Go to Post NEMO is a virtual organization with a virtual headquarters and virtual bank account. - KathieK [more]
Unread 03-07-2014, 08:32
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: pic: 4587-Sheet Metal Chassis
Originally Posted by Cash4587 View Post
I am definitely going to keep the shape of the chassis like this though. I hadn't really understood the reason behind 148 and 971's hex and ocot sided frames until you told me at Comic-palooza.
Play around with it and see how you like it. Our team was 8 sided this past year and most people assumed it was to prevent getting stuck in pins however the real reason is that the extensions on the left and right sides allowed us to fit our shooter on top of our robot inside the frame perimeter. While we did notice it was slightly harder for someone to pin us we did find ourselves getting stuck because one of the sides would brush up against and object (side wall, other robots, etc) and would spin us into them. Our driver had to learn that he could no longer run up the side of the field and needed to stay several inches away so he could continue to drive in a straight line.
Every team needs to come up with their own opinions but our team won't be doing a multi-sided robot again for the purpose of making it harder to pin us.
1058 PVC Pirates 2016 - xxxx
Unread 04-07-2014, 00:06
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
I've done some reworking to remove the gearbox motor plates. The motors now mount directly to the channels which contain the wheel modules. I also added a handy battery mount.
Image found here:
http://prntscr.com/3z85k1
Unread 27-08-2014, 23:20
RoundTabler's Avatar
RoundTabler RoundTabler is offline
AKA: Nick Garcia
FRC #1519 (Mechanical MAYHEM)
RoundTabler will become famous soon enough
What are you using to articulate your modules? I can't figure out how you plan to drop the traction wheel.
