Go to Post Perfection is less about effort or skill than it is about having a clear and limited goals. - SoftwareBug2.0 [more]
Unread 16-07-2014, 19:13
Jared's Avatar
Jared Jared is offline
Autonomous Path Maker
Here's my attempt at autonomous path generating software. It's similar to 254's, but uses parametric splines, splines with unspecified headings at waypoints, and acceleration limits through turns.
It uses the robot's starting and ending position and heading at two points and a series of up to 6 waypoints to generate a piecewise parametric 2nd derivative continuous function that goes through the points and has the starting and ending angles. It also outputs a text file with each wheel's distance travelled, x position, y position, velocity, acceleration, first, and second derivative (y with respect to x) at 0.01 second intervals, which can be previewed in real time. The acceleration and velocity can have limits, and the velocity at the start and end must be zero. It also smoothly decreases velocity through turns.
Here's a video of the spline editor: https://www.youtube.com/watch?v=pdqi...bfBMtpDr0IXytg
Check out the project on GitHub: https://github.com/dicarlo236/PathIn...athinterpolate
A better description of how it works is on the wiki page on GitHub.
The interesting classes are Spline, Robot, Path, and SplineEditor.
A robot controller is included, but it's not tested.
Unread 16-07-2014, 19:22
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
Re: Autonomous Path Maker
I can't view that video; it's set to private.
Head Programmer / Driver
Unread 16-07-2014, 19:28
Jared's Avatar
Try now.
Unread 16-07-2014, 19:41
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
I hope to one day reach a level of programming in which I could do stuff like this! *C++ port? )
