pic: Off-Season Drive Project
Re: pic: Off-Season Drive Project
It seems like with the octagonal frame, you have room for 2" wide - if not wider - wheels. With the 4" Colsons coming in a 2" wide variety, is there any reason you opted to choose the 1.5" wide wheels?
Good catch. I had originally designed the drivetrain without the octagonal frame up top. Now that I've added it, I have room for the 2" wide wheels. The only qualm I have is that I won't be able to use an e-clip to hold the wheels on the shaft because the WCP hubs are 1.5" thick. I suppose a screw, a washer, and some loc-tite would suffice. Thoughts?
Another question - is your bellypan just not lightened yet, or are you using a solid piece of aluminum? If you don't have the resources to waterjet a diamond-bellypan, I highly suggest using a solid piece of 6mm or 1/4" thick plywood as a bellypan. It's much lighter than a solid aluminum plate, and will serve well as an electronics pan as well as providing the torsional stiffness the diagonals that a diamond bellypan provide. |
This works well. I'd use a hex cap screw (which you can tighten with a wrench, not a screw driver/hex key) so you can get some extra torque on it.
#7
Spoiler for My original post:
#8
Spoiler for No longer relevant to topic:
Last edited by Andrew Lawrence : 05-07-2014 at 20:16. Reason: No longer relevant to topic |
#10
![]() This is our drivetrain with incorrect screws retaining the wheels. We used large washers for cosmetic reasons, we did some machining on the face of the wheel and wanted to keep it covered. Edit: Or as Akash pointed out, socket wrenches work in the set up you have CADed. Last edited by EricDrost : 05-07-2014 at 20:09. |
#12
I revise my previous statement to say that, thanks to Eric's example, a hex cap screw works equally as well any method of retaining. Last edited by Andrew Lawrence : 05-07-2014 at 20:14. |
#13
http://i.imgur.com/W7jAg3A.jpg We're partnering with another team to help with the waterjetting. Last edited by Ty Tremblay : 05-07-2014 at 20:08. |
#14
I'd seriously question that decision... Polycarbonate will be very floppy.
#15
That is a thing of beauty. I can't believe I haven't seen it before. What's the part number on those wheels, and do you have a link to any more pictures?
