Go to Post Actually there are several Wayne Cokeleys circulating around. We cloned him in 2001. This is his evil twin Mordechai responding.....-WC 3 - Wayne C. [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 05-07-2014, 23:19
magnets's Avatar
magnets magnets is offline
FRC Design- Tips, Tricks, and Effective Methods
Designing FIRST robots is a very unique challenge. In some aspects, the robots are exposed to large, unexpected, and often damaging forces and loads. On the other hand, these machines need only to run for 100 hours, so teams have found all sorts of tricks that may seem very unconventional to typical design engineers that they can get away with and succeed in FRC. There are also many "normal" designs that are common among successful teams. This thread is a place to share any mechanical design tips, tricks, or methods that apply to FRC robot design.
Introducing my friend, a design engineer, to FIRST showed how unique some elements of robot design are. To this day, he cannot get over using an aluminum sprocket with steel chain.
Some examples that I've learned from CD are -aluminum gears, aluminum sprockets, 118 style chain in tube, 254's zip tie encoder mount, roller bearing and teflon pad elevators, Aren Hill's choo choo linkage, 67/254's smooth bumper material, somebody's method of using a hex sleeve as a removable coupling between gearbox and transmission, 254's (I think?) method of freezing the main breaker with upside down cans of canned air so it doesn't trip.
Unread 06-07-2014, 00:30
runneals's Avatar
runneals runneals is offline
FTC Mentor - The Robot Corps 7491
FRC #3928 (Team Neutrino)
runneals has a spectacular aura aboutrunneals has a spectacular aura about
Re: FRC Design- Tips, Tricks, and Effective Methods
We were lucky enough to have Aren mentor our team when he was at Iowa State, and he had really effective design techniques that helped us build one heck of a bot. Some of the ideas I encourage my FTC team that I mentor to use include building with subsystems to allow subsystems to be built independent of each other and to be implemented into the robot as a whole (kinda like cooking where you make a sauce and a chicken, then combine them into one). The other idea was to use a standard building system (like what the Vex Versaframe or FTC Tetrix parts) to allow for building/attachments with minimal tools/shop.
David Runneals
FRC 3928 Team Neutrino 4-H: Mentor (2015 Off-Season - ?)
FTC North Super Regional Championship: Game Announcer (2015)
FTC 7491 The Robot Corps 4-H: Mentor (2013 - ?)
FRC 2167 Mentor (2014)
FRC 3928 Team Neutrino 4-H: Member, Co-Captain, & Media Coordinator (2013)
Unread 06-07-2014, 00:41
Deke's Avatar
Deke Deke is offline
no team (No Team)
Deke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the rough
Hex shaft is one thing that is impractical for normal engineering designs. It creates stress concentrations within the inner bearing race with 6 sharp corners, and it must be designed with a slip fit. That slip fit is slowing wearing over time, but it does fine for a few hundred hours of FRC time. It is a slick way to not deal with key locks.
Along those same lines, you can get away with slip fits and some loc tite in axles/bearings, where you would normally press fit details. That is what took me a while to understand, because you don't need the thousands of hours of reliability.
Unread 06-07-2014, 00:48
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
If your press fits fail to "press" put on some black spray paint and then press fit.... Works like a charm. Plus the black makes it stronger and faster right 148....
Unread 06-07-2014, 00:53
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Do you spray the outside *plastic part* of the breaker, or the metal part?
Unread 06-07-2014, 01:16
Jared's Avatar
Jared Jared is offline
This year was my first involved with any type of design, so I learned a bunch.
-When putting snap rings on 1/2" hex shaft, use a metric size. It's easier to get the snap ring on.
-It's really helpful to drill and tap a hole in a shaft you may want to remove in the future so you can put a bolt in it and pull it out
-Over center linkages are really cool too. We used one in our pneumatically loaded spring shooter. It let the pneumatic cylinder extend to load the mechanism, then retract without it firing. We needed this because the shooter fired faster than the cylinder got out of the way.
-Use surgical tubing as a shaft coupler for encoder mounts. This is an awesome way to deal with misaligned and weird sized shafts. You just slide it over the shaft and add a bunch of zipties.
-Don't use non sealed bearings, especially in places where junk is likely to get into.
-Vex Pro's chain and previous chain bought from McMaster have different master links. Vex Pro needs the "Heavy Duty" one.
As for the breaker freezing, how much do you really think it does? Is it considered unsafe and against the rules? I was hesitant to try it after I got in trouble for shorting the pressure switch to reload air tanks after a stopped match, but after a practice match with a cooled breaker, it reached normal temperature by the end. I don't think the breaker has enough heat capacity to stay cold for that long.
Unread 06-07-2014, 14:59
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
It makes a huge difference. It's not about staying cold as much as it is about not going into a match with it at an elevated temperature.
We've had far more issues with main breakers prior to cooling them religiously between elims matches. There are other things you can do too, like cooling down the piston area of your compressor post match and after you've charged your tanks before the next match and cooling your motors. Everything will operate more efficiently when it is at a lower temperature.
2001-2004: Team 100
2006-Present: Team 254
Unread 06-07-2014, 15:06
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
I don't have the data in front of me right now, but when I ran some tests it was obvious how much performance gain there was in cooling the breaker. While cooling is significant by itself, cooling also has a much greater impact if you have back to back matches (ie Qualification/Finals) where the breaker doesn't have time to return to room temperature. When running back to back matches with the breaker chilled between matches, I think we saw a 3x increase in trip time, although I'm not 100% on the actual number. Regardless, it gives a definite performance gain.
As far as legality, it resides in a gray area and until the rules/GDC/Q&A explicitly state otherwise, teams will continue to use this for it's performance enhancing aspect
(2015-?): 973
(2012-2015): 955
Unread 06-07-2014, 17:07
wasayanwer97's Avatar
wasayanwer97 wasayanwer97 is offline
Take from the best, invent the rest
AKA: Wasay Anwer
FRC #0668 (The Apes of Wrath)
wasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant future
Always put a quick-connect fitting on the relief valve of your compressor/pneumatic system. It's come in handy several times.
If something that's supposed to be a press-fit is a little loose, wrapping it in layers of PTFE tape has worked as a quick-fix for us.
A chain holder is REALLY nice to have around.
http://www.amazon.com/Koch-7760110-R...r+chain+holder
It's extremely useful for when you can't fit an extra pair of hands in to hold chain, or for when you need to stretch the chain a little to slip the master-link in.
"Coming together is a beginning; keeping together is progress; working together is success."- Henry Ford
FRC Team 668: The Apes of Wrath
Pioneer High School, San Jose CA
http://www.theapesofwrath.org
Talking to other FIRSTers is great. Add me on Facebook!
My Page
Unread 06-07-2014, 17:37
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
How the heck did I not know about this after working on drive trains for three years?
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 06-07-2014, 17:58
caboosev11's Avatar
caboosev11 caboosev11 is offline
Director of Strategy, Engineer
AKA: Christopher Sherling
FRC #0694 (Stuypulse)
Team Role: Tactician
caboosev11 is just really nicecaboosev11 is just really nicecaboosev11 is just really nicecaboosev11 is just really nice
Reversible bumpers are very good to make. You need 1 less set of bumpers, and they can be switched to another color without needing to take them off.
I <3 Robotics.
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 06-07-2014, 18:05
Tyler2517's Avatar
ShortOnes
AKA: Tyler Gibb
If the reversible side comes off due to hard defense (when your red alliance and the blue shows) you can get disabled... be care full defense hurt this year.
Unread 06-07-2014, 18:31
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
If built correctly, this isn't an issue at all. You may be thinking of the sleeves that some teams use.
Unread 06-07-2014, 19:14
brennonbrimhall brennonbrimhall is offline
Free Agent
AKA: Brennon Brimhall
brennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to all
Please clarify your definition of "trip time." I don't think you're intending to say that command packet round trip times issued from the driver station took 3 times longer than normal to (a performance loss), but I'm having trouble finding another interpretation of your response.
Team 20, 2012-2014: 4 blue banners, 5 medals, and 9 team awards.
Church of Jesus Christ of Latter-day Saints, 2014-2016: Missionary, Colorado Denver South Mission.
Unread 06-07-2014, 19:26
wmarshall11 wmarshall11 is offline
FRC #2399
wmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to behold
I think by "trip time", we're talking in terms of "time to trip main breaker".
