Go to Post FIRST is a pretty decent microcosm of real life, those who work hard, accomplish more decent lesson to learn, and FIRST is allowing us to learn it. - Aren_Hill [more]
Unread 13-07-2014, 16:00
Travis Schuh Travis Schuh is offline
FRC #0971 (Spartan Robotics)
Travis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant future
Re: 6 wheel vs. 8 wheel WCD
Originally Posted by evanperryg View Post
On a flat field, 6 and 8 wheel drives are almost exactly the same. 8 wheel drives do have the advantage when you look at the details, but the main difference between the two will be the quality of the driver.
A well balanced 6wd will have better turning response/handling than a 8WD because it will have minimal wheel scrub forces on the outer wheels (due to there being very little weight on them). We find this to be a huge advantage and really helps with having an amazingly driven robot.
6wd also have fewer parts, which helps with weight and manufacturing.
