Go to Post Also, the judges don't give out awards for money. They give out awards for hard work and effort. - BigJ [more]
Unread 23-06-2014, 23:12
cxcad cxcad is offline
FRC #1683 (Techno Titans)
cxcad will become famous soon enoughcxcad will become famous soon enough
254 Shockwave questions
My team is currently looking at building a t-shirt cannon, and no surprise we are looking at arguably the greatest of them of all. From their build blog, we have gained much valuable information, but we still have a few questions?
  • How does 254 roll their shirts? 2.375 ID seems really small. Why not the ranger roll?
  • 200 shirt capacity, isn't that excessive and expensive? Or is it for the convenience of not charging the air tanks all the time?
  • How difficult is it to add a rotating barrel? How is the barrel mechanism sealed to the air hose interface? Any closeups?
Thanks.
Unread 24-06-2014, 00:54
Torrance's Avatar
Torrance Torrance is offline
AKA: Andrew Torrance
Torrance has much to be proud ofTorrance has much to be proud ofTorrance has much to be proud ofTorrance has much to be proud ofTorrance has much to be proud ofTorrance has much to be proud ofTorrance has much to be proud ofTorrance has much to be proud ofTorrance has much to be proud of
Re: 254 Shockwave questions
We roll our T-shirts by simply folding the sleeves/edges up to the collar and then rolling from the collar down to bottom edge. We typically use 1-2 rubber bands to hold the shirts together. While this is not the most compact way to roll a shirt, they end of pretty small and also don't fly like bullets, making them a lot safer to shoot.
We tried to have such a large shot capacity purely for ease of maintenance. We will typically go to 2 or more outreach events with Shockwave before we have to take it back to a scuba shop for re-filling.
The large block in the back that holds the globe motor and a pneumatic cylinder for rotating/indexing was the most complex part on the robot. However, we found that a rotating barrel is simpler is better at managing the indexing of the shirts that a linear magazine.
There is no special sealant between the block and the barrels. The block simply has a conical-shaped output that lets the air through a polycarbonate plate that the back of the turret slides nearly flush against.
Hope that helps!
Unread 24-06-2014, 12:12
Hope that helps!
Thanks a lot! That's a lot of t-shirts per a year. How do you guys keep the costs down?
Unread 24-06-2014, 12:21
Anthony4004's Avatar
Anthony4004 Anthony4004 is offline
Anthony4004
FRC #4004 (MARS Rovers)
Anthony4004 is an unknown quantity at this point
You can look at shooting sponsor t-shirts. For team 4004, Buffalo Wild Wings in our area gives us free shirts for promotion, so we shoot them off with team shirts.
Unread 24-06-2014, 12:35
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Our football team booster club provides us Tee shirts from their sponsors. They also give us a small stipend. It is kinda of neat that the football jocks help sponsor the geeky robot team.
A lot different than way back when I was in high school.
Unread 24-06-2014, 14:13
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
As mentioned above, we shoot sponsor provided t-shirts usually. We rarely shoot shirts purchased with team funds, as that is cost prohibitive as you noted.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 24-06-2014, 22:58
What is done with the second stage of the regulator? And how is the first stage modified to fill a reservoir tank?
Unread 25-06-2014, 13:16
Engineering Mentor
FRC #0254
There are two regulators. One regulator is mounted on the scuba tank itself, which regulates the ~3000 psi air down to around 150psi. That air is used to fill the secondary scuba tank which the main shooting valve is hooked up to. The secondary regulator is used only for the pneumatic functions of the cannon, which is primarily just the indexing mechanism.
When the scuba tank is depleted, it gets removed and filled at a local scuba shop. We do not have the capability to fill the scuba tank at our school or lab. High pressure compressors are extremely expensive.
-Travis Covington
Unread 25-06-2014, 14:18
JohnFogarty's Avatar
AKA: @doctorfogarty
What valve do you use for the firing?
I figure you're not using a PVC sprinkler valve like most people use.
John Fogarty
Unread 25-06-2014, 14:26
Engineering Mentor
FRC #0254
Most of this information has been on our website since we unveiled Shockwave in 2010.
http://team254.com/shockwave
Hope this helps!
-Travis Covington
Unread 25-06-2014, 18:30
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Hope this helps!
Was anyone else suprised at how old shockwave is now? It seems like only a couple of months ago that I was picking my jaw up off the floor...
Oh wait, that ws Championship and a different incredibly awesome poof bot.
On a side note, anychance of a 2014 gatlin style corndog launcher at IRI?
http://www.youtube.com/watch?v=aW-ljrm7a6g
Sticks removed for safety of course....
Unread 25-06-2014, 19:03
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
Would it be particularly difficult to control a MAC solenoid valve using the cRIO? I've looked at them before, but they seem pretty advanced.
Unread 25-06-2014, 19:20
Engineering Mentor
FRC #0254
Nothing fancy. Feed it 12 volts for as long as you want it open. We use a VEX controller. A cRio is more than sufficient to do that. You could use an RC controller if you wanted.
-Travis Covington
Unread 07-07-2014, 17:30
glennword's Avatar
glennword glennword is offline
Resident Solidworks Guru
AKA: Glenn
FRC #4146 (Sabercat Robotics)
Team Role: Student
glennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to behold
any chance of a part number for that mac valve?
"Whether you think you can, or you think you can't--you're right."
-Henry Ford
Unread 07-07-2014, 17:56
NickE's Avatar
NickE NickE is offline
_
57D-13-601BA
