Go to Post Please don't complain about the party that was thrown in your honor because they didn't use your favorite color of balloons. - Taylor [more]
  #31   Spotlight this post!
Unread 02-07-2014, 18:39
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
Re: Weight Saving Techniques
Use the Battery as your weight buffer. Years ago, it had to be in the limit of 130 pounds. Now, the limit is 120 pounds less the battery. With the battery weighing in at about 12 pounds, that's a pretty hefty buffer zone.
Also, consider your options. When you put in plastic air tanks, use the weight of the metal ones. When you are going to use the minimal devices, use the weight of the maximum. You'll soon find yourself with a large amount of buffer weight whether you CAD your robot or design it on paper and build.
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
  #32   Spotlight this post!
Unread 02-07-2014, 21:38
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Originally Posted by Andrew Schreiber View Post
No... it's still required. Playing out here is rough. (This is partially joking, it's a lot rougher than I remember MI being though)
It was a rough game this year.
  #33   Spotlight this post!
Unread 03-07-2014, 09:45
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
True but its a rough year every year up here even with bumpers.
1058 PVC Pirates 2016 - xxxx
  #34   Spotlight this post!
Unread 03-07-2014, 12:49
bkahl's Avatar
bkahl bkahl is offline
Make Champs Great Again
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
bkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond repute
Originally Posted by Kevin Leonard View Post
A lot of people on this thread have mentioned using thin-walled aluminum as a great weight savings technique.
A lot of people on this thread have not competed at a New England event.
I'm going to start by attesting to the New England defense, our robot took a BEATING this year.
195 always goes overkill on material thickness, but its almost always for good reason. Our intake this year was made of welded 3/16" aluminum. Overkill? Maybe... but did it hold up? Yes.
Here's some general tips (Yeah, they're probably repeats, but they can't be over stated.):
-Over account for electronics weight...wiring does have weight, and its more than you'd think. (IIRC we left 20-30 lbs for electronics this year.)
-Go a size above what you think will work for Aluminum thickness. Its better to be safe than sorry.
-Always do CAD estimates, but know that the estimate is lighter than what it will actually be. CAD is just mean like that.
As for weigh-ins... I suppose we got lucky last year in Hartford.
Team 125
College Student/Whatever Brando says
Team 195
Alumni
Facebook
EWCP
  #35   Spotlight this post!
Unread 03-07-2014, 14:43
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
CAD isn't mean. It's a computer program. GIGO. Your calculation is only as good as the information you put in.
Just for general information, material nominal dimensions are sometimes given at what is known as "minimum material conditions" (unless specifically noted otherwise with a tolerance). This means that the 0.125" sheet you buy might actually be 0.127". The 1"x1"x0.0625" square tubing usually has pretty good dimensionality on the 1"x1", but the 0.0625" is very much a minimum requirement. Strength calculations for structural tubing are based on the nominal size, so the piece has to be at least that strong. Suppliers will target thicker materials to make sure that with manufacturing tolerances, they meet/exceed the minimum. They, of course, have an incentive to minimize the excess material to save on cost, but there is always the extra bit. Extrusions also don't have sharp intersections on internal corners. The fillet of material will add to the weight.
CAD models can account for this if you model all features and include the maximum material conditions.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
