Go to Post The great thing about liking someone in your robotics team is that they've already seen you at your worst, and you cant shock them with ANYTHING anymore :D - SCROSSLEY-GCEC [more]
Unread 26-06-2014, 14:41
JorgeReyes JorgeReyes is offline
Team Captain
FRC #2002 (Tualatin Robotics)
JorgeReyes is an unknown quantity at this point
Difference Between Dog Shifting and Ball Shifting
Can someone clarify between the two. I understand dog shifting but not ball shifting. I will be designing a custom 2 speed gearbox this summer with 3 Cims. Which shifting option is more reliable and is more compact. Pros/Cons?
Unread 26-06-2014, 15:30
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Difference Between Dog Shifting and Ball Shifting
This is what the innards of a Ball Shifter look like
You have a series of steel ball bearings which ride in holes in the shaft. The gears, which all freespin on the shaft by default just like in a dog shifter, have circular pockets cut into their bore, which line up with the holes in the shaft. A plunger with a variable diameter rides inside of this shaft. As it moves, the wide part of the plunger forces the ball bearings upward, such that they poke out of the holes and engage the pockets of the gear.
Here's a video that shows how it works: https://www.youtube.com/watch?v=D7ng4OWilUY
Ball shifters can be more compact than Dog shifters in certain circumstances, because they do not require space between gears for the dog to ride. Good dog shifter design can minimize this though, with a first stage reduction that rides in between the second stage reductions. Ball shifters are also generally the best choice for transmissions with more than two speeds, since one multi-position plunger can control any number of ratios. In my experience, Ball shifters can be less reliable, since they depend on exact positioning of the plunger, whereas a dog shifter has a hard stop at each end of the dog's travel. Properly used, the VEX ball shifter components shouldn't give you any trouble here. Also, ball shifters are somewhat more daunting to custom fabricate the components for, as there are a whole bunch of factors to consider in order to get proper engagement and proper free-spinning behavior on demand. Tolerances are critical. I'd definitely recommend playing with the VEX ball shifter to get a feel for how it works.
Unread 26-06-2014, 15:40
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
A dog shifter uses a dog gear to shift.
A pneumatic cylinder pushes this gear into corresponding slots on the actual output gears and when it engages the force is transferred through it into the output shaft. When not engaged the output gears just spin on bearings. I would take a look at wcp's dog shifter CAD to see exactly how this works. Ball shifters work similarly, however they use 3 ball bearings and a plunger instead of a dog. I personally would design a dog shifter first as, at least for me, is simpler to understand and fix.
Last edited by Bryce Paputa : 26-06-2014 at 15:45. Reason: got rid of huge picture, cd should make it easy to re-size them inside a post
Unread 26-06-2014, 21:10
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
Going off this,
If you decide to pursue a ball-shifter, and aren't confident in your understanding it. I would recommend buying the vex-pro ball-shifter part and using it as a starting point for future iterations. The Vex-Pro piece is quite good for a COTS part, but there are many aspects of it that can be improved upon.
Note that *generally* dog-shifters require more force to shift, whereas a ballshifter is easier to shift.
Also, if this is going to be your first custom gearbox (I don't know if it is), it may be simpler to attempt a single-reduction 3-CIM gearbox. This way the gearbox becomes simpler to design and assemble, reducing the risk of error.
(2015-?): 973
(2012-2015): 955
