Go to Post Don't you hate it when you can't find the droids you're looking for? - Jared Russell [more]
Unread 25-06-2014, 17:24
glennword's Avatar
glennword glennword is offline
Resident Solidworks Guru
AKA: Glenn
FRC #4146 (Sabercat Robotics)
Team Role: Student
glennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to beholdglennword is a splendid one to behold
Re: Team 1717: Uncut & Highlight Video
After watching the wheel view portion a few times, I noticed that the shaft and wheel appeared to be extremely sloppy, shifting back and forth laterally about 1/4" or more. Was this intentional?
"Whether you think you can, or you think you can't--you're right."
-Henry Ford
Unread 26-06-2014, 02:01
tickspe15's Avatar
tickspe15 tickspe15 is offline
Purdue University
AKA: Spencer Tickman
FRC #1747 (Harrison Boiler Robotics)
tickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant future
I spoke with a member of your team in the airport after champs who was very worried about your teams future. He mentioned that you were loosing Amir and another key mentor due to the growth of the Dos Pueblos engineering program into other areas. He hinted that we may not see a swerve drive from 1717 next year and he had a very bleek prediction of 1717's success in the future.
I have not heard/seen anything similar before or since this conversation. 1717 inspires me every year since we faced each other in the semifinals of Galileo in 2008 and was one of my favorite teams to work with during qualification matches at champs this year.
Team 1318: 2011-2015
Team 1747: 2015-Present
NAR (VEX U): 2015-Present
Unread 26-06-2014, 02:03
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
What.....
This cant be true. If that were to happen i'm not sure what to think any more i always thought of 1717 as one of the most stable teams in first. It would be very sad if 1717 were to fade away.
Unread 26-06-2014, 13:10
kevincrispie's Avatar
kevincrispie kevincrispie is offline
FRC #0971 (Spartan Robotics)
kevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to behold
Nobody should panic yet. The future of 1717's FRC program is in capable hands. The kids every year on 1717 are some of the hardest working in FIRST. They have a motivated core of mentors beyond their team leaders. It's a mistake to count them out any year and nobody should count them out now.
"If you want to build robots, you're going to have to break a few small appliances"
Unread 05-07-2014, 10:46
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
Looking at the 2012 uncut thread, it looked like you guys were dissatisfied with the performance of the gyro with the drifting and whatnot.
How did you improve upon this system since then, if you've managed to do so?
Head Programmer / Driver
Unread 05-07-2014, 21:47
Lordblair's Avatar
Lordblair Lordblair is offline
FRC #1717 (D'Penguineers)
Team Role: Driver
Lordblair will become famous soon enough
Originally Posted by JVN View Post
Are those numbers "free speed" or adjusted somehow?
Those are what we calculated as the theoretical speed, we didn't do any extensive testing to get an exact measurement.
Originally Posted by ekapalka View Post
What I mean is, did you have to make your own, or could you have just acquired them (without changing your CAD model). Did your team also design and fabricate your own pulleys? .
We did manufacture all our pulleys and gears out of solid billets of aluminum. This allowed us to make custom sizes to fit any restraints we had, but we tried to stick to more standardized sizes for simplicities sake, especially with pulleys and belt spacing.
The angle on the GoPro we used actually makes the whole module a lot larger than it is, so what may have seemed to be 1/4" is actually a lot less. We were running about .010" to .015" of slop in the bottom axle of the wheel box.
In 2012, we used just one gyro on our robot. This year we had two gyros, one being mounted upside down in relation to the other, that way we could use code to negate the drift. Having driven both the 2012 and 2014 robot, the second gyro makes a huge difference. There weren't really instances where I had to worry about re-zeroing during matches.
Unread 06-07-2014, 01:15
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Would you be willing to post the code that you used to fuse the two gyro measurements?
Thanks,
FRC 766, 2015-, Mentor
Unread 06-07-2014, 02:41
NWChen's Avatar
NWChen NWChen is offline
Alum
NWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to behold
Originally Posted by brandon.cottrell View Post
the way you guys approach matches.
Originally Posted by inkling16 View Post
your approach to pre-match strategy.
Could someone elaborate?
2012 - 2015 • Team 2601
Unread 10-07-2014, 07:46
brandon.cottrell's Avatar
brandon.cottrell brandon.cottrell is offline
Vice President
FRC #1266 (The Devil Duckies)
brandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud of
Their strategy mentor and a few teammates approached us before we left the pits the day before our match. We sat down in an empty area of the pit and just talked about the match and how we should handle it for probably about an hour and a half. After developing the strategy we went back to the hotel, and the next day we met with them immediately on the practice field where they practiced 2 matches with us, and personally showed me how to feed into their robot. They let me try it a couple times, and even though I ended up not having to ever feed into them for our match I still really appreciated that they thought to teach me that.
I'm sure they don't do all of that for /every/ match because of time constraints, and it was only probably because it was a very vital match for them, but it still shows that they exercise professionalism in strategy.
2012 Battle at the Border Winners
2014 San Diego Regional Winners
2014 Las Vegas Engineering Inspiration
2015 Battle at the Border Winners
