Go to Post Just like any good hardware or software product, "insert foot before putting mouth in gear"..... - dhitchco [more]
Unread 19-12-2012, 15:44
Andrew Lobos Andrew Lobos is offline
FTC4977/FRC225 Alum
FRC #0225 (TechFire)
Andrew Lobos is a jewel in the roughAndrew Lobos is a jewel in the roughAndrew Lobos is a jewel in the rough
Re: pic: FTC 4977 - The Black Box
Here's a video from one of our matches.
http://www.youtube.com/watch?v=8Gk5cjU45MA
The PID tuning on the rotation motors is still a bit rough, which causes some of the left and right misalignment you see.
Unread 14-04-2014, 18:08
5383robotsrule's Avatar
5383robotsrule 5383robotsrule is offline
FTC #5384 (code red robotics family of teams)
Team Role: Driver
5383robotsrule is an unknown quantity at this point
what language did you guys use to program this ? and is there any cad of the swerve modules ?
there are no mistakes only lessons
nothing is impossible some things are harder than others :yikes
Unread 14-04-2014, 18:36
FTC4977/FRC225 Alum
We used RobotC - the code for this robot is available on GitHub at https://github.com/FTCTeam4977/Robot2012-2013
I'll talk to the mechanical guys about getting the CAD up - the modules were CADed, but most of the parts were COTS or made with drills.
The modules shown in the picture were made with 100% Tetrix parts - don't do this if you can avoid it. We switched the side plates of the modules out for stronger plates and it vastly improved the performance and rigidity of the modules.
Unread 14-04-2014, 19:44
Wren Hensgen's Avatar
Wren Hensgen Wren Hensgen is online now
Alum, Mentor, Volunteer
AKA: Wren Hensgen
FTC #10353 (MetalWorks)
Wren Hensgen will become famous soon enoughWren Hensgen will become famous soon enough
Our CAD work, along with everything else the LANlords have created in Inventor over the years is available at GrabCad.
Link to the swerve modules here:
https://grabcad.com/library/lanlords...gn-2012-2013-1
Unread 14-04-2014, 21:29
Team Role: Driver
thanks so much now i can convince my teammates to choose swerve drive
Unread 14-04-2014, 21:47
FTC4977/FRC225 Alum
If you decide to go this route, I really recommend you try to build a prototype over the summer. We had a working testbed before the season started, and we were still improving and iterating on components during the competition season.
While FTC gives you a lot more freedom to make changes between events, implementing a complex system like swerve comes with a lot of challenges.
Unread 09-07-2014, 11:39
Team Role: Driver
Question Re: pic: FTC 4977 - The Black Box
how did you guys drive the robot ?
Unread 09-07-2014, 13:18
FTC4977/FRC225 Alum
The left gamepad stick controlled translation, and the right stick's X axis controlled rotation. Note that the left and right sides were chained together, so rotating and translating at the same time wasn't possible.
