Go to Post The mediocre do the minimum, then exclaim how easy it is. The exceptional never stop to gloat... they're too busy figuring out new ways to make it even better... - Mr. Lim [more]
Unread 21-07-2014, 12:41
AdamHeard's Avatar
Lead Mentor
Re: pic: Omniwheel Minibot
Make sure the lipos you get can handle the potentially huge currents 2 CIMs would cause. Trying to draw too much from them can cause thermal runaway and fire.
In terms of size and weight, I think you'd get a more satisfying performance by switching to 550's or 775 sized motors as you can shave a lot of size and weight off, without a large power loss.
Unread 21-07-2014, 13:25
Chris Endres Chris Endres is offline
Play hard, Work harder
AKA: Topher
no team (WildStang)
Team Role: CAD
Chris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really nice
I would have to agree with Adam; for this size, you wouldn't need that much power from two CIMs to move the weight of the bot.
2009 FLL Illinois State Champions - iLEGO
2010 FLL Illinois State Champions - iLEGO
2011 FLL Illinois State 3rd Place - iLEGO
2011 FLL Illinois State 1st Ambassador - iLEGO
2013 FRC Milwaukee Regional Champions - WildStang
2016 FRC Midwest Regional Finalists - WildStang
Unread 21-07-2014, 22:41
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Scott Kozutsky will become famous soon enough
The reason I chose to go with CIMs is because it's actually cheaper and simpler than using those more sensible motors. The Cim motor isn't much more expensive than a 775 for instance but because of the lower speed and higher torque we don't need any additional stages and we don't need to buy either non-vex gears or versaplanetaries. Also, because it's so light I doubt we'll see the massive stall currents that CIMs are capable of.
I'm actually planning a WCD styled minibot that uses 500 series brushless motors (made out of 30mmx15mmx1.5mm alu extrusion, I need to practice my metric) so it will also fit the RS 550.
Unread 21-07-2014, 22:45
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Additionally you have to look at its intended use. We regularly do demos for 6 hours without cool downs. The additional thermal mass will prevent over heating the motors.
2016: FRC 865 Mentor
Unread 22-07-2014, 18:05
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
I see you've got the rendering pretty well figured out. Could you share a bit about how it was done? It looks photorealistic :)
Unread 22-07-2014, 18:10
mman1506's Avatar
no team (WARP7)
I'm no expert but it was done in Solidworks photoview. Make sure perspective is on. I also added a spotlight to make things look a little more realistic.
