Go to Post A lack of knowledge is okay; a lack of initiative to learn more is not. - Madison [more]
Unread 05-07-2014, 15:00
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
pic: 2-Speed Gearbox
Unread 05-07-2014, 15:01
evanperryg's Avatar
AKA: Evan Grove
Re: pic: 2-Speed Gearbox
Here's the STEP file: https://drive.google.com/file/d/0B4P...it?usp=sharing
Any suggestions?
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 05-07-2014, 15:12
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
No technical suggestions, but than I am a software guy. Gearbox looks really good though! At ~8% lighter than a wcp dog shifter, this would be 1.9 pounds with a pancake attached! Also, no "Black anodized for superior performance"?
Unread 05-07-2014, 15:18
T^2 T^2 is offline
FRC #5499
Your pocket shapes are odd. There's no need for bearing retention screws on the top shaft. The top two standoffs may be unnecessary.
Unread 05-07-2014, 16:05
evanperryg's Avatar
AKA: Evan Grove
Sorry, I was a bit unclear on the weight improvements. The weight of the plates on this gearbox is 8% less than the weight of the plates on a dog shifter, so .46lbs vs .5lbs. If the larger gears were milled out, weight could be reduced more.
Some of the weird geometry is necessary because of the odd positioning of the gears, some of it is simply to add character. The "retention screws" are actually mounting points for an encoder.
2013
2015
Unread 05-07-2014, 17:31
Deke's Avatar
Deke Deke is offline
no team (No Team)
Deke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the rough
You may need slightly larger fillets in the pockets to allow for a bigger endmill to work around. I would think a .125" radius would be nice for at least a 1/4" endmill, but more experienced machinist could chime in on a nice cutter size. The larger fillets will also reduce stress concentrations, strengthening the plates.
Unread 05-07-2014, 18:03
Jared's Avatar
Jared Jared is offline
Agreed. A .250 endmill is where you want to be for these sorts of plates. It's actually significantly stronger than a 3/16th endmill. Even if you're waterjetting the plate, I'd use a minimum radius of an 1/8th. There's a few lightening pockets that can't be cut on your plates, even with radiused corners.
If you're planning to mill the plates, it can be helpful to make the radius 0.126 inches. The extra thousandth makes generating the toolpaths a lot easier. That way, the machine doesn't have to go to a specific point, stop, and change direction; instead, it cuts the fillet as an arc.
I like the design. I'm guessing the upper shaft is .375 hex like the WCP shifter.
The wall thickness on your threaded holes is scary thin. A general rule is to use a circle that has twice the diameter of the hole. Also, the holes should be at the center of their fillets. It's stronger that way.
If you're really looking to save weight, you can get rid of the top set of standoffs and make the closer plate a lot smaller.
Unread 05-07-2014, 21:14
evanperryg's Avatar
AKA: Evan Grove
Thanks for the suggestions! You're right about the upper shaft, the shaft is identical to one you'd get in a WCP 2-speed. I've been making some adjustments, like centering the holes and adding material around them.
Edit: The larger fillets make the space around the holes much better, I might post a new screenshot soon.
2013
2015
