Go to Post Banned for being a nerd. There are no nerds in here! - Schnabel [more]
Unread 24-02-2003, 18:46
GrahamS314's Avatar
GrahamS314 GrahamS314 is offline
FRC #0314 (Megatron Oracles)
GrahamS314 is an unknown quantity at this point
Send a message via AIM to GrahamS314
Question Two Pneumatics off one Double-Solenoid Valve
I was surfing the posts and it seems someone has already asked about this subject, but the reply didn't help us at all. It is my understanding that to run two pneumatic cylinders from one double-solenoid, you must use a servo to restrict the flow to one of the cylinders. Is there another way to accomplish this without the use of a servo? Any help is greatly appreciated.
Unread 24-02-2003, 18:54
Patrick Wang Patrick Wang is offline
#0115 (MVRT Alumni)
Patrick Wang has a spectacular aura aboutPatrick Wang has a spectacular aura about
Send a message via AIM to Patrick Wang
Lightbulb Nope
All you need is a T-juntion coming out of the solenoid.
Plug one tube to one cylinder and the other tube to the other.
Repeat for the other end of the cylinder to the other output.
Just look at the airflow and it should be pretty clear.
-edit-
I just looked at your question again, what you mean is, be able to independantly control them? or have them perform the same or opposite actions at the same time?
Patrick Wang
WRRF
Unread 24-02-2003, 19:01
GrahamS314's Avatar
Our goal is to control these cylinders independantly of one another. This would allow us to use 4 cylinders all for different purposes, only when needed.
Unread 24-02-2003, 19:04
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
There are ways to do it, but I don't think the materials are availible in this year's kit All methods I know would require a servo.
Unread 24-02-2003, 19:17
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Well, to my knowledge, if you were to use gravity (or inertia, or even latex tubing... whatever, really) to your advantage, you could power a pneumatic actuator in one (of the two possible) direction (connect only one side of the actuator to the solenoid, whether it's double or single), which would allow you to power two pneumatic actuators using only one solenoid.
Uh. Please correct me if I'm wrong.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 24-02-2003, 23:49
I thought it was pretty neat, when I saw a robot with servo motor that bent the pneumatic tubing of that year, sharply enough to close the tube. Ingenious
multiple cyclinders from one double solenoid Ed Crammond Pneumatics 1 07-02-2003 18:49
double solenoid gail OCCRA 0 11-10-2002 19:42
Will trade for double solenoid valve archiver 2001 2 24-06-2002 00:33
Pneumatics: Double Solenoid archiver 2001 13 23-06-2002 23:57
Single Solenoid Valve SMC Chubtoad Technical Discussion 3 20-01-2002 15:16
