3D Printed Name Plate
Hello CD Community, I need some help Editing a .STEP file so i can sketch on the Name plate's plane for my Mouse. But there is no Plane for it, I tried sketching Text and Extrude cutting it on the Front Plane but it didn't work.
Here's a Link to the CAD Files: Steel Serieshttp://cdn-co.steelseries.com/wp-con...e_3d_files.zip |
Re: 3D Printed Name Plate
Which CAD program are you using?
What about this approach didn't work? Last edited by RyanCahoon : 21-07-2014 at 22:17. |
Could you try using Tinkercad? It might just work for you.
PS Tell us what you did once you have figured it out. |
It really is important that you let us know what Modeling program you are using. You are correct that there will be errors, the name plate plane is not a regular curved surface (lack of better term). I got this done in a couple of minutes using the emboss tool - Inventor 2013.
Ill try it out. |
#7
The surface is curved and my text would come out unbalanced
#8
Solidworks is not the program that I'm the most familiar with but with a quick search I found many tutorials in youtube - the best was this one http://www.youtube.com/watch?v=gTqbFgEppKY
#9
First, I made a Sketch on the front plane and Sketched My text. Next, I Cut Extruded the Text and Cut Extruded From a Surface/Face/Plane and selected the curved surface of the Piece. Then, I cut extruded by 1/16" and I was done. Thank you all for your help. I greatly appreciate it |
