Go to Post Last year we saved a ton of money by using a good bit of square tubing for the frame of our robot, square tubing is a lot cheaper then C channel. We get to use so much raw material that the cost should go down in certain places. - Derrick Maust [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 19-07-2014, 15:41
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Re: FRC Class Curriculum Help
We at 3211 developed this full curriculum recently.
Not sure how it will work, but as a master plan im very happy with the result.
https://docs.google.com/document/d/1...it?usp=sharing
it was inspired by some material from team 1114.
I'd also love to get some input on that =]
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 19-07-2014, 18:27
adiben123 adiben123 is offline
AKA: Adi
FRC #4272 (Maverick Boiler Robotics)
adiben123 is an unknown quantity at this point
My team (4272) has a class as part of the school day. Last year, we spent the entire class time as just extra time for all robotics projects. While that worked well in the spring during the build season, it made the fall season a bit boring and we felt we weren't utilizing our time. For this upcoming year, we created a full curriculum for the fall class. We broke up the class into several modules with some mini-workshops in between. The basics of it are below:
Module 1 - Introduction to the class, the team, and FIRST
Module 2 - Good workmanship
Mini-workshop: Resume making
Module 3 – Materials and Parts
Module 4 – Tools and machining
Mini-workshop: Branding and team image, spirit, social media, and marketing
Module 5 – General Mechanical Design
Module 6 – Electrical Work
Mini-workshop: Outreach and Fundraising
Module 7 – Programming
The fall class is supposed to teach students skills they would not normally have the time to learn during the build season. If you would like, we have curriculum for this more fleshed out that we can send to you.
In addition, we have all the materials from when we asked the school for a robotics class and are putting together step-by-step instructions on how to get a FIRST robotics class at your school
Email the team if you are interested! FIRSTteam4272@gmail.com
Unread 19-07-2014, 19:57
Chirag's Avatar
Chirag Chirag is offline
Alumni, now Remote Mentor (?)
AKA: Chirag Patel
FRC #4761 (Robockets)
Chirag is an unknown quantity at this point
Thanks for the offer! I just sent you guys an email.
That outline looks good. Basically what I was thinking of earlier. But yeah any additional material and information would be awesome!
Unread 19-07-2014, 23:43
nicholsjj's Avatar
nicholsjj nicholsjj is offline
AKA: John Nichols
no team (Devil Bots)
nicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant future
Chriag- Sorry for the long post.
First off I want to say that I appreciate your spirit for wanting to help form a robotics class at your school in order to leave behind a better program than when you started. Our school recently switched from an electronics program to a robotics program two years ago, and we are currently looking to fully taking it to a pre-engineering course in the next two years so i have been looking into this quite a bit lately. First off, I suggest searching the forums as there is a lot of information here on chief of how other teams have went about doing this. Secondly, you will need to make sure the class is built on the standards that your state provides, http://www.doe.mass.edu/frameworks/current.html here they are for reference. This is probably the most important part of the process and you should probably ask the most veteran or newest teachers at your school to help you out with this task. The major principal of it is that the class needs to be able to fulfill enough educational standards in order to get the school support. The nice part of this is at quick glance it looks like for MA you can fulfill over half the Science and Technology standards in one program. My advice to you is look through these standards and you ideas about what the program should look like and try to match up as many as possible. Examples can be wiring the electrical system of the robot can be used to explain the standards in electrical energy. Cadding the robot allows for the modeling standards to be met etc. Finally you will need administration support to pull it through. Try to get as many principals, superintendents, or school board members involved in your program as possible in order for them to see the enthusiasm and growth of the students in robotics. With their support it is much more easy to get a classroom class established. Also it is more easy to find funding with the higher ups on board. If you do these three things then you will be in good shape for having your goal of a robotics class come to light.
2011-FRC Team 3862, Team Captain
2012-FRC Team 3862, Strategy Mentor
2013-FRC Team 3885, Programming Mentor, Razorback Regional, Curie Inspector
2014- FRC Team 3885, Programming Mentor, Arkansas Regional, Newton inspector
2015-??? Teacher Murphysboro High School
“They call it coaching but it is teaching. You do not just tell them…you show them the reasons.”- V. Lombardi
Unread 20-07-2014, 03:53
jpetito jpetito is offline
jpetito
AKA: Joe Petito
FRC #1197 (TorBots)
jpetito is a splendid one to beholdjpetito is a splendid one to beholdjpetito is a splendid one to beholdjpetito is a splendid one to beholdjpetito is a splendid one to beholdjpetito is a splendid one to behold
I'd like to affirm Nicholsjj: Getting buy-in from the people who set the curriculum is the most difficult part. You have to meet whatever state standards are in existence for math and science and squeeze in the robotics program to describe as many points of contact as possible. A number of states have adapted something called "A through G," a set of standards that make something like a for-credit FRC-style building program difficult to fit into. If the class is offered as an elective, the honors and college-prep students will be reluctant to take the class: An "A" will pull down their gpa (as unlikely as it sounds). Keep asking the questions!
Unread 20-07-2014, 04:39
safiq10's Avatar
safiq10 safiq10 is offline
FRC #2950 (DEVASTATORS)
safiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond repute
Now we have convinced our school board to let us juniors have our current engineering class as a robotics class, which is awesome expect for the fact that the school board is forcing the junior class to work on 2 other robotics competitions (FTC and BEST). So we decided that we will attempt to work on FRC by using FTC and BEST as our in class training grounds. So my question is have any of you been in a similar situation and how did you go about it?
2014 Dallas Semi-Finalist (Thanks 3847 & 231)
2014 OKC Semi-Finalist (Thanks 2341 & 2461)
Unread 20-07-2014, 13:38
Chirag's Avatar
AKA: Chirag Patel
Looking at the MA guidelines, it looks like we definitely could satisfy most of those requirements for an engineering class. But that definitely helps with giving the curriculum a more defined shape. Thanks nicholsjj!
As for getting school board members, the principal, and superintendent on board, I feel like that shouldn't be too hard as long as we follow those guidelines and really show how beneficial the class is. We recently gave the school committee a presentation on our team and our last two seasons and they were extremely impressed by us and FIRST as a whole. They said they were eager to help in any way possible so that seems like a good sign. Plus our school has recently been trying to emphasize engineering in the school with PLTW classes so I think this may just be the perfect time to ask.
