Go to Post theres no such thing as the best robot...cuz every robot is the best :D - [more]
Unread 24-07-2014, 15:07
Andrew Lawrence
Posts: n/a
Re: pic: #NotSwerve
What spreads and speeds are you using on the transmissions, alongside what wheels? Also, will you have any active way of measuring your total current draw with the 6 CIMs?
Unread 24-07-2014, 15:17
llamadon's Avatar
llamadon llamadon is offline
Gold pants swag
AKA: Quinn
FRC #2169 (KING TeC)
llamadon is just really nicellamadon is just really nicellamadon is just really nicellamadon is just really nice
Re: pic: #NotSwerve
Hey Brian, these gearboxes are going to be implemented on a summer drive project aimed towards testing the benefits of a 6 cim WC drive. We hope that future games will still allow for west coast drives to be feasible designs, and that our work this summer can be used for seasons to come.
Unread 24-07-2014, 15:27
llamadon's Avatar
Gold pants swag
AKA: Quinn
Re: pic: #NotSwerve
We plan to use 4" hex bore Andymark performance wheels on live axles with blue nitrile tread. We will be testing a 2.92 spread ratio, set to roughly 7fps/18fps, a 3.64 spread at 5.5fps/18fps, and finally a 2.06 spread geared to 7fps/13.5fps. The 2.06 spread is being tested specifically to see what kinds of acceleration we will see with a lower top speed, but more torque. As for the current draw, we have not thought of any ways to measure that yet.
Unread 24-07-2014, 15:33
Andrew Lawrence
Posts: n/a
Re: pic: #NotSwerve
Excellent idea of testing the different speeds and spreads. I'm not entirely certain what method they used, but Team Spectrum 3847 had a method of measuring their current draw on their robot this year. While you are testing spreads, I think it would be interesting to add this current meter to see how many amps you're pulling in certain situations. It could help you better assess what main breaker limitations you may have in the future.
Unread 24-07-2014, 15:42
llamadon's Avatar
Gold pants swag
AKA: Quinn
Re: pic: #NotSwerve
Thanks! I will definitely inquire of this testing methods. I have read up a small amount on the effects of this number of CIMs on the breaker and have heard of a few blow outs. These blow outs tend to happen in an immediate change in voltage. IE. driving the robot forward and then immediately going backwards. Teams have implemented a part in the code that does not allow this immediate jump from 0 to 100 percent, and instead ramps it up steadily.
Unread 24-07-2014, 15:46
AKSoapy29's Avatar
AKSoapy29 AKSoapy29 is offline
Driver, Prog, Elec, Pneu, Etc.
AKA: Andrew K.
AKSoapy29 has a spectacular aura aboutAKSoapy29 has a spectacular aura aboutAKSoapy29 has a spectacular aura about
Re: pic: #NotSwerve
Well we only tripped the breakers a few times on our shooter, lol. Load testing would be neat. I think we have a load tester in the cave actually, I saw it the other day.
Unread 25-07-2014, 12:00
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
Re: pic: #NotSwerve
We used these gearboxes on our robot this year. They were fantastic, esp. considering how we abused them. A few notes :
1. LOCKTITE like the instructions say. We did not do this and it caused several screw failures throughout the season, resulting in worn teeth on some of our gears. The gears themselves are overbuilt - they survived the extreme chipping a CIM coming unmounted caused.
2. The 22 fps calculated speed is too fast to drive without proper code, and will blow your breakers whenever you hit anything. For FRC applications , I don't recommend going faster than 16 FPS.
I'd be very interested in seeing the results of your tests of different ratios.
Unread 25-07-2014, 12:09
AKSoapy29's Avatar
AKA: Andrew K.
Re: pic: #NotSwerve
Thank you, this is very useful to know! 22 fps does seem too fast. I think I have only driven with 16, and it was plenty, and easy to control. I am really interested to see how our new drive train will handle!
Unread 25-07-2014, 12:14
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
Re: pic: #NotSwerve
There were a fair number of very successful teams this year that ran 6 CIM drive trains geared to >20fps before losses. Its possible to do but you have to be careful with you dont blow your breakers.
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Unread 25-07-2014, 12:27
RKazmer RKazmer is offline
FIRST Volunteer
AKA: Richard Kazmer
FRC #2363
RKazmer is on a distinguished road
Re: pic: #NotSwerve
Originally Posted by AKSoapy29 View Post
Oh yeah, and the first shooter was 100% pneumatic, and we were constantly working on it. Tip for anyone in the future: Don't use a pneumatic shooter unless you get it working REALLY well.
This is very true. It took three weeks of prototyping to get the shooter right on our robot this year. We even had to tweak it after that due to other pieces for better ball control and stability. However, having a pneumatic shooter was great since we didn't have to have stored energy on the bot versus a spring or motor driven shooting system.
Main lesson for using pneumatics to power a catapult: Start early and have multiple designs that can be tested quickly.
Unread 25-07-2014, 16:45
llamadon's Avatar
Gold pants swag
AKA: Quinn
Re: pic: #NotSwerve
Thanks Arpan! I will definitely post the results of our testing for you to veiw
I will remember the locktite! As for the speed I was actually having an mental debate with myself, and that is: Why gear for a high speed like say 22 fps? How often will you actually attain that speed? Being able to accelerate quickly is much more beneficial (in my mind) then being able to reach a high speed after spending a notable amount of time accelerating. Just a thought, and one of the reasons for the testing
Unread 25-07-2014, 17:06
Andrew Lawrence
Posts: n/a
Re: pic: #NotSwerve
Teams that gear for that speed use it in cases where you would want to cross the entire field extremely quickly in one straight shot (think 2011 or 2013). That being said, it's still something interesting to test. Most robots that run these speeds are on the lighter side (90-100 lbs), which helps them abuse the higher speeds with greater acceleration.
Unread 25-07-2014, 18:26
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Re: pic: #NotSwerve
These were sufficiently evil enough for our purposes in 2014.
4" Colsons on corners, 4" blue nitrile performance in the middle, 2.92 spread, max robot weight, roughly 5 fps / 15 fps split
And yes, Loctite everything per instructions.
Unread 25-07-2014, 21:38
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Re: pic: #NotSwerve
Originally Posted by ClockworkGold View Post
Originally Posted by audietron View Post
Nice Job! Are you still planning on improving the swerve drive throughout the next couple seasons?
Heck no
It looks like I missed the back story here. If it's not too painful would someone from 2169 mind recounting their season of swerve and what problems you had with it for other teams who are dead set on at least trying swerve as an off season project so they may learn from your season?
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 26-07-2014, 23:46
llamadon's Avatar
Gold pants swag
AKA: Quinn
Re: pic: #NotSwerve
We used the "Wild Swerve" modules from Team 221 robotics parts. We did not order them prior to build season. I think they were ordered by the end of week 1. Arriving mid week 2, we assembled them and attached them to our drive base. Our programers were coding prior to receiving the modules, confident in their code. We implement the code, not up to snuff. We keep editing and revising, problems arise left and right (using 3D printed encoder mounts was one of said issues.) We focused so much on our swerve that other mechanisms suffered. We over complicated the code, and the start up routine for each match (we had a "hard zero" button to "reset" the encoder values to 0) and in the end we didn't move for half our regionals. My advice is do your trouble shooting and learning before the build season, and only implement swerve for the build season if you already have a polished code for it, and have designed and planned the mechanical implementation of the drive before kick-off.
