Go to Post "Why do it the easy way when you can do it the hard way?:rolleyes:" - EricH [more]
Unread 22-06-2012, 09:13
badtkee badtkee is offline
badtkee is an unknown quantity at this point
VEX RC with Arduino
Hey Everyone,
I'd like to build a R/C robot using the VEX 75MHz transmitter and receiver and I was wondering if that is compatible with the Arduino Uno or Mega microprocessor boards?
Thanks for the help!
Unread 23-06-2012, 09:36
cmdelacuesta cmdelacuesta is offline
FRC #3455
cmdelacuesta is just really nicecmdelacuesta is just really nicecmdelacuesta is just really nicecmdelacuesta is just really nice
Re: VEX RC with Arduino
I'm working on the next revision for this board to submit for distribution but you can download the schematic and build your own for now.
http://code.google.com/p/vexmas-shield/
Unread 24-06-2012, 19:21
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
I was going to say not without some sort of interface, but it seems that someone has already designed one, how convenient. I love open source stuff.
Unread 25-06-2012, 04:23
sjspry sjspry is offline
FRC #1984
sjspry has a spectacular aura aboutsjspry has a spectacular aura aboutsjspry has a spectacular aura about
Alternatively you can clip off the RJ11 connector and connect to the wires directly. There is a library called ServoDecode which will handle interpreting the pulses from the VEX RC receiver.
Unread 12-07-2012, 13:02
Thanks for the help guys!
--Eric
Unread 11-03-2014, 11:01
ooo ooo is offline
ooo is an unknown quantity at this point
hi guys,
we're new here.
we want to send RF signals from our VEX RC controller and receive them with our Arduino Nano (ATMega328).
PAR_WIG1350 said there's already a library for this?
sjspry said we need to clip the connector and connect the wires directly.
which wire go where ?
where do we start with this?
many thanks
Unread 04-07-2014, 18:36
dmaki dmaki is offline
First VISTA
AKA: Dustin Maki
dmaki is a jewel in the roughdmaki is a jewel in the roughdmaki is a jewel in the roughdmaki is a jewel in the rough
I used that library in a few projects. Here is something similar to it, all I could find on this machine. This is an old version that may or may not compile. Use at your own risk, but the projects I built did drive via Vex RC and arduino pro mini or Teensy++ 2.0. Be sure to use the correct ICP (input compare pin) for the chip you use.
This for wiring and more
http://dankohn.info/projects/my_robot_2010/
#ifndef ServoDecode_h
#define ServoDecode_h
//Attribution: ServoDecode library from mem at http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1228137503/all
//adapted for Arduino 1.0, single file include, and use in this application by Dustin Maki
#include "Arduino.h"
#define TICKS_PER_uS	2	    // number of timer ticks per microsecond
typedef enum {NULL_state=-1, NOT_SYNCHED_state, ACQUIRING_state, READY_state, FAILSAFE_state } decodeState_t;
String stateStrings[] = { "NOT_SYNCHED", "ACQUIRING", "READY", "in Failsafe"};
#define MAX_CHANNELS    8	   // maximum number of channels we can store, don't increase this above 8
#define MIN_IN_PULSE_WIDTH (750 * TICKS_PER_uS) //a valid pulse must be at least 750us (note clock counts in 0.5 us ticks)
#define MAX_IN_PULSE_WIDTH (2250 * TICKS_PER_uS) //a valid pulse must be less than  2250us
#define SYNC_GAP_LEN	(3000 * TICKS_PER_uS) // we assume a space at least 3000us is sync (note clock counts in 0.5 us ticks)
//#define FAILSAFE_PIN   13  // if defined, this will set the given pin high when invalid data is received
#define PULSE_START_ON_RISING_EDGE  0
#define PULSE_START_ON_FALLING_EDGE (1<<ICES1)
#define ACQUISITION_COUNT  8  // must have this many consecutive valid frames to transition to the ready state.
volatile uint8_t pulseEnd = PULSE_START_ON_RISING_EDGE ; // default value
static volatile uint16_t Pulses[ MAX_CHANNELS + 1]; // array holding channel pulses width value in microseconds
static volatile uint16_t Failsafe[MAX_CHANNELS + 1]; // array holding channel fail safe values
static volatile uint8_t Channel;	// number of channels detected so far in the frame (first channel is 1)
static volatile uint8_t NbrChannels; // the total number of channels detected in a complete frame
static volatile decodeState_t State;	   // this will be one of the following states:
static volatile uint8_t stateCount;	   // counts the number of times this state has been repeated
static void processSync()
// Sync was detected so reset the channel to 1 and update the system state
   Pulses[0] = ICR1 / TICKS_PER_uS;  // save the sync pulse duration for debugging
   if(State == READY_state)
	   if( Channel != NbrChannels)
           {  // if the number of channels is unstable, go into failsafe
		   State = FAILSAFE_state;
   else
     if(State == NOT_SYNCHED_state)
	 State = ACQUIRING_state;	  // this is the first sync pulse, we need one more to fill the channel data array
	 stateCount = 0;
	 else if( State == ACQUIRING_state)
	    if(++stateCount > ACQUISITION_COUNT)
		State = READY_state;	     // this is the second sync and all channel data is ok so flag that channel data is valid
	        NbrChannels = Channel;       // save the number of channels detected
	 else if( State == FAILSAFE_state)
		 if(Channel == NbrChannels)
                 {  // did we get good pulses on all channels
   Channel = 0;	 // reset the channel counter
// required interrupt service routines
ISR(TIMER1_OVF_vect)
    State = FAILSAFE_state;  // use fail safe values if signal lost
ISR(TIMER1_CAPT_vect)
  // we want to measure the time to the end of the pulse
  if( (_SFR_BYTE(TCCR1B) & (1<<ICES1)) == pulseEnd )
    TCNT1 = 0;	 // reset the counter
    if(ICR1 >= SYNC_GAP_LEN)
    {   // is the space between pulses big enough to be the SYNC
	processSync();
    else if(Channel < MAX_CHANNELS)
    {  // check if its a valid channel pulse and save it
	if( (ICR1 >= MIN_IN_PULSE_WIDTH)  && (ICR1 <= MAX_IN_PULSE_WIDTH) )
        { // check for valid channel data
	  Pulses[++Channel] = ICR1 / TICKS_PER_uS;  // store pulse length as microsoeconds
	else if(State == READY_state)
	  State = FAILSAFE_state;  // use fail safe values if input data invalid
class ServoDecodeClass //ServoDecodeClass begin
  public:
    ServoDecodeClass(){}
    void begin()
      pinMode(ICP_PIN,INPUT);
      Channel = 0;
      State = NOT_SYNCHED_state;
      TCCR1A = 0x00;	   // COM1A1=0, COM1A0=0 => Disconnect Pin OC1 from Timer/Counter 1 -- PWM11=0,PWM10=0 => PWM Operation disabled
      TCCR1B = 0x02;	   // 16MHz clock with prescaler means TCNT1 increments every .5 uS (cs11 bit set
      TIMSK1 = _BV(ICIE1)|_BV (TOIE1);   // enable input capture and overflow interrupts for timer 1
      for(uint8_t chan = 1; chan <=  MAX_CHANNELS; chan++)
    	  Failsafe[chan] = Pulses[chan]= 1500; // set midpoint as default values for pulse and failsafe
    decodeState_t getState()
      return State;
    uint8_t getChanCount()
      return NbrChannels;
    void  setFailsafe(uint8_t chan, int16_t value)
    // pulse width to use if invalid data, value of 0 uses last valid data
      if( (chan > 0) && (chan <=  MAX_CHANNELS)  )
    	 Failsafe[chan] = value;
    void  setFailsafe()
    // setFailsafe with no arguments sets failsafe for all channels to their current values
    // usefull to capture current tx settings as failsafe values
    	  Failsafe[chan] = Pulses[chan];
    int16_t GetChannelPulseWidth( uint8_t channel)
      // this is the access function for channel data
      int16_t result = 0; // default value
      if( channel <=  MAX_CHANNELS)
         if( (State == FAILSAFE_state)&& (Failsafe[channel] > 0 ) )
    	   result = Failsafe[channel]; // return the channels failsafe value if set and State is Failsafe
    	 else if( (State == READY_state) || (State == FAILSAFE_state) )
           bitClear(TIMSK1, _BV(ICIE1)|_BV (TOIE1));//disable Timer1 input capture and overflow interrupts
    	   //cli();	 //disable interrupts
    	   result =  Pulses[channel] ;  // return the last valid pulse width for this channel
    	   //sei(); // enable interrupts
           bitSet(TIMSK1, _BV(ICIE1)|_BV (TOIE1));//enable Timer1 input capture and overflow interrupts
      return result;
};//ServoDecodeClass end
// make one instance for the user
extern ServoDecodeClass ServoDecode = ServoDecodeClass();
void configureRC(bool& configureRCenabled)//used for debugging, testing, and capturing typical values for setting up constants
    int pulsewidth;
    while(configureRCenabled)
        // print the decoder state
      if( ServoDecode.getState()!= READY_state)
        Serial.print("The decoder is ");
        Serial.println(stateStrings[ServoDecode.getState()]);
        for ( int i =0; i <=MAX_CHANNELS; i++ ){ // print the status of the channels
    	Serial.print("Cx "); // if you see this, the decoder does not have a valid signal
    	Serial.print(i);
    	Serial.print(" invalid pulsewidth : ");
    	pulsewidth = ServoDecode.GetChannelPulseWidth(i);
    	Serial.print(pulsewidth);
    	Serial.print("  ");
        Serial.println("");
      else
        // decoder is ready, print the channel pulse widths
        int16_t leftButtonMin = 2250;
        int16_t leftButtonMax = 750;
        int16_t rightButtonMin = 2250;
        int16_t rightButtonMax = 750;
        int16_t leftVertical = ServoDecode.GetChannelPulseWidth(3);
        int16_t rightVertical = ServoDecode.GetChannelPulseWidth(2);
        int16_t leftHorizontal = ServoDecode.GetChannelPulseWidth(4);
        int16_t rightHorizontal = ServoDecode.GetChannelPulseWidth(1);
        int16_t leftButtons = ServoDecode.GetChannelPulseWidth(5);
        int16_t rightButtons = ServoDecode.GetChannelPulseWidth(6);
        if(leftButtons < leftButtonMin)
        leftButtonMin = leftButtons;
        if(leftButtons > leftButtonMax)
        leftButtonMax = leftButtons;
        if(rightButtons < rightButtonMin)
        rightButtonMin = rightButtons;
        if(rightButtons > rightButtonMax)
        rightButtonMax = rightButtons;
        Serial.println("leftButtons: ");
        Serial.println(leftButtons);
        Serial.println("leftButtonMin: ");
        Serial.println(leftButtonMin);
        Serial.println("leftButtonMax: ");
        Serial.println(leftButtonMax);
        Serial.println("rightButtons: ");
        Serial.println(rightButtons);
        Serial.println("rightButtonMin: ");
        Serial.println(rightButtonMin);
        Serial.println("rightButtonMax: ");
        Serial.println(rightButtonMax);
    	leftVertical = map(leftVertical, 1000, 2000, -127, 127);
       rightVertical = map(rightVertical, 1000, 2000, -127, 127);
        leftHorizontal = map(leftHorizontal, 1000, 2000, -127, 127);
       rightHorizontal = map(rightHorizontal, 1000, 2000, -127, 127);
void parseRCbuttons(bool& L_UP_pushed, bool& L_DWN_pushed, bool& R_UP_pushed, bool& R_DWN_pushed, Servo& L_servo, Servo& R_servo)
        int servoTmp = 90;
        if(L_UP_pushed = (ServoDecode.GetChannelPulseWidth(5) < 1500-200) &&
	 (servoTmp = L_servo.read()) < 180)// open grip commanded and grip not already fully open
	{L_servo.write(servoTmp+1);}
	if(L_DWN_pushed = (ServoDecode.GetChannelPulseWidth(5) > 1500+200) &&
	 (servoTmp = L_servo.read()) > 0)// close grip commanded and grip not already fully closed
	{L_servo.write(servoTmp-1);}
	if(R_UP_pushed = (ServoDecode.GetChannelPulseWidth(6) < 1500-200) &&
	 (servoTmp = R_servo.read()) < 180)// raise arm commanded and arm not already fully raised
	{R_servo.write(servoTmp+1);}
	if(R_DWN_pushed = (ServoDecode.GetChannelPulseWidth(6) > 1500+200) &&
	 (servoTmp = R_servo.read()) > 0)// lower arm commanded and arm not already fully lowered
	{R_servo.write(servoTmp-1);}
	//illuminate LED on any button push
	if(L_UP_pushed || L_DWN_pushed || R_UP_pushed || R_DWN_pushed)
	{digitalWrite(6, HIGH);}
	else
	{digitalWrite(6, LOW);}
#endif
Unread 04-07-2014, 21:31
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Originally Posted by ooo View Post
hi guys,
we're new here.
many thanks
schucker.org:65080/schucker/Wiki.jsp?page=VEXTransmitter
schucker.org:65080/schucker/Wiki.jsp?page=VEXReceiver
http://profmason.com/?p=602
These should help you
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
