Go to Post In the 2010 game, FRC and FVC robots will be working together to cut Dave's hair, mow his lawn, and serve him dinner. ;) - Rich Kressly [more]
  #31   Spotlight this post!
Unread 30-06-2014, 23:35
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Jefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond repute
Re: Swerve Concept
Originally Posted by Greg Woelki View Post
Okay, so about half a second or so.
FYI, I just tested ours using smartdashboard. It looks like 200 ms for a 90 degree turn, which matches our design calcs pretty closely.
  #32   Spotlight this post!
Unread 30-06-2014, 23:44
AdamHeard's Avatar
Lead Mentor
Re: Swerve Concept
Mind posting motor, gearing and what the wheel is? Thanks!
  #33   Spotlight this post!
Unread 01-07-2014, 00:00
AKA: Jeff Clements
Re: Swerve Concept
AM0912
100:1 VersaPlanetary
42T:66T (we think... At least that's close) sprockets
Edit: AndyMark 6" performance wheels
  #34   Spotlight this post!
Unread 01-07-2014, 09:28
Gdeaver Gdeaver is offline
FRC #1640
Re: Swerve Concept
A swerve control algorithm can always run the drive motors one direction and check to see which way to turn. Least distance. Or the algorithm can look for the shortest distance with motor reversal. Both will work. We have done the latter. This does put a stress mechanical and electrically on the module. The first has increased response times. Now say you have a CVT solution for swerve, but the response is asymmetric on the direction of the drive motors. Works really good counter clockwise, terrible clockwise shaft end. Do you accept greater than 90 degree steering solutions for CVT or is the steering response more important? That's what I've asked our team.
  #35   Spotlight this post!
Unread 01-07-2014, 12:29
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
Re: Swerve Concept
So... optimally, what RPM should the module turn at? What speed do teams that consistently use swerve revolve at?
  #36   Spotlight this post!
Unread 01-07-2014, 18:45
AKA: Jeff Clements
Re: Swerve Concept
See my response above. I measured a 90 degree turn at 200 ms. We had designed for around 1 RPM, and it looks like we are a little faster than that.
That is with the hardware-enabled ramp on the Jaguar and limiting the output to 75% in the software. Those guys can eat a battery up if you let them.
  #37   Spotlight this post!
Unread 01-07-2014, 18:55
Re: Swerve Concept
A lot faster. 90deg/200ms = 75 RPM.
  #38   Spotlight this post!
Unread 01-07-2014, 19:17
bobcroucher's Avatar
bobcroucher bobcroucher is offline
FRC #2471 (Team Mean Machine)
bobcroucher has a spectacular aura aboutbobcroucher has a spectacular aura about
Re: Swerve Concept
you are correct. Although, I think he meant 1 RPS.
  #39   Spotlight this post!
Unread 01-07-2014, 19:34
nathannfm's Avatar
nathannfm nathannfm is online now
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Re: Swerve Concept
Originally Posted by jimbo493 View Post
2 Wheels allow for more traction
Well keep in mind that, while more wheels will keep the tread pattern from wearing down as quickly, doubling the number of wheels will give only a very minor improvement in traction since, while it is simplified, friction very closely equals N*mu.
Originally Posted by Bryce Paputa View Post
On a deformable surface like carpet, the n mu approximation isn't a valid assumption, he'd pretty much need to test it himself with his wheel setup in order to figure out how friction would be effected. With a rough top tread I would think you would get more friction
Do you know of any quantitative data that teams have collected about this with different wheels/treads? I have been unable to find any.
MOE just did this test last week. Our test rig was a simple 4 wheel cart with the wheels locked in place. We used 4 inch AM Performance Wheels (1 inch wide) with riveted on blue nitrile*. The cart was first weighed down to 127lb total and dragged with a force gauge. It slipped when the gauge read ~108lb. The test was then repeated with more weight (192lb total) and slipped at ~160lb. We took this to mean that the relationship between weight and force needed to slip was relatively linear as the % increase in force needed to pull was about the same. We then added 4 more identical wheels to the same 4 axles and locked them in place effectively creating a 2 inch wide, 4 inch diameter wheel. The cart was pulled a third time and the reading was ~180lb. This shows that (at least for a 4 inch diameter wheel with blue nitrile) wheel width will certainly give you more traction but it is not anywhere close to 1:1. More like 100% increase in width = 13% increase in traction, so it's worth is still subject to some debate.
We opted to go with the force gauge test because we felt it was safer, easier and more accurate than the ramp test (the cart tended to fall forward off the ramp before it slipped)
*not new, slight wear.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
  #40   Spotlight this post!
Unread 01-07-2014, 20:10
AKA: Jeff Clements
Re: Swerve Concept
Ha! Yes. Good catch. 1RPM wouldn't do a lot of good in a 2 min match.
1RPS
  #41   Spotlight this post!
Unread 01-07-2014, 20:26
ekapalka's Avatar
FRC #3216
Re: Swerve Concept
Wow... that's less than half the proposed speed for this design. What is the reasoning behind that? I guess there's a threshold beyond which the speed qualifies as unnecessarily fast, but where do you draw the line?
