Re: Ford auto mechanic?
1) Turn key from OFF to ON and pause:
can hear fuel pump run for about 2 seconds and then stop
2) Rotate key from ON to START:
Engine starts immediately and idles smoothly, quietly, at correct speed
3) Before misfiring begins, press accelerator:
Engine bogs down and stalls.
My working hypothesis is that the fuel pump itself is fine, but it's not being controlled properly once the engine is started. A fuel pressure test would only confirm what I am already pretty certain is true. It wouldn't help me find the cause. If I had an appropriate fuel pressure gauge and all the proper fittings I'd probably test it just to be sure... but in the meanwhile I'm exploring if there are other simpler things I can check -- things which might be interfering with the proper operation of the fuel pump once the engine has started. I visited three auto parts stores and two auto shops this morning. There appears to be much confusion concerning fuel pump operation and fuel pressure regulation on this engine for this model year. On the one hand: Chilton's says there is no pressure regulator: The PCM (Powertrain Control Module aka engine computer) controls the speed of the fuel pump to regulate to the desired fuel pressure. To do that, I would assume the PCM would need a fuel rail pressure sensor, and sure enough Autozone's website shows a drawing of the top of the engine with a Fuel Rail Pressure Sensor (FRPS). On the other hand: None of the auto parts stores (including the afore-mentioned Autozone!) could find a FRPS listed for this engine. They all said the engine uses a FPR (Fuel Pressure Regulator). The auto shops I visited thought the engine has a pressure regulator. One even gave me a quote to replace it. There is a large hard plastic cowling covering the top of the engine, hiding from view the area I would otherwise simply look at to resolve this question, and it is securely fastened with a weird fastener whose removal process I have yet to figure out. Later today I will take a photo and post it here, maybe someone has seen something like it. Last edited by Ether : 02-07-2014 at 14:21. |
Ether,
My guy also said there is a fuel rail regulator rather than direct control of the fuel pump. Again the fuel pressure test would show if that was at fault as well. I have been told that more often than not, the pump gives up all at once. Since the engine bogs down and quits with either the pedal depressed or simply idling, we can rule out idle circuit troubles I think. Still points to fuel pressure/delivery. My guy is not a big fan of Stabil for cars BTW. The MAS airflow still could be an issue and in some cars, you can disconnect it to get the engine running and some you can't. Be warned that there are two numbers for the same engine in that line. When you order parts you need to know that number or the VIN number to get the right parts. |
On my Vic it's a W. Anybody know what the differences are? |
9 indicates a 'natural gas' burning CV, W indicates SFI (burns gasoline, 99%+ of CVs)
I've had excellent results using StaBil in small engines (chainsaw, go-kart, ATV, yard tractors, walk-behind brush mower, etc) but never used it before in a car.
What does he not like about StaBil in a car, and what does he recommend instead? |
It has a fuel pressure regulator. AND it has a fuel pressure sensor.
Rockauto.com lists both parts: Fuel Injection Pressure Regulator and Fuel Pressure sensor. If the crash inertia switch were triggered the pump would not turn on at all. See: http://troubleshootmyvehicle.com/for...rt-condition-2 Seeing as you seem fairly convinced it's a fueling issue I would recommend getting a voltmeter on the fuel pump or the fuel pump harness while the engine is started and then running. This will be most instructive and could indicate a bad fuel pump relay, relay fuse, fuel pump fuss, bad wiring, etc. Note: eye-balling fuses won't indicate if they're failed due to hairline cracking, which does happen. I believe this wiring may be accessed fairly easily in the trunk. I personally dislike using fuel pressure gauges in general because of the risk of leaking fuel. There are a few other things to check on a car of that age that should take a total of 20 minutes: -Check all vacuum lines (dry rotting, cracks, leaks) -Clean the MAF (mass air flow) sensor (a dirty MAF is a sad MAF) -Clean IAC (these like to get plugged with build-up from the PCV system) -Check the air filter FWIW my first car was a 2000 Crown Vic (police interceptor) and these days I maintain four cars and work on a couple race cars. While I'm no Ford engineer I have turned a wrench or two ![]() Last edited by JamesCH95 : 02-07-2014 at 15:51. |
#7
Does anybody know where I can find a detailed electrical schematic? Quote:
#8
You could register with Autozone to get access to repair/service manuals, here. There are, of course, numerous other sources. IMO Haynes and similar are about useless except for listing torque specifications, so I do not think you should bother with one of those. A google image search yields some interesting results, but nothing of great resolution... |
#9
I can't vouch for this particular manual, but I've had good luck with similar purchases. You can always get the hard-copy version, which is clearly marked 'Ford Motor Company': http://www.ebay.com/itm/like/310968012052?lpid=82 |
#12
Meanwhile, while I'm waiting for delivery, does anyone know where I might find schematic of fuel pump wiring? I've tried the Chilton manual (database available through our library) but no cigar. |
#13
Ether,
From your description, we know several things are good. But we don't know if the fuel pump relay is good, or if the system controlling the relay is good, or if the pump is delivering sufficient volume. The Prime function (2-second run you hear before crank) bypasses the fuel pump relay. The relay NO contact ("87") is actuated by the PCM (powertrain control module) during start and run; verify pump gets power while cranking. You can also jumper across relay - Terminals "30" (+12V in) and "87" (not "87A"). Temporarily, of course, but OK for many minutes. PCM uses several inputs to decide if pump runs: If engine speed <~400 RPM it shuts off, for example. PCM grounds terminal "85" to close relay, you should have +12V at terminal "86" all the time (or at least with ignition on). The genuine Ford manual will have both diagnostic trees you can follow and a basic explanation of how it works. At least my 98 Windstar manual did. Note that the Electrical Troubleshooting Manual (wiring diagrams) was a separate book for my Windstar. So dd that check and we'll see what to do next based on the result. |
#14
Thanks for the post Don. I'll follow up on it in more detail a bit later today. In the meantime, I've got a few questions: Quote:
#15
Just because a picture is worth some number of words;
http://www.supermotors.net/registry/media/175395_1 and a connector diagram; http://www.supermotors.net/registry/media/175387_1 These both appear to be for a 2000, but from what I can tell it should still be applicable. Also, I came across this diagram of a CV fuel pump wiring. It's not clear what year it is for but I expect the mid 90's to 2003 were all pretty similar. It does include the 'prime connector', which is just an easier way of bypassing the relay. If it's present on yours it might be a good place to watch the relays behavior, and an easier way to bypass it temporarily. Incidentally, the electrical wiring diagrams would be found in a specific Ford manual. In this case, FCS-12118-01 (where the last two digits appear to be a year code, so 01 for 2001). They're out there in printed form, though I have no idea if the electronic manual you ordered will have the same information or not. Good Luck! |
