Go to Post The robot is talking to you, you must listen to find out what might be wrong. - Al Skierkiewicz [more]
Unread 30-06-2014, 17:07
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
pic: New serve mk.1-2517
Unread 30-06-2014, 18:39
Tyler2517's Avatar
ShortOnes
AKA: Tyler Gibb
Re: pic: New serve mk.1-2517
http://imgur.com/a/H6Qcm
Unread 30-06-2014, 19:05
magnets's Avatar
magnets magnets is offline
That's a really neat swerve drive. I don't think anyone's done something like this before.
A few questions/comments-
I'm assuming the really big green thing that goes in the middle of the wheels is a bearings. If not, what is it? If so, why is it so big?
Those bevel gears- where are they from? Are they strong enough? They're at the end of the reduction so they're going to try really hard to get away from each other. The little one is going to push up so you'll probably want a thrust bearing/washer there too.
The green angle to support the sides has the mounting holes too close to the edge. Making it a little bit wider around the bolt holes is cheap strength.
How is torque transferred between the bevel gear and the wheel?
What type of wheels are those?
Overall, a pretty cool iteration on swerve.
It's pretty neat to see these offseason swerve designs come back. There's usually some pretty cool ones like this!
Unread 30-06-2014, 19:33
Tyler2517's Avatar
ShortOnes
AKA: Tyler Gibb
The green thing is a spacer that lets us translate the power from the wheel with the bevel to the wheel with out. It has 12 threaded holes in it so that we can offset the bolts so the load from each one of the wheels so there is a lot less shear force(each wheel has 6 holes.)
6 holes on the gear.
The bevels are from sdtp. We are not using the stock materials and will custom make them our selves if the ones are not strongthat we can buy.
We are looking at making the bigger of the gears out of a titanium alloy most likely Ti-6Al-4V Trading a week of my summer to clean there shop in trade for the machine time and resources to make 20ish on there 5 axis cnc. We do not want 2 of the same material gears so we don't have to grease them so carpet cant get stuck in the grease.
Custom wheel 2.78 in diameter if i remember.
https://drive.google.com/folderview?...sp=dri ve_web
Unread 30-06-2014, 19:49
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
That is a very nice deal.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 30-06-2014, 20:01
Chris is me's Avatar
AKA: Pinecone
I'm having trouble picturing this so I can't be sure, but doesn't this just mean each bolt is loaded in single shear instead of double shear? I think 12 bolts going through both wheels would be stronger since the bolts are in double shear. Both are probably overkill.
Why does having two different materials negate the need for grease? Why does having two of the same material necessitate it?
Unread 30-06-2014, 20:12
Tyler2517's Avatar
ShortOnes
AKA: Tyler Gibb
I suck at explaining.
The spacer in the middle will have 12 holes threaded in to it. each wheel will have 6 bolt holes they will be threaded in to the middle spacer every other hole so that we don't have large amount of shear force going through the green spacer.
The wheel is really small and trying to get room for 12 bolts is both supper heavy and over kill for a 2.78 inch wheel. We were trying to have no nuts/bolt heads on the out side of the wheel so that we can get the walls of the moduler as close as possible.
Having the 2 different materials will cause much less wear. Just like running 2 steel gears on each other will cause rapid wear. Having the titanium gears running on a brass alloy gears will let us put very little grease on it with very little wear. That way the carpet fibbers will not get cough in the gear grease causing us not to bind our gears like last season.
Unread 30-06-2014, 20:25
T^2 T^2 is offline
FRC #5499
Are you sure you want to be loading screws in shear at all? Why not replace half of them with spring pins?
Unread 30-06-2014, 20:26
kk052's Avatar
kk052 kk052 is offline
CAD extraordinaire
AKA: kyle lundquist
FRC #2517 (the green wrenches)
Team Role: CAD
kk052 can only hope to improve
actually the wheels are custum 2.75 inch, and the bevel is from SDP/SI part:
A 1B 3-Y32016B
A 1B 3-Y32064
the grean spacer is threadded on the outer holes, six bolts from the right wheel, six though the left
(im the CAD lead, i would know)
FRC TEAM 2517 The Green Wrenches
2012 Autodesk Oregon regional
Chairman's award, Entrepreneurship award, Pit safety award
2013 central Washington regional
Imagery award, Pit safety award
2014 we won something but i forgot
-"the CAD is only accurate if you machine it accurate!!!"
--"its not working because your doing it wrong!!!"
---"is it really ok to put an acronym in an acronym?" (FIRST)RC?
Unread 30-06-2014, 20:29
kk052's Avatar
CAD extraordinaire
AKA: kyle lundquist
Team Role: CAD
also the brass on titanium is to make the brass take all the wear, so we dont need to replace the titanium
Unread 30-06-2014, 20:45
All the wear, as in "you better replace 'em often". Brass isn't known for wearing well--in fact, it's better known for deforming when harder materials apply force to it (to the point where when a hard material is getting beat up, and brass is suggested as a replacement, engineers start asking "Are you sure about that?" and "Is there another material that will work?"). Try bronze instead--it's a little harder, and to some extent can be made somewhat self lubricating (bronze bushings, NOT brass bushings). Titanium is already really hard, harder than most FRC gears are, which will tend to increase the wear on the brass gears even more than, say, aluminum/aluminum interactions or steel/steel interactions.
Regarding the screws: You're loading the screws in shear. (Quick check: Do you know what shear stress is, in broad terms? If not, we'll be happy to explain.) What that means is that the screws are going to want to "cut" themselves apart, probably at the spacer. The tendency is actually less if there are multiple locations for the shear stress to act at, hence the suggestions to run the bolts through, giving double shear instead of single shear. If you're concerned about clearance, there are ways to deal with that, including sinking the holes for the screw heads and nuts so the heads drop right out of the plane of the side plates.
Unread 30-06-2014, 20:47
magnets's Avatar
Why would you want titanium? It's a worse material for gears than steel. The weight savings would be well under a tenth of a pound. The "good stuff", grade 5 titanium, isn't cheap either.
If wear is so bad that it is an issue for an FRC robot, then you'll experience wear on both gears, regardless of material.
You will need grease regardless of the material you make your gears out of. If you run without enough grease, you'll wreck the gears in no time.
TBH, I haven't done the math, but a cantilevered 32 DP brass bevel gear at the output of the transmission, where the torque is the highest doesn't seem like a good idea.
If you're doing this on CNC anyway, I would get rid of the green thing and try something like the vex pro versakey pattern, or something that's similar to the dog clutches used in FRC gearboxes.
Unread 30-06-2014, 21:47
Tyler2517's Avatar
ShortOnes
AKA: Tyler Gibb
http://imgur.com/6orZXtp - The green spacer 12 holes.
http://imgur.com/TskU7rT - wheel with 6 holes.
We will probably change it over to 6 single bolts going all the way through there was a really good reason we did not do this in the first place and now i cant remember why.
For gears steel on steel i think is what we will run for the initial prototype types.
Unread 30-06-2014, 23:07
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
I thought screws were meant to be in shear load? 10-32 screws have ratings in the hundreds of pounds range IIRC.
Unread 30-06-2014, 23:23
It depends on the screw and arrangement. Generally, an individual screw is meant to handle tension loads. However, in the right arrangement, they can handle pretty high-shear loads.
I broke out my machine-design textbook--it's really handy for a lot of things with robotics, including a general screw-bolt-nut overview. (Also one of the few chapters I didn't get into in college.) The answer there is that generally, screws are for tensile loads, but in structure use, they're often used to resist shear. BUT, those shear loads are taken when the screw is already in tension. The suggestion from the book is to use dowel pins in machine-type shear situations to assist the screws.
I've seen what sometimes happens when a lone screw takes a shear load. It's not fun to hear if it's a good-sized screw. Come to think of it, I don't know if we ever did find that one screw/bolt head...
