Go to Post Teams should spend more time talking about how to avoid penalties during their strategy sessions. - Rob [more]
Unread 15-07-2014, 21:51
tgross35 tgross35 is offline
FRC #4810 (I Am Robot)
Team Role: Electrical
tgross35 is an unknown quantity at this point
Is there an alternative to the PDB?
Hello all,
My team was looking to build a self-driving cart (anyone with experience on that, while I'm on the subject?) and would obviously need some way to power our motors. It doesn't make any sense to me to sink in $200 for a PDB to power about 4 motors and an Arduino (and some lights, and a DC/AC inverter) but the other option that AndyMark has is from the cheap and dirty kit, which doesn't support the 40A breakers. Does anybody have any suggestions? Even a fuse system could work, anything under $80 or so. Thanks!
Unread 15-07-2014, 21:54
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
Re: Is there an alternative to the PDB?
You could always solder in 40A breakers in line.
Unread 15-07-2014, 22:00
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
We've used these 1 In/4 Out fuse blocks . I believe they were used in FIRST before the CRE and IFI PDB were available.
2016: FRC 865 Mentor
Unread 15-07-2014, 22:08
Do you need 40 amp breakers?
Unread 15-07-2014, 22:09
Jared's Avatar
Jared Jared is offline
As others have said, you can use the really old style blocks.
If you're only using a few, you can get some individual inline fuse holders from amazon
http://www.amazon.com/MAXI-Fuse-Hold...ords=maxi+fuse
It's also possible to get 40 amp fuses (not auto resetting breaker) that are the blade size (smaller) fuses if you want. http://www.mcmaster.com/#7460k39/=susd5r
You can use a board like this with them http://www.amazon.com/Seachoice-ATO-...rds=fuse+block
Unread 15-07-2014, 23:45
Thanks everyone for the quick responses, you solved my problem.
Just to answer the question, I would prefer having them just since the motors will be drawing a lot of current. We could probably make do without, but I like having the option.
Thanks again everyone!
Unread 16-07-2014, 03:38
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
I'd go with stud mount breakers of this style. http://www.waytekwire.com/item/46440...T-BREAKER-40A/
There are lots of options with these breakers, in addition to the one I linked w/o a bracket and auto reset there are manual reset and ones with brackets.
However I posted the one without a bracket so you can use one of these http://www.waytekwire.com/item/46468...AKER-MOUNTING/ which is available for 2 to 8 breakers, or this 7 bracket box http://www.waytekwire.com/item/46560...-JUNCTION-BOX/
To distribute the power to multiple breakers you can use one of these buss bars. http://www.waytekwire.com/item/46568...RCUIT-BREAKER/ again available for different numbers of breakers.
To insulate the breakers w/o using the box they sell these boots http://www.waytekwire.com/item/23540...AKER-BOOT-RED/
Here is the catalog page with all of these types of breakers. http://www.nxtbook.com/nxtbooks/wayt.../#/131/OnePage
You should be all in for ~$20 or so depending on how many you actually use. You can also find those style of breakers in a decent auto parts store though they typically will not stock the buss bars, snap in brackets or boots. They also have other styles of breakers such as those used as the FRC main breaker in various amperage and mounting styles. http://www.waytekwire.com/products/1...cuit-Breakers/
Unread 16-07-2014, 20:25
DonRotolo's Avatar
Back to humble
FRC #0832
The automobile industry has lots of things that are useful. Particularly the auto accessory industry, like guys who put in new car stereos...
Google around that and see what comes up.
Unread 16-07-2014, 20:59
Jacob Bendicksen's Avatar
Jacob Bendicksen Jacob Bendicksen is offline
Figuring out what's next
Jacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond repute
It is nice having the option of 40A breakers, but we built an 300lb autonomous Roomba-like robot this year for a lake in our area (cue water game comments), and even when we were running 48" paddlewheels and 75lb conveyor belts off of CIMs, we never blew a 30A breaker, even in full sunlight. This was a huge worry for us, but we just used an old FRC PDB (I'm forgetting which one), and we never looked back.
Just my 2 cents.
jacobbendicksen.com | @jacobbendicksen
Yale University Class of 2020
Team 1540 | 2012-2016
7 Chairman's Awards, 6 other awards, 2015 Dean's List Finalist, 1 event win, 2 finalist finishes. Thanks for an amazing ride.
