Go to Post Surely any group of rational human beings (which FIRST seems to attract) can work this out. - Billfred [more]
Unread 27-06-2014, 07:41
weaversam8 weaversam8 is offline
Team Captain
AKA: Sam Weaver
FRC #4534 (Wired Wizards)
weaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to behold
Question Legality On Expansion Boards for the RoboRIO
Hey guys,
I have read the rules about this a few times, but they never seem to stick in my head. The new RoboRIO control system is coming out for the 2015 season, and with it, support for a new feature called expansion boards.
http://sine.ni.com/nips/cds/view/p/lang/en/nid/211702
Expansion boards are protoboards that plug into a port on the RoboRIO. My question is:
Can I buy these boards and build custom circuits on them before season?
When I build these circuits, is it legal to use them on the robot even though they were constructed before season?
Can I use programming created before kickoff to use the expansion boards?
Thanks for the help CD!
Unread 27-06-2014, 07:45
Gdeaver Gdeaver is offline
FRC #1640
Re: Legality On Expansion Boards for the RoboRIO
Good Question. Our team will need access to several of the pins on the port. If we make an adapter board before kick off, is it legal?
Unread 27-06-2014, 08:51
foote stepped in
AKA: E. Foote
FRC #0868
Yes, I'd expect that would be a good learning experience.
R13
ROBOT elements created before Kickoff are not permitted. ROBOT elements, including software, that are designed before Kickoff are not permitted.
Exceptions include the following:
A. BUMPERS,
B. OPERATOR CONSOLE,
C. battery assemblies per R5-A, and
D. software and designs with source files publicly available prior to Kickoff.
Per 2014 R13D, you could not use the circuit, and you can only use the code if make your code publicly available.
These are the 2014 rules, the 2015 rules are going to be different (this rule has a good chance of remaining the same).
I'd recommend doing that still as it will be a worthwhile learning experience, and your learning will carry over to the build season.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
Unread 27-06-2014, 09:00
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
I would hold off making concrete plans about the expansion port until a later date. We had a discussion about the boards at alpha. More specifically, we talked about safety, inspection, and possible safety certification. First needs to work out a comprehensive plan on how they plan on handling them.
