Go to Post "Individual": I am the FMS. I don't want to talk to you. Robot: FMS, is this true? I still have stuff for you. Actual FMS: No, what gave you that idea? Are you feeling ok? Repeat. Field Monitor: FTA! We need a counselor! - EricVanWyk [more]
Unread 05-07-2014, 09:27
Gdeaver Gdeaver is offline
FRC #1640
Re: Alligning swerve modules (and other problems)
We use continuous rotation 360 degree absolute encoders on our coaxial modules. All modules are identical. We calibrate our modules on or off the robot. We use the convention of looking at the module from the front, the wheel sprocket is to the right. We get the wheel pointing straight forward by eye, twisting it back and forth making sure it is centered. (more lash than I like). We connect Ground and 5 volts to the sensor. Signal and ground to a volt ohm meter. We loosen up the set screw on the beam coupler and twist till we get the 0.25 - 4.75 volt crossover position. Tighten the set screw. One of our mentors made a break out board to make this easier. This also can be done by the crio and dash board. We did have problems in the past with plastic beam couplers from automation direct loosening and loosing calibration. This year we used the First choice voucher and use the Al beam couplers. No slipping. We have had arguments over calibrating to the cross over point or 2.5 volts. I don't think it matters. When things get out of calibration, the code is bad or something else is wrong, our team calls it the happy dance. The drunken apple? I think I know were that came from. I call it a grand mal seizure.
