Go to Post Defense will be everybody's part time job, not their career. - Wayne TenBrink [more]
Unread 05-07-2014, 10:04
FTC7584's Avatar
FTC7584 FTC7584 is offline
addicted to FIRST
AKA: Andrew S
FTC #7584 (Bad News Bots)
Team Role: Scout
FTC7584 will become famous soon enough
[FTC]: Joystick Issues
Hi. As our team starts to work on some side projects over the summer, I've run into an issue with the joystick controller. To test it, I created a simple debugging program, but I still can't figure out why the joystick fails to work.
No matter where the joystick is, RobotC (code) seems to think it's still at (0,0), however, when bringing up the joystick control debug window, I can clearly see that RobotC can see the joystick movement. I've tested this in several different programs so far. I just wanted to make sure that I wasn't making some sort of systematic error in the code, so here is an example of the issue.
#include "JoystickDriver.c"
task main()
 while(true)
    getJoystickSettings(joystick);
    if (joystick.joy1_x1 != 0 | joystick.joy1_y1 != 0)
    	writeDebugStreamLine("Test successful.");
If anyone could provide any insight, that'd be great.
Unread 05-07-2014, 18:28
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: [FTC]: Joystick Issues
Try
if (joystick.joy1_x1 != 0 || joystick.joy1_y1 != 0)
You are doing a bitwise OR with | and you want to do a logical OR ||
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 05-07-2014, 22:28
FTC7584's Avatar
addicted to FIRST
AKA: Andrew S
Team Role: Scout
That solved it, thanks!
