Go to Post During the day on Thursday, I had to change costumes a few times, being "Andy the inspector", to "Andy the green power ranger drive coach", to "Andy the President of AndyMark, meeting with companies". I am sure some people in the guys' bathroom were wondering what I was up to. - Andy Baker [more]
Unread 24-06-2014, 10:59
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Re: Pneumatics system code
Ok, to do some quick troubleshooting:
First, for my sanity, please add brackets
// Solenoid
if (mainStick.getRawButton(1))
   spike.set(Relay.Value.kForward);
else {
  if (mainStick.getRawButton(2))
   spike.set(Relay.Value.kReverse);
If problem persists, comment out the code and use only
If the spike LED is not solid Green, you have a wiring issue. Either your wire is bad or the spike is on the wrong port. If that does work, it becomes a code issue.
Unread 24-06-2014, 11:19
Team 4939 Team 4939 is offline
AKA: Anshul Shah
FRC #4939 (All spark 9)
Team 4939 is an unknown quantity at this point
"If the spike LED is not solid Green, you have a wiring issue. Either your wire is bad or the spike is on the wrong port. If that does work, it becomes a code issue."
We tried switching all the wires, but not change in the light.
Here is the updated code:
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.Relay;
public class RobotTemplate extends SimpleRobot {
    RobotDrive chassis = new RobotDrive(1,2);
    Joystick mainStick = new Joystick(1);
    Jaguar jaguar = new Jaguar(3);
    Jaguar jag = new Jaguar(4);
    Compressor compressor = new Compressor(1, 1);
    Relay spike = new Relay(4);
    public void robotInit() {
        compressor.start();
    public void autonomous(){
        chassis.setSafetyEnabled(false);
        chassis.drive (-0.5, 0.08);
        Timer.delay(2.0);
        chassis.drive (0, 0.0);
    public void operatorControl() {
        chassis.setSafetyEnabled(true);
        while (isOperatorControl() && isEnabled()) {
            double speed = mainStick.getY();
            double rot = -mainStick.getX();
            chassis.arcadeDrive (speed, rot);
            if (mainStick.getRawButton(3)){
                jag.set(1);
                jaguar.set(-1);
            else if (mainStick.getRawButton(4)){
                jaguar.set(-1);
                jag.set(1);
            else{
                jaguar.set(0);
                jag.set(0);
            // Solenoid
            {if (mainStick.getRawButton(7))
                spike.set(Relay.Value.kForward);}
Unread 24-06-2014, 11:27
One Eyed Man
Did you try it without any case statements around the relay set? I'm trying to remove the controller from this as well.
        compressor.start();
        Timer.delay(2.0);
            // Solenoid
Unread 24-06-2014, 11:36
AKA: Anshul Shah
I tried it with the new code that you posted but that did not work out either. No change in light on the spike or change in the system
Unread 24-06-2014, 11:38
Aren Siekmeier's Avatar
on walkabout
In this pic it looks an awful lot like the PWM cable into the Spike is backwards. Make sure the black wire is near the "B" on the casing. Also check the Digital Sidecar end of this wire, to make sure Black lines up with (-) (Red with + and White with SIG).
Edit: According to your code, it should be in Relay output 4. Also note: the socket in Spikes and Victors can be a little funny - make sure the connector is properly and snuggly seated all the way down into the socket.
The solid orange light on the spike means it's being commanded to do nothing, which is certainly the case if there is no proper signal coming in.
Unread 24-06-2014, 11:41
One Eyed Man
No I'm becoming puzzled. Can you check your digital Side Car to ensure all lights are operating correctly
http://wpilib.screenstepslive.com/s/...tem-components
Are you able to control the drive motors?
Unread 24-06-2014, 11:57
on walkabout
I looked again at that picture. Definitely a wiring issue.
1. Your double solenoid valve is wired incorrectly. Each end of the valve is one solenoid, each of which has a red wire (+, positive) and a black wire (-, negative). Make sure these wires are connected to the spike exactly as shown in this diagram. Right now you are doing something totally different with those wires, which wouldn't work even if the Spike were working properly (it's not, due to 2 below). You should have a red wire on each of the M+ and M- terminals on the spike, and then both black wires should connect to the GND terminal on the Spike.
2. As I posted above, ensure all PWM cables (for lack of a better name - the grouped black, red, and white wires) are inserted in the right direction. In general: B means black; (-) means GND which is always black (or maybe brown or blue ... ) + means hot which is always red, and SIG is signal which is usually white.
Unread 24-06-2014, 11:58
AKA: Anshul Shah
Ya all the motors are working.
Here is a pic of the sidecar at the moment:
http://i58.tinypic.com/ohrara.jpg
The relay lights don't seem to be steady or blinking, but everything else seems to be fine.
I also changed the port to 7 for the spike on request of my team.
    Relay spike = new Relay(7);
        compressor.start();
        Timer.delay(2.0);
            // Solenoid
Unread 24-06-2014, 12:15
One Eyed Man
If I'm seeing that right, I think I found the issue. The Spike must be plugged into the Relay Ports on the Side Car. You have it plugged into the PWM ports.
Unread 24-06-2014, 12:21
AKA: Anshul Shah
I rewired the solenoid and spike to the way that was suggested, and we checked the PWM cables and still no fix, the light is still red.
Could it maybe be the code? Can someone check that and reply back.
Unread 24-06-2014, 12:24
One Eyed Man
Red or Orange? If Red, that means it's working (and the colors in the guide I consulted were backwards).
Unread 24-06-2014, 12:26
AKA: Anshul Shah
We plugged the spike into the Relay ports. But the light is still orange in the spike. Any suggestions
Unread 24-06-2014, 12:30
AKA: Anshul Shah
When we connect the spike to the Digital I/O the solenoid lights up, but the spike's lights turn off.
Unread 24-06-2014, 12:46
AKA: Anshul Shah
When we put it into the Digital I/O and we move the wire around the light on the spike changes from green, to orange, to red for 2 seconds, and when we push the wire in all the way the spike has no color. And all this is without me turning on the driver station. The spike does not work when we plug in to the PWM section, or the relay section of the sidecar. We don't know where to go from here. Any help would be appreciated.
Unread 24-06-2014, 12:49
One Eyed Man
It needs to be plugged into the Rleay section. Lets go from there. By plugging it into the DIO, you're setting it to reverse, as the reverse pin in the Spike is getting the 5V from the DIO. Lets try setting it to reverse in code while it's on the relay panel.
            // Solenoid
