Go to Post And then the judges joined in and did the wave! - Basel A [more]
Unread 26-06-2014, 11:36
RKazmer RKazmer is offline
FIRST Volunteer
AKA: Richard Kazmer
FRC #2363
RKazmer is on a distinguished road
Electrical Quick Connections for Large Amounts of Wire
Over the past two years, the robot our team builds has had two main pieces: drive train and mechanisms that go on top of the drive train. However, the system for connecting all of the pieces together has always been a massive bundle of wires going up and down a main strut. This means that to take off a component from the mechanism, a massive bundle of wires needs to come undone, and subsequently, redone.
I have seen a lot of teams that use other types of connectors, but I do not know how to start implementing this process. The main question: What are some of the main ways to connect electronics for ease of disassembling and reassembling the robot?
Unread 26-06-2014, 12:04
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
Re: Electrical Connections
Originally Posted by tim-tim View Post
Here is a link to some of the Anderson Power Connectors we have used. You can order new pins (contacts) and reuse the cases on wires no longer being used to help offset costs for future builds.
The crimper that we use for these connectors is a great one.
You can also connect the blocks in such a way that they only fit in one orientation instead of using different color cases. This eliminates the "need" for stocking different color cases.
I just copied tim-tim's post from a previous thread since it is exactly what will help you out!
Using D-sub connections is also a great way for connecting sensors!
Unread 26-06-2014, 12:30
FIRST Volunteer
AKA: Richard Kazmer
FRC #2363
Thanks. I was looking into using a 50-pin connector for all of the PWM wires instead of making two separate PWM wires that connect in the middle. Would that be the same process as making a ribbon cable?
Unread 26-06-2014, 13:35
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
This sounds messy. Do you have a specific use case where you will need to connect/disconnect all your sensors/pwm devices at once? If not, I would just take the standard route for PWM.
EDIT: nvm, misread. I would just get the larger housings (1x12?) on hansen hobbies for structure to structure connections.
http://www.hansenhobbies.com/product...ools/crimp_ec/
http://www.hansenhobbies.com/product...vo/sw_dx22_fu/
http://www.hansenhobbies.com/product...tors/pt1in_ft/
http://www.hansenhobbies.com/product...tors/pt1in_mt/
http://www.hansenhobbies.com/product...ors/pt1in_1x3/
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 26-06-2014, 13:59
protoserge's Avatar
One of the best connection choices would be to use a D-sub connector. Here is an example that you can solder to (make sure to look at the pin count and not use the photo - we've used a 53 pin connector with a great result). You would then select a male end to mate up.
Here are some photos of our 2012 robot, Frizz Bee. These photos show how the entire electronics board can be dropped. I wasn't able to readily find photos of the shooter assembly removed, but the shooter was attached by the D-sub connector and could be interchanged/removed by one plug for sensors and another pair of APP for the shooter motor.
BEES6944 by FRC Team 836, The RoboBees, on Flickr
BEES6917 by FRC Team 836, The RoboBees, on Flickr
BEES6974 by FRC Team 836, The RoboBees, on Flickr
MattInAHat's Avatar
MattInAHat MattInAHat is offline
I disassemble dryers.
AKA: Matt Cukier
FRC #3620 (Average Joes)
MattInAHat is an unknown quantity at this point
Exactly this. Andersons are the way to go. Plus if you want to get creative there's different colors of Andersons, they're easy to label, and it makes connecting motors and motor controllers an absolute breeze.
Another benefit of Andersons is that you can connect them to each other to organize positive and negative polarities.
And then you can connect those connections into an even bigger block for more ease of access.
tl;dr--Andersons are the best thing since sliced bread.
Unread 26-06-2014, 16:04
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Besides connectors, there is a number of other things you can do to pretty up your wiring.
  • Using fused wiring for the power runs helped my team substantially. Since power wires for each motor are stuck together, they were easier to route together and they look very nice. (might post pictures later)
  • This season, my team used the harness environment in Inventor to lay out all our power and signal runs before constructing the bot. This not only allowed us to make a very organized design, but it took less time to wire the competition bot and the practice bot than it did to wire just the competition bot last year.
  • Wire sleeve is extremely helpful for keeping lots of small wires (i.e. solenoid and PWM) together, and it can help protect wires from damage.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
