Go to Post What Delphi says doesn't matter. What the official Q&A says matters. - Tetraman [more]
Unread 16-07-2014, 21:08
shewejff shewejff is offline
Jeffrey S
AKA: Jeffrey S
FRC #1025 (Impi Robotics)
shewejff is on a distinguished road
Most Commonly Used Aluminum Extrusion Profiles
Hi all,
I have a question to throw out to the CD community. I know what aluminum extrusion profiles that our team has found that we like to use, but I'm curious what's most commonly used by other teams. What are the top five aluminum extrusion profiles that your team most commonly uses in building your robots (standard profiles excluding T-slotted)? Typical profiles include: angle, rectangular tubing, flat, c-channel, round tubing, etc. And what size?
For example, if I were to answer for team 1025, I would say:
1. Rectangular tubing 1" X 1" X 1/16"
2. Angle 1" X 1" X 1/8"
3. Rectangular tubing 2" X 1" X 1/16"
4. Flat 4" X 1/8"
5. C-channel 2" X 1" X 1/8"
Also, if this is any different than the first answer, what profiles would you recommend that an average rookie team stock up on before the season begins (again, nothing exotic or T-slotted)? Please don't answer with, "It depends on their manufacturing capabilities" or "Wait until the game is released." All you know is that it's an "average" rookie team that wants to stock up before the season.
Unread 16-07-2014, 22:16
itzaklevi's Avatar
itzaklevi itzaklevi is offline
itzaklevi
AKA: Jeremiah Johnson
FRC #3618 (Petoskey Paladins)
itzaklevi is an unknown quantity at this point
Re: Most Commonly Used Aluminum Extrusion Profiles
My team definitely has favorites. Here they are.
1. 80-20 of several shapes and sizes. Usually 1x1, but this year we had some 2x4 as well.
2. C-Channel for the base. 4 years in a row.
3. 1.25x1.25 square tubing with 1/8 walls.
4. 2.5" angle. Used in most brackets.
5. 1" angle, used relatively frequently when the 2.5" is not required.
Unread 16-07-2014, 22:38
Michael Hill's Avatar
Last year, we used 1x1x.125 square tubing, 1x2x.125 rectangle tubing 1x1x.125 angle. Previously, we've used small amounts of 1x1 80-20, but it's SO heavy. Is it just me or is, 1x2x.0625 6061-T6 hard to find? I've looked for it in several places, but it seems to be rather uncommon.
Unread 16-07-2014, 23:03
Greg Woelki's Avatar
Greg Woelki Greg Woelki is offline
FRC Alumnus
FRC #1768
Greg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of light
Adding to everything posted so far, 2x1x0.1 rectangular tube (versachassis), 1x1x0.0625 angle, and 0.5x0.5x0.125 angle are great.
Unread 16-07-2014, 23:15
There's lots listed in this thread: http://www.chiefdelphi.com/forums/sh...d.php?t=125737
Unread 17-07-2014, 12:58
jimbo493's Avatar
jimbo493 jimbo493 is offline
Quasi Mentor
AKA: Jimmy
FRC #3357 (The COMETS)
Team Role: Electrical
jimbo493 is on a distinguished road
We use a lot of 1x1 Angle in both 1/16 and 1/8 depending on the application
We also used last year some 3x5 box for a gearbox, 1/8th thick. We also use 1in flat and 4in flat for a lot of applications,We use 1x1 1/8th thickness for drive bases and structure, along side 1x2. We don't use tubing that much, but we did use it for supports this year
Unread 17-07-2014, 15:47
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Churros!
Unread 18-07-2014, 13:38
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
1) 80/20 I know you said no t-slots but it is so useful especially for rookie teams & prototyping. You can get a deep discount if you tell your distributor you are a First team when you order it.
2) The Andymark C channel. reference holes are nice
3)The VEX 2x4x.1 rect. tube reference holes & lines are nice.
4)1x1x.125 angle. easier to properly torque nuts than in tube.
5)1x1x.125 square tube. About the same weight as 1" 80/20. Slightly stiffer.
6) 1/2 hex. Great for shafting
Unread 18-07-2014, 15:51
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Actually, contrary to popular belief a section of 1x1 80-20 is slightly LIGHTER than the same legenth of 1x1x.125 square tubing. If you really want to save weight use thinner wall square tube.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 21-07-2014, 00:40
tickspe15's Avatar
tickspe15 tickspe15 is offline
Purdue University
AKA: Spencer Tickman
FRC #1747 (Harrison Boiler Robotics)
tickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant future
The order changes from year to year but usually looks something like this:
1) 1"*1"*1/8"
2)1"*2"*1/8"
3)1"*1.5"*1/8"
4)1.25"*1.5" T bar
5)2"*2" 1/8 angle
6)1"*1"*1/16"
7)1.25"OD*1/8" pipe
8)1.5"OD*1/8" pipe
9)1/8" sheet
Team 1318: 2011-2015
Team 1747: 2015-Present
NAR (VEX U): 2015-Present
Unread 21-07-2014, 13:17
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
The weight from 80/20 isn't in the extrusion. It's in all the bracketry and fasteners.
2001-2004: Team 100
2006-Present: Team 254
Unread 21-07-2014, 15:04
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Here's something people haven't yet mentioned in this thread. I love to design worm gearboxes based on big, 1/4" thick box extrusion and then pocket the heck out of it to save weight. They're really, really strong, and although they can be hard to assemble, they're really versatile units.
For example, this year we used about this much stock for creating worm gearboxes:
  • 5 ft 4" x 2" x 1/4" tubing
  • 3 ft 3" x 2" x 1/4" tubing
On the other hand, I doubt a rookie team would use tubing like this unless they had a CNC mill and were pretty confident in their ability to design gearboxes.
My general advice for a rookie team would be to just stock up on 1x1x1/16 and 2x1x1/16 6061 tubing. We probably used 40 ft of the 2x1 this year and 20 ft of the 1x1. You can build almost any frame you want with those two extrusions, 1/8" alu plate for gussets, and 3/16" rivets.
-Plutarch
Unread 21-07-2014, 16:46
george.tan's Avatar
george.tan george.tan is offline
Raider Power!
AKA: George
FRC #3005 (RoboChargers)
george.tan is on a distinguished road
Rectangular tubing 6061 1" X 1" X 1/16"
Rectangular tubing 6061 1" X 1" X 1/8"
Flat 6061 1/4" and 1/8"
Unread 22-07-2014, 12:46
Clem1640's Avatar
Clem1640 Clem1640 is offline
Head Mentor
AKA: Clem McKown
FRC #1640 (Sab-BOT-age)
Clem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond repute
Our main profiles are:
1) 2" x 1" x 0.130" u-channel (Al 6061)
2) 1" x 0.125" square tube (Al 6061)
3) 1" x 1" x 0.125" u-channel
4) 1010 80/20 profile
Items 1-3 mostly are used in welded assemblies.
Clem McKown
Head Mentor - FRC 1640 & FTC 7314
Chairman - Downingtown Area Robotics
Unread 24-07-2014, 15:39
Oblarg Oblarg is online now
AKA: Eli Barnett
Here's my best guess for the past year:
For 449:
1) 1''x1''x.125'' Angle
2) 2''x1''x.125'' Tube
3) 1''x1'' 80/20
4) 1''x1''x.0625'' Tube
For 4464:
1) 1.5''x1.5''x.0625'' Tube (I had never used this particular extrusion before last year, and I absolutely love it now)
2) 1''x1''x.0625'' Tube
3) 1''x1''x.125'' Angle
4) 2''x1''x.125'' C-Channel
5) Churro Tube (best AndyMark product ever)
"The breakfast of champions!"
