Go to Post the always so humble metal-in-motion.....i know your tricks; you all are gonna have a killer robot as usual.... - Stephen Kowski [more]
Unread 12-07-2014, 19:16
safiq10's Avatar
safiq10 safiq10 is offline
FRC #2950 (DEVASTATORS)
safiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond repute
C-Rio as on board computer?
Now for the upcoming year every team will be getting a new RIO (Yaaa ) and that means every veteran team will a C-Rio left over. So could you use the C-Rio as your new onboard computer? (I have no knowledge on C-Rio or programming so that is why I asked on the CD)
2014 Dallas Semi-Finalist (Thanks 3847 & 231)
2014 OKC Semi-Finalist (Thanks 2341 & 2461)
Unread 12-07-2014, 19:56
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Re: C-Rio as on board computer?
It's doable, but you'd be better off using a raspberry pi or something similar. Smaller, easier to program, and more flexible power options.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 12-07-2014, 20:00
brennonbrimhall brennonbrimhall is offline
Free Agent
AKA: Brennon Brimhall
brennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to all
The legality of that depends on the wording of the R57 equivalent next year's rules.
However, I don't predict that that will be common in 2015 -- the cRIO's processor is only clocked at 400 MHz (for cRIO-FRC II). For comparison, a Raspberry Pi ($35) runs at 700 MHz without overclocking it. I don't know what you'd be using it for, but common FRC applications for on board computers (like vision) would benefit from something that has a higher CPU speed or USB capability (something that the cRIO also doesn't have).
Team 20, 2012-2014: 4 blue banners, 5 medals, and 9 team awards.
Church of Jesus Christ of Latter-day Saints, 2014-2016: Missionary, Colorado Denver South Mission.
Unread 12-07-2014, 23:59
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
The RoboRIO with the Zynq 7020 (ARM A9 and FPGA) is a little (quite a bit) more powerful than what the previous cRIO. I'm not sure a co-processor will even be required at this point. We'll see!
Also, you can likely remove the cRIO backplane from the housing if you desired to use it as a co-processor. It would just need a GDC approval. Keep in mind, the weight penalty of the cRIO is huge.
Unread 13-07-2014, 08:42
evanperryg's Avatar
AKA: Evan Grove
It would certainly be nice to have camera processing on-board. It would make basically everything relating to vision tracking way easier. Hopefully, the FMS bandwidth will be improved too, so sending decent quality camera data back to the drivers station will be feasible.
2013
2015
Unread 13-07-2014, 10:53
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
It is perfectly legal to have an sbc, like a pi or odroid. We plugged multiple cameras into our odroid and processed all our images on the robot. In 2012, we build a small, 5 pound computer and had it on our robot.
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 13-07-2014, 11:36
evanperryg's Avatar
AKA: Evan Grove
Sounds pretty cool. Hopefully, the rRio will be able to process camera feeds more effectively than the cRio. It'd be nice to eliminate the need for an outside computer to do good image processing.
2013
2015
Unread 13-07-2014, 15:40
headlight headlight is offline
headlight is an unknown quantity at this point
Would there be advantages to writing custom FPGA code for the old C-Rio and using that as a secondary computer? As I understand it, an FPGA is very good at parallel execution and operates much more like a re configurable integrated circuit. If you can move your image processing and other autonomous functions into the FPGA it might be able deliver some good performance. I've only written simple FPGA functions for the C-Rio before and don't a very good handle on the actual capabilities of an FPGA.
As for the weight penalty it seems like many teams are coming in routinely underweight. It seems to be less of an issue than in previous years.
Unread 13-07-2014, 16:01
magnets's Avatar
magnets magnets is offline
Used in the application of FRC? How? With VHDL? LabVIEW?
The answer to your question is yes, but programming an FPGA is not an easy task. Even if you knew VHDL really well, how would you go about programming the cRIO? Getting the development environment together without having a LabVIEW license to program a FPGA is easier said than done. That's not to say it can't be done though. There were teams interested in doing this sort of stuff before, but couldn't due to rules. It would be really cool too.
Unread 13-07-2014, 17:50
I did it in Labview and not for FRC. I'm just hoping NI is generous with software sponsorship.
Unread 13-07-2014, 19:11
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
I plan to use our c-Rio as a training aid on a tabletop robot. I think just about anything that will run on the RoboRio will run on the c-Rio with maybe a tweak here and there. It could be used to develop prototypes while the RoboRIO has been integrated into the production robot.
Unread 13-07-2014, 20:44
If a team has a great idea that needs the use of the FPGA, please write up a grant and contact someone in academic marketing or myself. Please, no dangerous stuff.
Greg McKaskle
Unread 13-07-2014, 20:50
Michael Hill's Avatar
While it sounds like an interesting idea, I just couldn't imagine it being worth it in weight. There are tons of other boards that could be used that are much lighter than a crio. If you're wanting an FPGA board, I know there are some Xilinx Dev Boards out there for a pretty reasonable price (<$150).
Unread 14-07-2014, 00:12
To clarify, I wasn't necessarily talking about a competition robot, or a robot at all.
Greg McKaskle
