Go to Post Dee and I pooling our brain cells almost make a full deck... - RoboMom [more]
Unread 08-07-2014, 14:35
RyanShoff RyanShoff is offline
FRC #4143 (Mars Wars)
RyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to behold
Drivers accidentally enabling Auto/Practice mode
What would everyone think about changing the driver station to make it harder to enable Autonomous or Practice mode?
Our team had a least two incidents last year where the driver, while tethered, intended to enable Teleop mode and accidentally enabled Autonomous.
It would be easy to make the radio button default to Teleop after every disable. Or even better make Autonomous mode a completely different tab and button.
Last year we mitigated the risk by keeping the robot in the pits on a stand that kept the wheels off the ground and kept the shooter locked out so it wouldn't fire.
One of the incidents happened on the practice field. A typical cycle on the practice field was run Auto, have someone retrieve ball, run Teleop to drive back to starting line, load ball, maybe change a setting, and repeat.
If the driver forgot to switch from Auto to Teleop and enabled, the result is a second autonomous run starting when no one on the field is expecting it. This scenario could be avoided with a simple change to the driver station.
Ryan Shoff
4143 Mars/Wars
CheapGears.com
Unread 09-07-2014, 20:07
Re: Drivers accidentally enabling Auto/Practice mode
Do you recall whether this was done with the mouse or the F1 shortcut?
One of the reasons I ask is that the button label could be made more explicit. Instead of saying Enable, and relying on the user to look at the mode section to verify what mode will be enabled, the button could replicate the info and be labeled as "Enable Auto" vs "Enable Tele". This would avoid the mode change side-effect and would help reenforce what the user is about to enable.
This doesn't help much if the F1 key is being used. But that could be removed. I don't think many people use it.
BTW, thanks for bringing this up, here or on the FIRST forum.
Greg McKaskle
Unread 09-07-2014, 21:45
Joining the 900 Meme Team
FRC #0079
Greg McKaskle
I use F1 all the time... But that's because I prefer keyboard shortcuts.
Unread 09-07-2014, 21:59
Aaron.Graeve Aaron.Graeve is offline
FRC #1477 (Texas Torque)
Aaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to all
Same here. I prefer the keyboard shortcuts, but I do see where they may cause a problem with knowing the robot mode. Even if the soft button changed to include text about the mode, it will still be a human error if the wrong mode is used.
Alamo, Bayou, and Lone Star Regional FTAA
2015:
Dallas, Alamo, Bayou, and Lone Star Regional FTAA
2014:
Alamo, Dallas, and Lone Star Regional FTAA
Alamo Regional Robot Inspector
2013:
Einstein Champion and 2013 World Champion (Thanks 1241 & 610), Galileo Division Champion, Razorback Regional Winner, Alamo Regional Semifinalist, Bayou Regional Semifinalist, Lone Star Regional Quarterfinialist
2012:
Curie Division Semifinalist, Lone Star Regional Finalist, Bayou Regional Winner, Alamo Regional Winner
Unread 09-07-2014, 22:38
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
The F1 key is great
Unread 10-07-2014, 00:41
It was with the laptop touchpad. I don't believe any of our drive team used F1 to enable.
Ryan Shoff
4143 Mars/Wars
CheapGears.com
Unread 10-07-2014, 00:52
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #5827 (Code Purple)
zinthorne will become famous soon enough
I think the driver station should be changed. Being a driver myself and doing the scenario on the practice field that was mentioned above there were a few times where I forgot to switch it back and havoc ensued. It happened more often when I would leave the computer for a second, and then someone else would mess with it.
Unread 10-07-2014, 08:32
Aren Siekmeier's Avatar
on walkabout
The F1 key is a must for us since we often have other stuff for diagnostics, data processing/logging etc. that can hide the DS interface. A quick press let's us enable to test, rather than finding the window and clicking in the right spot. And we can keep a full view of whatever other window is up when we enable.
Maybe have separate enable buttons (and keyboard shortcuts) for each of the modes? And keep the combined disable/e-stop commands.
Unread 10-07-2014, 18:11
DavisC DavisC is offline
FRC #0539 (Titans)
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
Could have something like after pressing Enable, have a menu popup to select which mode to run.
Could then also have that popup gain control so arrow keys can be used.
Also have F1 maintain the Enable mode, but then the user can use arrow keys or 1-3 respectively (or letters).
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
Unread 18-07-2014, 21:25
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
How about, whenever the robot is disabled, the setting is automatically reset to Teleop?
Unread 20-07-2014, 15:16
I'm looking at the suggestions to switch back to Teleop on disable, and I'm thinking about how inconvenient that would make it to test the robot. But instead of just shouting "NO! DON'T DO THAT!" I'm going to try something a little more constructive.
How about making the behavior a configurable option? Those who want it to be difficult to run Autonomous by mistake can set it up that way. Those who prefer it the way it is now don't have to be forced away from it.
Unread 20-07-2014, 16:11
on walkabout
I agree that defaulting back to teleop after every disable is kind of a terrible idea. This would really derail any attempt at iterative testing in autonomous mode, and causes more unexpected behavior than the current configuration.
Keep the disable and e-stop buttons and hot keys. But for each mode, have a separate on-screen button and hot-key to enable this mode, so that by hitting this button or hot-key you are explicitly telling it to enable in a particular. The menu seems really impractical as well since it requires several steps and gets in the way of quick cycling.
