Go to Post I approve of this misuse of machinery! - RoboChair [more]
Unread 24-06-2014, 10:09
burde1jb's Avatar
burde1jb burde1jb is offline
FRC #4327 (Q Branch)
burde1jb will become famous soon enough
Help with Relay Code in Labview
I'm attempting to fix a red dot of trouble in our Teleop code. As seen in the attached picture of the code [BOTTOM RIGHT], we are using Button 3 of the controller to send the Spike Relay into the forward position (we used a numerical value of "2" because we could not pull up the Enum Constant which provides forward/reverse/on/off, but that is another section of help...).
Sending the two values through the T/F gate and onto the Relay Set, we get that little red dot which we know from past experience does not mean anything good. Any advice as to how to fix the issue would be appreciated. Thanks!
Unread 24-06-2014, 10:50
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Re: Help with Relay Code in Labview
You're getting a red dot becuase the data types do not match. you can fix this by using the enumerated type def the relay uses instead of floats.
(From memory, may be wrong on some things)
Step one: Delte wire to relay set port, the '0', and '2' on the T/F gate
Step two: Right click on the relay set port and click "create constant"
Step one: Delte wire to relay set (but not the new constant)
Step three: Copy this variable and wire up one each to the inputs of the T/F gate
Step four: Rewire T/F gate to relay set port
Step five: Left click on the constants to set them to the status you want. This should bring up a drop down menu giving "off/forward/revers/on" as options. This should not select the constant for movement around the screen.
Unread 24-06-2014, 11:11
burde1jb's Avatar
Good memory! Worked as you said. Thanks so much!
Unread 24-06-2014, 11:12
Aren Siekmeier's Avatar
on walkabout
The red dot just means that a data type cast is taking place. You are providing values with double precision float point type (coloured orange in LabVIEW), but the Relay Set VI is looking for an enum constant of the appropriate type (which is really just a relabeling of a uint of some sort - mapping one label to 0, another to 2, as you've done in your code). Assuming 0 and 2 are the values you want (couldn't help you here, you'll have to check this in LabVIEW - see below), the code will correctly cast your float types to uint types, and it should work fine.
However, the proper way to do this is, of course, to use the enum constants. As adciv pointed out, you can access the enum type by right-clicking the terminal on the Relay Set block, and selecting "Create Constant." Furthermore, if you right-click the enum constant and on the context menu select "Edit Items," you'll see the label-to-uint associations I mentioned above.
