Go to Post lets get FIRST in every home around the world, and a robot in every school. - Rohith Surampudi [more]
Unread 13-07-2014, 13:08
SoftwareRachel's Avatar
SoftwareRachel SoftwareRachel is offline
FRC #4505
SoftwareRachel is an unknown quantity at this point
Drivetrain controlled by xbox controller?
Hello,
I was wondering which RobotDrive would I use if I wanted to control the robot in a way such that:
The left stick on the xbox controller would give y-values that would control the forward and backward movement of the robot
And the right stick on the controller would give x-values that would control the rotation of the robot (for example if the right stick was pushed to the right, the robot would rotate to the right)
It's probably really simple, but I've been stuck for a while
Thanks in advance!
Unread 13-07-2014, 13:17
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Drivetrain controlled by xbox controller?
I would suggest arcade drive.
Unread 13-07-2014, 13:21
FRC #4505
Would public void arcadeDrive(double moveValue, double rotateValue) work?
Unread 13-07-2014, 13:34
Flywheel Police
Absolutely.
