Go to Post We are behind you 100% (more if needed)! - Clem1640 [more]
Unread 26-06-2014, 12:04
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
Re: Electrical Connections
Originally Posted by tim-tim View Post
Here is a link to some of the Anderson Power Connectors we have used. You can order new pins (contacts) and reuse the cases on wires no longer being used to help offset costs for future builds.
The crimper that we use for these connectors is a great one.
You can also connect the blocks in such a way that they only fit in one orientation instead of using different color cases. This eliminates the "need" for stocking different color cases.
I just copied tim-tim's post from a previous thread since it is exactly what will help you out!
Using D-sub connections is also a great way for connecting sensors!
