Go to Post I looked at it and originally thought it was a crazy idea... then I looked at it again and it still sounds like a crazy idea. - Yipyapper [more]
Unread 24-06-2014, 21:30
Team 4939 Team 4939 is offline
AKA: Anshul Shah
FRC #4939 (All spark 9)
Team 4939 is an unknown quantity at this point
Re: Pneumatics system code
Any help with this issue would be greatly appreciated.
Also my team is pressuring me to re-check the code, because they think that is the case.
Here is the current code that I am running:
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.Relay;
public class RobotTemplate extends SimpleRobot {
    RobotDrive chassis = new RobotDrive(1,2);
    Joystick mainStick = new Joystick(1);
    Jaguar jaguar = new Jaguar(3);
    Jaguar jag = new Jaguar(4);
    Compressor compressor = new Compressor(1, 1);
    Relay spike = new Relay(7);
    public void robotInit() {
        compressor.start();
    public void autonomous(){
        chassis.setSafetyEnabled(false);
        chassis.drive (-0.5, 0.08);
        Timer.delay(2.0);
        chassis.drive (0, 0.0);
    public void operatorControl() {
        chassis.setSafetyEnabled(true);
        while (isOperatorControl() && isEnabled()) {
            double speed = mainStick.getY();
            double rot = -mainStick.getX();
            chassis.arcadeDrive (speed, rot);
            // Solenoid
                spike.set(Relay.Value.kReverse);
If somebody could please check over this code?
Unread 24-06-2014, 22:48
Domenic Rodriguez's Avatar
Domenic Rodriguez Domenic Rodriguez is offline
FRC #0316 (LuNaTeCs)
Domenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura about
This line...
compressor.start();  // Relay port 1
...and this line...
spike.set(Relay.Value.kReverse);  // Relay port 7
...should be activating the green LED for Relay 1 and the red LED for Relay 7 on the Digital Sidecar when the robot is enabled in teleop mode. They should turn on regardless of whether Spikes are connected or not. If the LEDs are not activating and you are not measuring any voltage off of these ports, then my conclusion is that there is an issue with either your digital sidecar or the cable connecting it to your cRIO. The code looks fine to me, and it compiles without error in NetBeans.
LuNaTeCs - Learning Under Nurturing Adults Teaching Engineering Concepts and Skills - Small and Mighty!
FRC 316 LuNaTeCs - Student (2011-2014), Lead Programmer (2011-2014), Team Captain (2013-2014), Operator (2013), Drive Coach (2014), Mentor (2015-????)
'11 Philly Regional Finalists, '13 Chestnut Hill Finalists, '13 Lenape Champions, '13 Archimedes Division, '14 Chestnut Hill Champions, '14 Lenape Champions
FTC 7071 EngiNerds - Founding Advisor (2013-2014) | FRC 5420 Velocity - Founding Advisor (2015)
Grove City College Class of '18, Electrical/Computer Engineering (B.S.E.E)
