Go to Post it's not the bot that makes the team great, it's the team that makes the bot great. - alicen [more]
Unread 02-07-2014, 15:48
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Ford auto mechanic?
Anybody know how fuel pressure is regulated in this engine ?
It has a fuel pressure regulator. AND it has a fuel pressure sensor.
Rockauto.com lists both parts: Fuel Injection Pressure Regulator and Fuel Pressure sensor.
If the crash inertia switch were triggered the pump would not turn on at all.
See: http://troubleshootmyvehicle.com/for...rt-condition-2
Seeing as you seem fairly convinced it's a fueling issue I would recommend getting a voltmeter on the fuel pump or the fuel pump harness while the engine is started and then running. This will be most instructive and could indicate a bad fuel pump relay, relay fuse, fuel pump fuss, bad wiring, etc. Note: eye-balling fuses won't indicate if they're failed due to hairline cracking, which does happen. I believe this wiring may be accessed fairly easily in the trunk. I personally dislike using fuel pressure gauges in general because of the risk of leaking fuel.
There are a few other things to check on a car of that age that should take a total of 20 minutes:
-Check all vacuum lines (dry rotting, cracks, leaks)
-Clean the MAF (mass air flow) sensor (a dirty MAF is a sad MAF)
-Clean IAC (these like to get plugged with build-up from the PCV system)
-Check the air filter
FWIW my first car was a 2000 Crown Vic (police interceptor) and these days I maintain four cars and work on a couple race cars. While I'm no Ford engineer I have turned a wrench or two
Unread 02-07-2014, 16:33
Be warned that there are two numbers for the same engine in that line. When you order parts you need to know that number or the VIN number to get the right parts.
AIUI, the 8th digit of the VIN is either a "9" or a "W".
On my Vic it's a W. Anybody know what the differences are?
Unread 02-07-2014, 16:35
My guy is not a big fan of Stabil for cars BTW.
I've had excellent results using StaBil in small engines (chainsaw, go-kart, ATV, yard tractors, walk-behind brush mower, etc) but never used it before in a car.
What does he not like about StaBil in a car, and what does he recommend instead?
Unread 02-07-2014, 16:44
^This is an excellent idea.
Does anybody know where I can find a detailed electrical schematic?
ditto that. gasoline is scary stuff.
Unread 02-07-2014, 17:23
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FSM (factory service manual) is your best bet. I like to get digital copies and have a laptop/tablet in the garage.
You could register with Autozone to get access to repair/service manuals, here.
There are, of course, numerous other sources.
IMO Haynes and similar are about useless except for listing torque specifications, so I do not think you should bother with one of those.
A google image search yields some interesting results, but nothing of great resolution...
Unread 02-07-2014, 17:28
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
9 indicates a 'natural gas' burning CV, W indicates SFI (burns gasoline, 99%+ of CVs)
Unread 02-07-2014, 23:52
I couldn't find any electrical schematics for the fuel pump circuitry there. Maybe I'm looking in the wrong place.
Unread 02-07-2014, 23:57
Is this the official service manual published by Ford?
Unread 03-07-2014, 08:33
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
I checked last night when I had a chance and couldn't find anything either. Plenty of schematics, but not of the fuel pump wiring.
I can't vouch for this particular manual, but I've had good luck with similar purchases.
You can always get the hard-copy version, which is clearly marked 'Ford Motor Company': http://www.ebay.com/itm/like/310968012052?lpid=82
Unread 03-07-2014, 08:42
I went ahead and ordered it last night. We'll see.
Meanwhile, while I'm waiting for delivery, does anyone know where I might find schematic of fuel pump wiring? I've tried the Chilton manual (database available through our library) but no cigar.
Unread 03-07-2014, 11:45
DonRotolo's Avatar
Back to humble
FRC #0832
Ether,
From your description, we know several things are good.
But we don't know if the fuel pump relay is good, or if the system controlling the relay is good, or if the pump is delivering sufficient volume.
The Prime function (2-second run you hear before crank) bypasses the fuel pump relay.
The relay NO contact ("87") is actuated by the PCM (powertrain control module) during start and run; verify pump gets power while cranking. You can also jumper across relay - Terminals "30" (+12V in) and "87" (not "87A"). Temporarily, of course, but OK for many minutes.
PCM uses several inputs to decide if pump runs: If engine speed <~400 RPM it shuts off, for example. PCM grounds terminal "85" to close relay, you should have +12V at terminal "86" all the time (or at least with ignition on).
The genuine Ford manual will have both diagnostic trees you can follow and a basic explanation of how it works. At least my 98 Windstar manual did. Note that the Electrical Troubleshooting Manual (wiring diagrams) was a separate book for my Windstar.
So dd that check and we'll see what to do next based on the result.
Unread 03-07-2014, 12:10
Thanks for the post Don. I'll follow up on it in more detail a bit later today. In the meantime, I've got a few questions:
Is there a physically separate relay component for turning on the pump for the prime function? Or are there 2 relays in one package: one for prime and one for when the engine is running?
Is this specifically for the 2001 Crown Vic 4.6L V8 -W? May I ask where you got this info from and if it's available somewhere online?
Will do!
If the previous test indicates I'm not getting voltage out of the relay I may try this. But here's my concern: It's still not clear how the fuel pressure is regulated on this engine. Some sources say there's a separate regulator, but some other sources say that the PCM regulates pressure by varying the fuel pump speed. If there's a separate regulator I can see where it would be OK to jumper the relay. But if the PCM is regulating pressure by turning the fuel pump on and off it's not clear to me it would be OK to override this function.
Again, this is exactly the kind of info I am looking for. Where are you getting this from? Is it from your Windstar manual?
Unread 03-07-2014, 13:09
Andy A. Andy A. is offline
Getting old
FRC #0095
Just because a picture is worth some number of words;
http://www.supermotors.net/registry/media/175395_1
and a connector diagram;
http://www.supermotors.net/registry/media/175387_1
These both appear to be for a 2000, but from what I can tell it should still be applicable.
Also, I came across this diagram of a CV fuel pump wiring. It's not clear what year it is for but I expect the mid 90's to 2003 were all pretty similar. It does include the 'prime connector', which is just an easier way of bypassing the relay. If it's present on yours it might be a good place to watch the relays behavior, and an easier way to bypass it temporarily.
Incidentally, the electrical wiring diagrams would be found in a specific Ford manual. In this case, FCS-12118-01 (where the last two digits appear to be a year code, so 01 for 2001). They're out there in printed form, though I have no idea if the electronic manual you ordered will have the same information or not.
Good Luck!
Unread 03-07-2014, 18:59
Don, did the above info come from your 98 Windstar manual?
Unread 03-07-2014, 21:02
Are you sure of this?
I just ran a test:
key OFF: Pin87 reads zero volts
key ON: Pin87 reads 12 volts for 2 seconds while I hear fuel pump running, then goes back to zero when pump stops.
turn key to START: engine starts, Pin87 reads 14 volts, stays there. I turn key off when engine starts misfiring.
