Go to Post "You know you're a robotics kid when you sit on Chief Delphi and hit refresh over and over again waiting for new pictures and videos of other teams" - pwnageNick [more]
Unread 23-06-2014, 15:59
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Xbox Controller
Originally Posted by LFRobotics View Post
Ok AWESOME - now this may seem like a dumb question to you but im a beginner programmer so here it is
How exactly do I extend the Joystick class - I tried it like this:
public class XBox extends Joystick {
but Netbeans doesn't like that
When you say
do you want that in the class and would that just look like
THANKS for all your help!
That is the correct way to extend a class. The compiler is most likely complaining about the missing constructor. Anything that extends the Joystick class is required to have a constructor that calls the Joystick(int port) constructor. So your constructor will look like this inside of your class:
public XBox(int port) {
     super(port);
The super() method will call the super class's (Joystick) constructor.
Unread 23-06-2014, 18:13
LFRobotics's Avatar
LFRobotics LFRobotics is offline
FRC #4623
LFRobotics is on a distinguished road
Re: Xbox Controller
Ok AWESOME now it works just fine.
I tried uploading this https://github.com/MrSTUDofCODE/XBox.../edu/wpi/first code to the robot and it does not work - the button assignments don't work and the joysticks don't work
Here's the output:
ant -f C:\\Users\\Developer\\Documents\\NetBeansProjects\\XBoxBot2014 deploy run
clean:
Deleting directory C:\Users\Developer\Documents\NetBeansProjects\XBoxBot2014\build
Created dir: C:\Users\Developer\Documents\NetBeansProjects\XBoxBot2014\build
Created dir: C:\Users\Developer\Documents\NetBeansProjects\XBoxBot2014\build\classes
[crio-compile] ./src, C:/Users/Developer/sunspotfrcsdk\lib\wpilibj.jar;C:/Users/Developer/sunspotfrcsdk\lib\networktables-crio.jar, C:/Users/Developer/sunspotfrcsdk\lib\squawk.jar -> ./build/classes
Compiling 37 source files to C:\Users\Developer\Documents\NetBeansProjects\XBoxBot2014\build\classes
compile:
preverify:
Created dir: C:\Users\Developer\Documents\NetBeansProjects\XBoxBot2014\build\preverify
Created dir: C:\Users\Developer\Documents\NetBeansProjects\XBoxBot2014\build\preverify.raw.util
[crio-preverify] ./build/classes, , C:/Users/Developer/sunspotfrcsdk\lib\wpilibj.jar;C:/Users/Developer/sunspotfrcsdk\lib\networktables-crio.jar, C:/Users/Developer/sunspotfrcsdk\lib\squawk.jar -> ./build/preverify
Expanding: C:\Users\Developer\sunspotfrcsdk\lib\wpilibj.jar into C:\Users\Developer\Documents\NetBeansProjects\XBoxBot2014\build\preverify
Expanding: C:\Users\Developer\sunspotfrcsdk\lib\networktables-crio.jar into C:\Users\Developer\Documents\NetBeansProjects\XBoxBot2014\build\preverify
jar:
[crio-jar] ./build/preverify, ./resources -> ./build/app.jar
Building jar: C:\Users\Developer\Documents\NetBeansProjects\XBoxBot2014\build\app.jar
suite:
Created dir: C:\Users\Developer\Documents\NetBeansProjects\XBoxBot2014\build\suite
[crio-suite] ./build/app.jar -> ./build/suite/image
CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes
CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt
CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods
[translating suite image [closed: false, parent: squawk] ...]
### Excluding compile: com.sun.squawk.Method::getParameterTypes
### Excluding compile: com.sun.squawk.SymbolParser::getSignatureTypeAt
[Including resource: META-INF/MANIFEST.MF]
[Including resource: META-INF/maven/edu.wpi.first.wpilib.networktables.java/NetworkTablesAzalea/pom.properties]
[Including resource: META-INF/maven/edu.wpi.first.wpilib.networktables.java/NetworkTablesAzalea/pom.xml]
Romizer processed 424 classes and generated 4 files.
Expanding: C:\Users\Developer\Documents\NetBeansProjects\XBoxBot2014\build\app.jar into C:\Users\Developer\Documents\NetBeansProjects\XBoxBot2014\build\suite
Moving 1 file to C:\Users\Developer\Documents\NetBeansProjects\XBoxBot2014\build\suite
Deleting: C:\Users\Developer\Documents\NetBeansProjects\XBoxBot2014\image.suite.api
deploy:
[crio-configure] Configuration files not included in this version of the sdk
[crio-configure] Checking that crio is configured for Java
Host OS: Windows 7 6.1, 6.1
Host JVM: Java HotSpot(TM) Client VM 24.51-b03
Target IP: 10.46.23.2
Network interfaces on host:
    Realtek PCIe FE Family Controller:  address: 10.46.23.5 netmask: 255.255.255.0 <--- on robot's subnet
Connecting FTP @10.46.23.2
[crio-deploy] ./build/suite/image.suite -> 10.46.23.2
Sending local file image.suite
run:
[cRIO] [OTA Server] ********* REBOOTING cRIO *********
[cRIO]
   Waiting for cRIO to reboot (1s)
   Waiting for cRIO to reboot (2s)
   Waiting for cRIO to reboot (3s)
   Waiting for cRIO to reboot (4s)
   Waiting for cRIO to reboot (5s)
   Waiting for cRIO to reboot (6s)
   Waiting for cRIO to reboot (7s)
   Waiting for cRIO to reboot (8s)
   Waiting for cRIO to reboot (9s)
   Waiting for cRIO to reboot (10s)
   Waiting for cRIO to reboot (11s)
   Waiting for cRIO to reboot (12s)
[cRIO]
[cRIO] -> * Loading debug.o: debug
[cRIO] Debugging is up, target server mounted at /tsfs
[cRIO]
[cRIO]
[cRIO]                 VxWorks
[cRIO]
[cRIO] Copyright 1984-2006  Wind River Systems, Inc.
[cRIO]
[cRIO]              CPU: cRIO-FRC II
[cRIO]     Runtime Name: VxWorks
[cRIO]  Runtime Version: 6.3
[cRIO]      BSP version: 1.0/0
[cRIO]          Created: May 23 2013, 16:00:09
[cRIO] ED&R Policy Mode: Deployed
[cRIO]    WDB Comm Type: WDB_COMM_END
[cRIO]              WDB: Ready.
[cRIO]
[cRIO] * Loading nisysrpc.out: nisysrpc
[cRIO] * Loading NiRioRpc.out: NiRioRpc
[cRIO] * Loading nivissvc.out: nivissvc
[cRIO] task 0x18b9b98 (VISA Jungo Init Thread) deleted: errno=196709 (0x30065) status=-1073807360 (0xbfff0000)
[cRIO] * Loading nivision.out: nivision
[cRIO] task 0x1896118 (Service Locator Thread 5) deleted: errno=0 (0) status=0 (0)
[cRIO] NI-RIO Server 13.0 started successfully.
[cRIO] task 0x17a5ee0 (NiRioRpc) deleted: errno=0 (0) status=0 (0)
[cRIO] task 0x1916ba8 (Service Locator Thread 6) deleted: errno=0 (0) status=0 (0)
[cRIO] task 0x1916ba8 (Service Locator Thread 7) deleted: errno=0 (0) status=0 (0)
[cRIO] task 0x1916ba8 (Service Locator Thread 8) deleted: errno=0 (0) status=0 (0)
[cRIO] task 0x13ab7f8 (nisysapi-mDns) deleted: errno=0 (0) status=0 (0)
[cRIO] * Loading visa32.out: visa32
[cRIO] * Loading niserial.out: niserial
[cRIO] * Loading NiFpgaLv.out: NiFpgaLv
[cRIO] * Loading FRC_FPGA_ChipObject.out: FRC_FPGA_ChipObject
[cRIO] * Loading FRC_NetworkCommunication.out: FRC_NetworkCommunication
[cRIO] FRC_NetworkCommunication version: p4-1.4.0a18
[cRIO] FPGA Hardware GUID: 0x1394F6DC1FEB42EC6910E5767ED1D22C
[cRIO] FPGA Software GUID: 0x1394F6DC1FEB42EC6910E5767ED1D22C
[cRIO] FPGA Hardware Version: 2012
[cRIO] FPGA Software Version: 2012
[cRIO] FPGA Hardware Revision: 1.6.4
[cRIO] FPGA Software Revision: 1.6.4
[cRIO] * Loading FRC_JavaVM.out: FRC_JavaVM
[cRIO]
[cRIO]
[cRIO] [OTA Server] Version: 2012 FRC, Jan  5 2012, 17:20:48
[cRIO]
[cRIO]
[cRIO] Welcome to LabVIEW Real-Time 13.0
[cRIO] task 0x1879bd8 (sysapi-rpc) deleted: errno=0 (0) status=0 (0)
[cRIO]
[cRIO] [Squawk VM] Version: 2011 FRC, Nov  5 2011, 14:34:13
[cRIO] FPGA Hardware GUID: 0x1394f6dc1feb42ec6910e5767ed1d22c
[cRIO] FPGA Software GUID: 0xa14c11bde4bb64aef6a86fc52a294cd9
[cRIO] java.lang.IllegalArgumentException: Subsystem must not be null.
[cRIO]     at edu.wpi.first.wpilibj.command.Command.requires(Command.java:173)
[cRIO]     at edu.wpi.first.XBoxBot2014.commands.ReleaseTension.<init>(ReleaseTension.java:17)
[cRIO]     at edu.wpi.first.XBoxBot2014.OI.<init>(OI.java:55)
[cRIO]     at edu.wpi.first.XBoxBot2014.subsystems.Chassis.<init>(Chassis.java:24)
[cRIO]     at edu.wpi.first.XBoxBot2014.commands.CommandBase.<clinit>(CommandBase.java:23)
[cRIO]     in virtual method #109 of com.sun.squawk.Klass(bci=49)
[cRIO]     in virtual method #106 of com.sun.squawk.Klass(bci=328)
[cRIO]     in virtual method #106 of com.sun.squawk.Klass(bci=156)
[cRIO]     in virtual method #105 of com.sun.squawk.Klass(bci=32)
[cRIO]     in static method #25 of com.sun.squawk.VM(bci=4)
[cRIO]     at edu.wpi.first.XBoxBot2014.commands.AUTONOMOUS.<init>(AUTONOMOUS.java:40)
[cRIO]     at edu.wpi.first.XBoxBot2014.XBoxBot2014.robotInit(XBoxBot2014.java:36)
[cRIO]     at edu.wpi.first.wpilibj.IterativeRobot.startCompetition(IterativeRobot.java:72)
[cRIO]     at edu.wpi.first.wpilibj.RobotBase.startApp(RobotBase.java:235)
[cRIO]     in virtual method #10 of javax.microedition.midlet.MIDlet(bci=17)
[cRIO]     at javax.microedition.midlet.MIDletTunnelImpl.callStartApp(64)
[cRIO]     at com.sun.squawk.imp.MIDletMainWrapper.main(110)
[cRIO]     in virtual method #95 of com.sun.squawk.Klass(bci=25)
[cRIO]     at com.sun.squawk.Isolate.run(1506)
[cRIO]     at java.lang.Thread.run(231)
[cRIO]     in virtual method #47 of com.sun.squawk.VMThread(bci=42)
[cRIO]     in static method #3 of com.sun.squawk.VM(bci=6)
[cRIO] java.lang.Error: ExceptionInInitializer: edu.wpi.first.XBoxBot2014.commands.CommandBase:java.lang.IllegalArgumentException: Subsystem must not be null.
[cRIO]     in virtual method #106 of com.sun.squawk.Klass(bci=409)
[cRIO] WARNING: Robots don't quit!
[cRIO] ---> The startCompetition() method (or methods called by it) should have handled the exception above.
[cRIO] edu.wpi.first.wpilibj.networktables2.server.ServerConnectionAdapter@a entered connection state: GOT_CONNECTION_FROM_CLIENT
[cRIO] edu.wpi.first.wpilibj.networktables2.server.ServerConnectionAdapter@a entered connection state: CONNECTED_TO_CLIENT
BUILD STOPPED (total time: 1 minute 20 seconds)
Unread 23-06-2014, 18:28
Flywheel Police
Re: Xbox Controller
Here's the output:
clean:
compile:
preverify:
jar:
suite:
deploy:
run:
[cRIO]
[cRIO]
[cRIO]
[cRIO]
[cRIO]                 VxWorks
[cRIO]
[cRIO]
[cRIO]              WDB: Ready.
[cRIO]
[cRIO]
[cRIO]
[cRIO]
[cRIO]
[cRIO]
In XBoxBot2014.java, you need to move the instantiation of your AUTONOMOUS command below the initialization of CommandBase. Since CommandBase hadn't been initialized prior to creating a command all of your subsystems hadn't been set up yet.
Unread 23-06-2014, 19:08
LFRobotics's Avatar
FRC #4623
Re: Xbox Controller
Ok I think I fixed that - here's https://github.com/MrSTUDofCODE/XBox.../edu/wpi/first the updated code
But it still shows an error:
clean:
compile:
preverify:
jar:
suite:
deploy:
run:
[cRIO]
[cRIO]
[cRIO]
[cRIO]
[cRIO]                 VxWorks
[cRIO]
[cRIO]
[cRIO]              WDB: Ready.
[cRIO]
[cRIO] task 0x18beed8 (Service Locator Thread 5) deleted: errno=0 (0) status=0 (0)
[cRIO] task 0x17531c8 (NiRioRpc) deleted: errno=0 (0) status=0 (0)
[cRIO] task 0x193a2c0 (VISA Jungo Init Thread) deleted: errno=196709 (0x30065) status=-1073807360 (0xbfff0000)
[cRIO] task 0x19e14f0 (Service Locator Thread 6) deleted: errno=0 (0) status=0 (0)
[cRIO] task 0x19e14f0 (Service Locator Thread 7) deleted: errno=0 (0) status=0 (0)
[cRIO] task 0x19e14f0 (Service Locator Thread 8) deleted: errno=0 (0) status=0 (0)
[cRIO] task 0x13c2300 (nisysapi-mDns) deleted: errno=0 (0) status=0 (0)
[cRIO]
[cRIO]
[cRIO]
[cRIO]
[cRIO] task 0x17ae568 (sysapi-rpc) deleted: errno=0 (0) status=0 (0)
[cRIO]
[cRIO]     in static method #24 of com.sun.squawk.VM(bci=4)
[cRIO]     at edu.wpi.first.XBoxBot2014.commands.CommandBase.init(CommandBase.java:0)
Unread 24-06-2014, 07:54
Flywheel Police
Re: Xbox Controller
In your Chassis subsystem you have an OI declaration, remove it.
FYI, your XBox class looks perfect.
I have also attached my version of the XBoxController and PS4Controller classes for anybody out there that would like to use them. We are working on creating a utilities library and will post it later. I have not tested the mappings on a robot yet, so if you notice anything that is not mapped correctly when you use it please let me know.
Unread 24-06-2014, 10:57
LFRobotics's Avatar
FRC #4623
Re: Xbox Controller
Ok AWESOME - thanks the robot works like a CHARM!
