Go to Post Getting your questions answered is what the big thick manual is for....GO READ. - Dorienne [more]
Unread 24-02-2003, 16:43
Kori E. Kori E. is offline
#1065 (Tatsu)
Kori E. is on a distinguished road
Send a message via AIM to Kori E. Send a message via Yahoo to Kori E.
Unhappy Need help with programming
My team has no programmer. So I tried it out. Now I'm the programmer and everyone is blamming me for the program not being done. I need help with this if any programmer can give me a hand with this it would be great.
Unread 24-02-2003, 16:51
redbeard0531 redbeard0531 is offline
#0686 (Bovine Intervention)
redbeard0531 is an unknown quantity at this point
Send a message via AIM to redbeard0531
I, and several, others would love to help, but we need more info. What are you trying to do? What controls are you using? What are you trying to control? Also, it would be good to know your programming background(it is ok if the answer is none). If you want, I can e-mail you a copy of our code. It is writen in such a way as to be easaly readable.
Unread 24-02-2003, 16:56
Enzeru Enzeru is offline
#0382 (Twisted Blizzard)
Enzeru is an unknown quantity at this point
Send a message via AIM to Enzeru
Ill help
hey ill help you as mch as i can just email me first382@hotmail.com or im me shenlong395 and ill hook you up.
So just tell me what ur robot needs and ill do what i can.
Unread 24-02-2003, 19:10
#1065 (Tatsu)
what i need help in right now is making the autonomous mode run on only one joystick. i tried using a SW5 jumper but in autonomouse mode that makes one wheel go and so it goes in circles the whole time. and i need to get my robot to ramp. it just comes to a jolting stop but i need it to slow down to a stop.
Unread 24-02-2003, 20:04
Iain Iain is offline
Iain is an unknown quantity at this point
Why would you need a joystick active during autonomous mode at all?
Unread 24-02-2003, 21:17
ok one joystick
if ur using tank drive id say use 2 joystics.So send me ur code and ill have a look.
Unread 24-02-2003, 21:18
Umm Errr...
post ur code so far and what you need it to do and i as well as lots of other people will be more than happy to help.
Also we need to know how your motors are hooked up to your speed controllers
1139 Alumni
Unread 24-02-2003, 21:21
rust710's Avatar
rust710 rust710 is offline
#0862 (Lightning Robotics)
rust710 is an unknown quantity at this point
Send a message via AIM to rust710
You cannot have a joystick input in autonomous at all. If you are trying to gradually slow the robot without a joystick, something like this might work.
slowdown:
if PWM >127 then
PWM = PWM - 1 'This number can be increased to slow faster.
endif
If you need any help, send me you code info@lightningrobotics.com or Im me at Rust710 or PM me here.
One other thing. SW5 jumper, on the full size robot defult code it limits PWM3. This would make more sence to me if you where using the EDU bot. On the EDu bot SW5 does make the bot a one joystick drive. On the full size robot though you have to add the code your self.
Andrew Radamis
Programmer on 862
info@lightingrobotics.com
Programming Compatition Angela06 Programming 30 08-04-2005 23:12
multi-bank programming problem GregC Programming 3 14-02-2003 16:13
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
pbasic programming punarhero Programming 4 21-01-2002 23:32
