Go to Post I'm still trying to find a way to get FIRST to dump the Chicken Dance song. :p - Koko Ed [more]
Unread 16-07-2014, 14:12
tuXguy15's Avatar
tuXguy15 tuXguy15 is offline
Team Mentor
AKA: Devin Kolarac
FRC #2559 (Normality Zero)
tuXguy15 is an unknown quantity at this point
Power From The Wall
So our team so far in the off season has built several trainers for future members of the team. Our next goal is to run these trainers off of a wall outlet instead of a battery. I was wondering if anyone has built a device like this and tried it out? I know its just a power converter since its AC to DC but I'm not sure what else is involved if you guys have any tips for me.
Unread 16-07-2014, 14:34
Re: Power From The Wall
Can you describe what these "trainers" are? How much current do they require, at what voltage?
Unread 16-07-2014, 14:38
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
The problem with running a robots/similar things off a AC-DC power supply is the spike in amperage (from motors) most psus cannot handle. I have some 1000w server power supplies I modded for use in bench testing electronics and running battery chargers.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 16-07-2014, 17:21
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
There are ways to modify computer power supplies for custom use. If you're doing a lower power setup (i.e. control system and a couple small motors at most) you could be able to use a normal power supply out of an old OEM desktop. Regardless, for a just-good-enough system, look for a 350W+ supply, preferably made in the last 6-7 years. I have done this in the past with a couple of different OEM supplies if you are interested in how to do it.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 16-07-2014, 17:31
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Seconded. I'm sorry, but "trainer" is not a standard term to my knowledge in FIRST. Even if it's a commonly used term where you are, I would sincerely appreciate it if you would explain precisely what you are referring you when you talk about a "trainer." I am relatively confident that you do not mean a shoe.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 16-07-2014, 17:39
Jared's Avatar
Jared Jared is offline
If you're just powering electronics, then a 12 volt supply good for a few amps should be just fine. I don't know exactly what type of power supply the PDB has for the cRIO, but I know some supplies designed for batteries don't like to be powered from another supply, so power your cRIO-II directly from the 12 volt supply.
If you're powering a drive base, then no, not unless you have a really expensive supply. At stall, you can draw a few hundred amps at 12 volts. Even if you did have a supply, it is likely that a robot's sudden current spikes could trip the typical 15 or 20 amp breaker that powers the wall outlets.
Unread 16-07-2014, 20:08
DonRotolo's Avatar
Back to humble
FRC #0832
I'm going to make a huge assumption here and guess you built a few basic robots that will be used to train drivers.
Can you run them off a wall outlet? Yes. As you almost said, what you want is a "12 volt power supply". Google it.
There are some considerations though:
1. A power supply with sufficient capacity to supply a typical FRC robot would need about 120 Amperes of current output. Such a power supply is likely to be VERY expensive.
2. You CAN put a battery into the trainer robot and also connect a power supply with a current capacity of maybe 10 to 20 Amperes. This will allow you to run a bit longer on that battery. But not forever. And not a LOT longer, maybe double or triple the battery-only time.
3. You can't leave the power supply connected to the battery if the robot won't be used for a while (more than 20-30 minutes), because it acts like a charger but isn't really set up like one - it can overcharge the battery, causing damage to many things.
4. Wires from the power supply to the robot will interfere with driving. Just like an Ethernet cord would do.
5. Running longer heats up motors more than when you give it a rest to change the battery, Be sure to manage the thermal aspects of your robot.
Another alternative is to get a larger deep-discharge type battery (sometimes called a Marine battery). It is not FRC legal, but it is a 12 volt battery and will have a far larger capacity than an FRC battery, allowing you to run quite a bit longer.
In the future, a clearer, more detailed question would help us help you better.
Unread 16-07-2014, 21:24
tuXguy15's Avatar
Team Mentor
AKA: Devin Kolarac
There is an electrical trainer and a pneumatic trainer. The electrical trainer's highest load comes from the mini-cims without any load on them so the current draw is minimal. The pneumatic trainer's largest load is going to come from the compressor. I dont think current will be an issue with the electrical board, but I do think it might be an issue with the compressor since that does occasionally draw a lot of current.
Unread 19-07-2014, 00:15
sparkytwd's Avatar
sparkytwd sparkytwd is offline
FRC #3574
sparkytwd will become famous soon enough
An ATX power supply should give you what you want. You can find several ATX to banana post breakouts online:
http://www.seeedstudio.com/depot/ATX...ly-p-1222.html
If 15 amps is your power budget, you're pretty much set with any $30 supply you can find online.
If your budget is higher than that, you'll need to check the specs for the supplies, which should be easy to find as the beefier video cards require certain amounts of power delivery.
If you need even more than a single PSU rail can deliver, you can find multi-rail power supplies. In that case you need to remember you can't connect the 2 rails in parallel, they must be hooked up separately. Switch mode power supplies without explicit support for synchronous power conversion don't play well with each other.
Unread 19-07-2014, 10:22
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
OP, no one can help you solve your problem until you clearly describe what you are trying to do. What is your definition of trainer? What is the quantity of motors in the trainer? How are they to be used?
If you are trying to run a robot as a trainer for new students, then what exactly precludes the use of the FRC battery pack? What about the battery limits you from using it as a reliable, representative solution? Part of training could include the limits of the FRC system, and battery life absolutely can be one of them.
Unread 19-07-2014, 10:43
jimbo493's Avatar
jimbo493 jimbo493 is offline
Quasi Mentor
AKA: Jimmy
FRC #3357 (The COMETS)
Team Role: Electrical
jimbo493 has a spectacular aura aboutjimbo493 has a spectacular aura about
Maybe it would be helpful if you posted a few pictures? Are these just platforms which you have but, say, a compressor, some storage tanks, and a few solenoids?
Or for the electrical a Full FRC layout? aka Main breaker, PDB, Motor controllers, some motors, maybe a sensor or encoder? Personally, I would see how having a power for the pneumatics "trainer" could be helpful, but I think its best to leave electrical as a battery, you probably won't use an entire battery in a day, and it helps students see the limits of the system, ect.
Unread 20-07-2014, 00:01
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
To do this "cheaply" What you would want is an unregulated 12V power supply. Basically, you'd parallel the output of the power supply with an FRC battery. The battery would handle the peak loads and the PSU would handle the base load & recharge the battery.
Theoretically, you can use a standard 12V automotive battery charger with this, although I'm not sure what current rating it would require. I'd recommend at least a 20A charger, it really will depend on your base load and your drive train.
Unread 20-07-2014, 11:31
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
A 20A charger has the potential to do significant damage to both the battery and the power distribution board.
Unread 20-07-2014, 16:48
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
Older computer PSUs can output 20 amps of 12 volt power for cheap if you know how to hack them. Check your local junkyard.
You could possibly take an old UPS and use it. Just draw off of the battery terminals. The battery will act as a high capacity capacitor of sorts, so you can achieve high amperage output, but not have to worry about swapping in and out batteries.
But of course, all of this depends on your exact needs- how many amps you need, if that is continuous or not, and how much of ripple is acceptable.
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
Unread 21-07-2014, 10:58
One Eyed Man
I disagree that it could damage the battery, although I understand why people say that. But damaging the power distribution board? How?
