade 8 10-32 SH cap crews for free spinning shafts. On last years bot we did this for our VEX wheeled, chain driven mecanum drive. The smooth zone of bolt was polished to fit the TETRIX sleeve bearings. Worked extremely well, but length is limited.
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
Unread 24-06-2014, 11:21
Actually, it was asked and answered on the forum and D-shaft from McMaster-Carr is legal:
http://ftcforum.usfirst.org/showthre...ull=1#post7492
let tau = 2pi
Unread 25-06-2014, 21:12
AKA: Dick Ledford
Well this is a turn around from when first I asked that same question a few years ago after our first FTC season demonstrated how horrible the TETRIX axles are. We ended up belt sanding flats on 3/16" solid round hardened stainless steel shafts -- very tedious but totally worth it.
Unfortunately, the McMaster link does not go down to the 3/16" diameter needed to match up with thr TETRIX hubs and bearings, etc. - but other sources do have the needed 3/16" size D-shaft. The 10-32 Grade8 SH Cap Screws do require a a very slight reaming of the TETRIX hubs to fit them, but this only improves the precision of the fit.
Good news & thanks for the update.
-Dick Ledford
Unread 26-06-2014, 11:04
blockwall2's Avatar
AKA: Adam Blocker
I have not been able to find any to save my life. There are quite a few places with d-shafts, but all that I have found do not have the 3/16".
I quite like the idea of reaming the axle hubs and buying the 1/4" or 3/8" axles and bushings from McMaster-Carr though.
Unread 26-06-2014, 18:28
Yeah, the rulings on this one have been rather puzzling. The question was actually asked twice last season and the answers conflicted. The upshot was that McMaster-Carr D-shaft is legal but Servo City D-Shaft, due to a chamfered end, is not. That would sort of make sense except that McMaster-Carr shaft is chamfered as well....
let tau = 2pi
Unread 04-07-2014, 01:39
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
I believe the difference was not just the chamfered end, but that the Servo City ones were cut to specific lengths too. Whereas the McMaster ones were stock length (a couple feet), and you would have to cut the sizes you want yourself.
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
Unread 07-07-2014, 17:03
That was indeed part of the rationale. But McMaster Carr also offers a selection of lengths--6" through 4'. (Admittedly, Servo City has a much greater variety)
My hope is that the wording of the raw materials rule will receive some attention this year. Doing so would (hopefully) remove lots of the clutter from the official forums, reduce confusion for teams and make it easier for the forum moderators. But now I'm way off topic....
let tau = 2pi
