Go to Post Maybe someone should start a FIRST Anonymous meeting to try to help the tragicly addicted... - BiTurboS4 [more]
  #31   Spotlight this post!
Unread 14-07-2014, 18:10
Jared's Avatar
Jared Jared is offline
Re: Linear Actuators
Originally Posted by JamesTerm View Post
So I have a question for everyone who has used the lead screw technique. How did you do a set point operation... like if you want it to go a certain distance? Did you:
1. Use an encoder?
2. Use a potentiometer?
3. Use a limit switch?
4. String potentiometer?
4. Something else?
If you used an encoder how do you ensure it remains calibrated (e.g. limit switch). I'd like to use this lead screw technique, but I haven't found reliable way to sense distance. (I have not tested the string potentiometer either).
Lead screws are super accurate for distance. The McMaster ones are rated per turn to within 0.009" per foot of travel. We used two end of travel limit switches and an encoder, coupled to a gearbox shaft with surgical tubing.
  #32   Spotlight this post!
Unread 17-07-2014, 10:57
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
1. Use an encoder?
4. Something else?
Our setup used a 10-turn potentiometer, belt driven off the lead screw, which was in turn direct driven from the window motor.
  #33   Spotlight this post!
Unread 17-07-2014, 11:43
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #5827 (Code Purple)
zinthorne will become famous soon enough
In 2013 we were a tower shooter. We used a "linear actuator" to move our shooter up and down for fin movements. We got our off of a car seat. (They are used to move seats forward and backwards in cars) We took the old motor off and then made a plastic converter on the lathe to the versa planetary gearbox we were using with a bag cim. Overall it took only a few hours to fully assemble.
  #34   Spotlight this post!
Unread 18-07-2014, 15:45
JamesTerm's Avatar
JamesTerm JamesTerm is offline
Terminator
AKA: James Killian
FRC #3481 (Bronc Botz)
JamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to behold
That is very cool! I googled around to see what they look like and they look like they are self contained when retracted (e.g. like a pneumatic cylinder). If you have any pictures of this setup... please share... thanks!
  #35   Spotlight this post!
Unread 18-07-2014, 22:24
Nyle's Avatar
Nyle Nyle is offline
FRC #0422 (The Mech Tech Dragons)
Nyle is just really niceNyle is just really niceNyle is just really niceNyle is just really nice
1. Use an encoder?
4. Something else?
For a while in 2013 our launcher was articulated using a lead screw (at first , we later replaced it with a piston) and we used a few magnetic reed switches (they sense the proximity of a magnet) to sense when the screw was close to either end, as well as a set-point in the middle.
If you just need to move to certain set-points, and are ok not knowing exactly where you are when between them, using switches that trigger at the important points can be both reliable and easy to set up.
  #36   Spotlight this post!
Unread 20-07-2014, 17:51
zinthorne's Avatar
AKA: Avery
This is the only picture I could dig up of the part. I am sorry that I could not find a better one. I can ask for a better one from someone else on the team.
http://www.idleloop.com/frctracker/p.../2013/3398.jpg
  #37   Spotlight this post!
Unread 21-07-2014, 22:28
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
1. Use an encoder?
4. Something else?
We prefer string potentiometers for our linear actuators. Quite simply, they are the easiest sensor to implement, and they are accurate enough for nearly every FRC application.
  #38   Spotlight this post!
Unread 22-07-2014, 14:19
JamesTerm's Avatar
Terminator
AKA: James Killian
A friend pointed me to this link last night: http://www.mcmaster.com/#ball-screws/=sy3xrc ... while the parts look great the prices are terrible... it makes me wonder if it would be easier to make your own using parts from say home depot or something. <I'm going to search around a bit more as well>.
  #39   Spotlight this post!
Unread 22-07-2014, 16:21
magnets's Avatar
magnets magnets is offline
Ball screws are pretty overkill for FRC. McMaster's fast travel lead screws are more affordable, and are very smooth running. The brass nuts have very low friction.
http://www.mcmaster.com/#acme-precis...screws/=sy9ith
  #40   Spotlight this post!
Unread 22-07-2014, 17:32
pfreivald's Avatar
AKA: Patrick Freivald
This is what we used. Ball screws are just too expensive!
That said, you of course still want grease on those brass nuts.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #41   Spotlight this post!
Unread 23-07-2014, 13:25
pribusin's Avatar
pribusin pribusin is offline
Uber Alien
AKA: Mike 1
FRC #4004 (M.A.R.S. Rovers)
pribusin has a spectacular aura aboutpribusin has a spectacular aura aboutpribusin has a spectacular aura about
Originally Posted by Tom Line View Post
I've been eyeing some of these models for some time:
http://www.servocity.com/html/12v_linear_actuators.html
I would love to have a drop-in electronic shifting option for gearboxes, and some of the lighter-duty short-throw actuators there have enough force to shift under load fairly quickly. They are pricey, however, and I haven't had time to find out what type of motor and shaft they are. I called servo city and they were unable to give me any more info than external dimensions, so someone would have to buy one to find out if any of our motors would mount in the same location.
Tom, We bought some similar to the ones you show in the link, but without the pot feedback. We modified the shaft of a mini CIM to accept the drive gear of the original motor. Works like a charm but still dead slow at 0.5"/sec. Would be ok for small adjustments that require precision and strength but if you wanted a 6" stroke for example, you'd wait 12 seconds - an eternity during a match. Still a very compact unit; easy to use.
  #42   Spotlight this post!
Unread 23-07-2014, 14:34
JamesTerm's Avatar
Terminator
AKA: James Killian
I also have been considering to use this model... Thanks for the feedback what would be great is to know how to make something similar to this buying separate parts that are affordable. From that one could buy a different lead screw like an 8 or 10 start. I'm having a hard time finding information about how to mount the motor onto the screw, and how this is self contained on the other end. I'd almost want to take one of these apart to see how they are doing it. (this is still research in progress)... Any insight to this would greatly be appreciated.
P.S. I was thinking of using this as a lead screw http://www.use-enco.com/CGI/INSRIT?P...&PMPXNO=942694
  #43   Spotlight this post!
Unread 23-07-2014, 16:40
Jared's Avatar
You don't have to drive the screw. If you drive the screw, you'll most likely need to support both ends with bearings and thrust bearings, and you'll need another bearing solution for the nut/carriage, which wants to twist. If you do drive the nut, you could probably mill a hex on the top/bottom and put a gear/versahub/sprocket on it.
You can also drive the nut, which is what we did on our climber. We found this to work well with the geometry of our climber, as the screws were non rotating and fixed to our climber arm.
We put the nut in an 1/8 inch wall aluminum box, drove it with a sprocket, and used two of these (http://www.mcmaster.com/#60715k11/=sysaez) bearings.
Multi start lead screws are awesome and can go pretty fast. We prototyped an 8 start climber that could lift the robot one level up in under 4 seconds, but were unable to use it due to other gearbox issues.
The material selection of both the nut and the screw are important too.
  #44   Spotlight this post!
Unread 23-07-2014, 17:18
JamesTerm's Avatar
Terminator
AKA: James Killian
I almost understand this and see the benefit of doing it this way... how exactly does the sprocket interact with the nut though? I know the vex #25 sprocket has a nice 1/2 inch Hex ID... does a sprocket like this mate with the driven nut in what you were saying?
  #45   Spotlight this post!
Unread 23-07-2014, 17:45
Jared's Avatar
http://www.mcmaster.com/#fast-travel-acme-nuts/=syswre
We used nuts identical to the ones at the top of that page. All the half inch multi start lead screws and their nuts can be purchased from amazon.com for a lot less. IIRC, they were from nook industries. To connect the nut to the sprocket, used a 14 tooth sprocket from McMaster, removed the hub and put a clearance hole for the lead screw.
To transfer the torque, we cut a small (0.1 thick?) groove about .25" deep on the diameter of the nut. We left behind part of the sprocket's hub, and it fit into this groove. There were also 2 4-40's that went into holes we tapped in the nut.
McMaster also sells flanges that can be screwed onto the end of the nuts too. You could also make your own if you have the ability to cut the threads. The 1/2" screw nuts have 15/16-16 threads on the outside.
If you aren't carrying a ton of weight, you could probably get away with using a few 8-32's to transfer the torque. You can buy "machinable" nuts that have room to add larger tapped holes to the end.
