Go to Post Then there's the electronics, pneumatics, and all that stuff on top that will magically make the ball score billions of points. That will add up to a lot of weight. - MrForbes [more]
Unread 24-06-2014, 15:32
ferrari77 ferrari77 is offline
FRC #2583
ferrari77 is on a distinguished road
Addressable LED lights without Arduino
I am looking to purchase multicolor addressable LED lights, the type that can be controlled by an Arduino or similar board, however I would like to have the option to use the LED strip in one color without controlling it frmo a board.
I know that there are LED strips that plug directly into a power source and light up as one color but is there a way to have the option to either go directly into a power source or use an Arduino with the same strip?
I am thinking of a strip like this but with the option to be a single color
http://www.adafruit.com/products/306
I can clarify if needed
Thanks
Unread 24-06-2014, 15:54
foote stepped in
AKA: E. Foote
FRC #0868
Re: Addressable LED lights without Arduino
Could you explain what you want to accomplish? Why do your LED's need to be individually addressable?
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 24-06-2014, 16:05
FRC #2583
Purely decoration purposes.
I have not decided if i want the strip a solid color such as all blue and power it without a board or if I want multicolor/changing colors/flashing that is controlled through a boardso I am asking if there is one strip that I can buy that has the option to do either.
Unread 24-06-2014, 16:11
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
I think what you're asking for is more along the line of a regular RGB LED strip such as this one (also with remote for $3 more here). You can power each RGB LED color with an independent 0-4V signal, mixing the colors will result in a emitted color for the entire strip (cut to length). You could build a small power circuit and trigger power to the lights with a mosfet.
Unread 24-06-2014, 16:12
foote stepped in
AKA: E. Foote
FRC #0868
Are you looking to have the LEDs change colors individually (such as 10 LEDs in your strip, 5 are blue and 5 are white simultaneously), or just the entire strip at a time (10 LEDs, all one color which can change)?
The way the product you linked works, you'll need the microcontroller regardless of what you want. However, there are other simpler products which will do the latter with basically a power supply.
Unread 24-06-2014, 16:19
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
This is what our team did using the controller provided (the $3 more). To take it a step further we hijacked the PWM lines in the controller itself and fed those straight to the cRIO digital I/O (set to PWM mode) which allowed us to control the color of the entire strip at run time without any extra processor board.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
