#16
Re: Alpha Weekend #2, 2015 Control System
Using a DIO to control a relay will likely never be legal.
#17
At this point, they are very similar and it would not be hard to make a program work on both.
#18
There's no rule currently saying you have to hook relays up to the relay ports. The only hookup requirement is that servos must be hooked up to PWM ports.
#19
2 things:
1. Has anybody had time to look at using USB to communicate with a co-processor? Is this even supported? How comprehensive is wpilib in supporting this at the moment? 2. I believe this has already been adressed, but are there any updates on when the roboRIO will be released to teams? Would it be possible for the 2015 wpilib to get released first, or at least a beta version? I really want to get a chance to look at developing code for some of the newer features on the roboRIO. |
#21
<R66> Every relay module, servo, and PWM motor controller shall be connected to a corresponding port on a Digital Sidecar and be controlled by signals provided from the cRIO. They shall not be controlled by signals from any other source.
#22
Ah I must have just skipped right over that. Also thinking about it, that rule makes sense because of the integrated pullups. That could get bad if it has enough current to run the relay. Yeah my bad.
#23
Also, hooking a Relay to a DIO will leave one channel of the Relay permanently on (corresponding to the DIO power line).
#24
Okay, off topic, but r66 was mentioned so I hope this isn't too off base.
My team is currently in the middle of designing a swerve drive. Part of the design is a custom circuit board that would be mounted to each swerve module to reduce the amount of computing the ___RIO has to do, as well as improve modularity, wiring, and ease of replacement if a module were to fail. The board takes inputs from the SideCar (if using 2014 and older control system) or roboRIO itself over SPI. The circuit board then processes the inputs and turns them into PWM motor commands, which are sent to a Talon or other approved motor controller. Does this meet the requirements of R66? It could be interpreted as legal if one thought that the ___RIO was still providing the signals by proxy, or it could be viewed as an entirely separate entity, and therefore illegal. Another thought, with the integration of the various serial communication ports on the roboRIO, as well as the MXP boards, do you think that this rule could be omitted, reworded, or loosened in next years manual? Thanks and sorry if this is off topic and/or confusing. |
#25
I expect this particular rule might be changed a little bit for next year, in order to accommodate break-out boards attached to the MPX port on the RoboRio. Despite that, I doubt it will change enough to make your solution legal. |
#27
Now, if you're doing it just for the experience, don't let me dissuade you. It sounds like a fun controls design task. If wiring simplicity is your desire, you can use the Jaguar's internal PID over CAN. That way the sensor wiring just has to run back to the Jaguar. The only reason we don't do this is because the analog encoder we use requires a 5V input and only outputs 0-5V. The Jaguar outputs 3.3V and is looking for a 0-3.3V input. It ends up complicating the wiring and requires a voltage divider in there to make things right. On the other hand, we have run at least 6 (maybe 7... can't remember) simultaneous PID loops on the cRio and never got close to 100% processor usage and saw no ill affects to any of the controls. We were using the WPILib PIDController on C++, so with other languages/controller YMMV. |
#29
What support would you want to see in WPILIB, vs using the interface provided by the OS?
