Go to Post Don't Canadians spell it that way? Someone should cheque on that.... - Travis Hoffman [more]
Unread 05-07-2014, 17:37
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
Re: pic: FrameDrive 6wd Concept
If you're running 9mm wide belts you should have adjustment to tension them correctly. If you're running 15mm wide fixed c-c would be fine. I would suggest adding up to 10 thou to the calculated c-c depending on belt run length, pulley size, and the specific belts you'll be using.
