Go to Post We have donut eating contests to see who has the best legs. We paint our pigs. We argue about which time zone we are in. About 400,000 of us gather together to watch cars go around in a circle. We also build robots.Yep, our cultural norm is a bit different. - Andy Baker [more]
Unread 11-01-2002, 22:50
AWiser's Avatar
AWiser AWiser is offline
AWiser is an unknown quantity at this point
Send a message via AIM to AWiser Send a message via Yahoo to AWiser
Question Controller System Testing
What would be a good design for testing the Robot Controller and Operator Interface with some of the parts while using the Default Program Code? I would appreciate it if you could be specific so that I would know just what it is that I'm doing.
Thanks!
~Alex Wiser~ <Team #846 (Lynbrook)>
There are three kinds of people in the world:
Those who can count...
and those who can't
Unread 12-01-2002, 01:20
AWiser's Avatar
*sniff* nobody likes me...
WAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!
and those who can't
Unread 12-01-2002, 10:36
zorro zorro is offline
#0292 (PantherTech)
zorro is an unknown quantity at this point
Send a message via AIM to zorro
The easiest way would be to wire a speed controller to PWM1. Hook any of the larger motors up to the output of this controller. Then plug in a joystick to port 1 on the operator interface. The y-axis will control the motor in the default code. Be sure you follow wiring guidelines as stated in the manual. If you are just testing, you can bypass the 60A circuit breaker for now. Wire the battery to the fuse block. Attach the robot controller and speed controller to the fuse block. Make sure the polarity is right, or you might see some magic smoke.
If you have any questions, just reply to this message.
Greg Szorc
gregszorc@cwru.edu
Unread 12-01-2002, 18:39
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Slap a chassis together NOW...
In my opinion, you need to have some sort of rolling stock to get your foot in the water.
Making a quickie chassis gives you a lot of good things. It gives your drives something to practice driving -- even if the real deal will be different. It gives you some practical experience with the forces involved in a drive system (how much damage tension in the chain can cause, how hard it is to hold those nasty drill cases, etc.). It gives your wiring folks practice writing things up (and perhaps it will make them see the sense of spending time making wiring neat, orderly and well documented). Finally, it helps you really understand where Tab A fits into Slot B, i.e. how the Innovation First stuff all goes together.
Bottom line: Build a chassis. NOW.
Joe J.
Unread 12-01-2002, 22:23
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
One thing to make sure of: don't plug the battery into the motor end of a spike. White smoke will result (and your mentors will get pretty mad at you).
Zan Hecht
Unread 12-01-2002, 22:37
smokescreen smokescreen is offline
FRC #2360 (POWERStorm)
Team Role: Photography
smokescreen is on a distinguished road
spikes
This may not be a problem anymore, but if you have some of the older spikes (red i think. or was it blue?) make sure not to hook the power up backwards.
If memory serves (many times it doesn't), the spikes are not polarity protected as the victors are.
-smokescreen
No! Don't let the MWS out!
Unread 13-01-2002, 00:23
fs_2002's Avatar
fs_2002 fs_2002 is offline
#0804 (TeamMetamorphisis)
fs_2002 is an unknown quantity at this point
Send a message via ICQ to fs_2002 Send a message via Yahoo to fs_2002
May i just suggest that you use the breaker for a quick power kill... someone created a dead short buy connecting a wire wrong and we melted the insulation off our wires today
~Bobb
Team 804
"Fundrasing?!? CHILDREN????? AHHHHH!!!!"
"The Pants command me!! Do not ignore the rubber pants!"
"Word up kids, This is POOP DOG!!!"
"I MUST HAVE TACOS!!!!!"
Unread 13-01-2002, 01:05
Andrew Wyatt Andrew Wyatt is offline
#0524 (Alpha Omega Robotics)
Andrew Wyatt is an unknown quantity at this point
Send a message via AIM to Andrew Wyatt
control system testing
the very first thing the control system team does when we get the kit every year is grag out all of the electrical stuff and mount it on a piece of plexiglass and then wire everything up.
this setup holds everything in position so we don't have to worry about the componenets shifting around and causing shorts and also allows us to test every component before putting it on our robot.
I'll have pictures soon.
There are only two tools you really need: duct tape and Wd40. if it moves and it shouldn't, use the tape. if it should move and doesn't, use the wd40.
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
control system worth more than $500 archiver 2001 8 24-06-2002 02:00
New Innovation FIRST control system and the dashboard archiver 2000 0 23-06-2002 22:15
Control System Power Al Skierkiewicz Technical Discussion 0 25-03-2002 09:04
